Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. May 17, 2019 at 7:56 AM
    #1771
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    Thanks brother, I love the look! My favorite about the truck is the audio upgrade, I feel like I can shatter windows with how load it is!!!
    Newm[QUOTED] likes this.
  2. May 20, 2019 at 1:21 PM
    #1772
    KTM Hauler
    KTM Hauler New Member
    Rich
    Santa Clarita
    2017 SR5 Tundra 4x4
    Method 306 18"x9" Nitto Ridge Grapplers 275/65r18 Leveling kit
    Those tires make me want to do donuts in a wet grassy field!!
  3. May 20, 2019 at 8:51 PM
    #1773
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Yeah that would be a real mess. Trust me these things do a job just barely moving straight in softer grass. The meats on them dig in and RIP chunks just going slow a d straight. With the wheel cocked and w.o.t it can get real ugly, in a good way of course.
  4. May 23, 2019 at 9:27 PM
    #1774
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    Any Upper control arms installed
  5. May 26, 2019 at 9:37 AM
    #1775
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Added Sota Novakane in Deathmetal 20x9" +25 offset and 275 60r20 BFG KO2's yesterday. Resized_20190525_132324.jpg Resized_20190525_132337.jpg
  6. May 27, 2019 at 6:13 PM
    #1776
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    Just got a new 4wd Tundra and kind of hate the stock wheels. I normally don't go aftermarket on wheels but would like to find something reasonable for this truck
    I don't do a ton off-road and do a lot of highway miles so would like to stick to a tire with around 50k of life or more on the road.
    Most off roading is on dirt roads sometimes with gravel and sometimes not, but also get into grass fields for dirt bike racing events and can be tricky when it rains, but in those cases there are people around to help out if you get stuck.
    Think i'm going to stick with the 18's either way but can't really justify just throwing out the stock tires so would like to put them on a better looking set of rims, unless you guys thing the stockers wear out fast anyway or just aren't good for the kind of off road I'm looking at.
    What should I be looking for as far as wheels go for decent quality at a reasonable price? I'm not looking for bling or name brands just something that will last and leaning towards a black color
  7. May 28, 2019 at 5:01 PM
    #1777
    TwistedTad
    TwistedTad TRUCK GANG “T”
    Tad
    Canyon Lake, CA
    2019 Cement Limited CM 4x4
    Method NV 18x9 with +25 offset. 295/70/18 Toyo AT2 Extreme. Toytec BOSS 3/1.5.
  8. May 29, 2019 at 11:46 AM
    #1778
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    OEM TRD Sport wheels with 3/1.5 leveling and Cooper AT3 XLT 275/65/20 tires. They are a 34.2" OD; slight rubbing on the front mudflap thingies (which I removed) and on the skid plate (which I hammered in about 1/2". No rubbing anymore.
  9. May 29, 2019 at 12:29 PM
    #1779
    LiftMeUp
    LiftMeUp New Member
    That is a good looking truck. I'm about to lift the front 3" and waiting to see if I can fit 285/65/20s on stocks. If not, then will probably drop to 275/60. Too bad there isn't a huge price difference it would make it easier! :)
    Any issues with rubbing on the stock UCAs?
  10. May 29, 2019 at 12:58 PM
    #1780
    Boerseun
    Ferdie
    Sarasota Florida
    I was going back-and-forth between the 275/65 and 285/65. The difference is from 34.2" to 34.6" OD. I was rubbing on the inside against the skid plate, but it was an easy fix - small rubber mallet and a few wacks was all it took to bend it over and about 1/2" out of the way. The 285 is slightly wider, so it will rub more there. At full lock my passenger side is also almost touching the sway bar, which is not that easy to change. In the front the outside edge rubbed the small mud flaps. Again the 285 is a little wider, and will rub more. With them removed, you should be okay there also.
    There is a little gap between the tire and UCA. The 285 should fit, but it will be very close. With the 285s I would have added spacers to prevent it from rubbing on the UCAs. But spacers will put it closer to the front bumper liner. Always a catch 22.
    Seeing where the 275/65s are, I think the 285/65s might be just a hair too big causing unnecessary concerns, using OEM wheels and UCAs. It will work, but it will be very tight.
    LiftMeUp[QUOTED] likes this.
  11. May 29, 2019 at 1:31 PM
    #1781
    LiftMeUp
    LiftMeUp New Member
    I know, just don't want to listen to reason! I'm wanting that half inch in height and hate to go smaller and could have fit bigger, but not sure that .5 is worth everything it may come with.
    Trying to stay away from the spacers and like you said, clears one concern and brings up others.
    Thanks.
    Boerseun[QUOTED] likes this.
  12. May 30, 2019 at 7:50 PM
    #1782
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    F08273B9-5F7B-41EB-BA74-0B491F2A4F16.jpgFuel D561 22x12 -44 offset
    Fury Tires 33x14.5
    Biby, BlakRaptor, yoshi82 and 6 others like this.
  13. Jun 2, 2019 at 11:47 AM
    #1783
    Quicksand20
    Quicksand20 New Member
    Ryan
    2019 Quicksand Tundra SR5 TRD Off Road
    Does anyone know if I could run a 295/70/17 on a 2019 with bilstein 5100s up front? According to tire size calculator they are about same size as the 275/70/18s that people run just alittle wider.
  14. Jun 2, 2019 at 1:54 PM
    #1784
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    Wet 35x12.5x17 RTs with some Icon Six Speeds :cool:46030.jpg
  15. Jun 2, 2019 at 3:09 PM
    #1785
    Beesta
    Beesta New Member
    Jay
    Loudoun County
  16. Jun 3, 2019 at 11:03 AM
    #1786
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Nice! Do you have any more pictures?
  17. Jun 3, 2019 at 4:00 PM
    #1787
    Swalters
    Sam
    Arizona
    More in my build thread, too
  18. Jun 3, 2019 at 6:40 PM
    #1788
    equin
    Ed
    DFW, TX
    Awesome 1st gen!
  19. Jun 3, 2019 at 7:38 PM
    #1789
    Swalters
    Sam
    Arizona
    Thanks!
    equin[QUOTED] likes this.
  20. Jun 4, 2019 at 4:58 PM
    #1790
    Benny63
    Benny63 New Member
    Hello CSUVIPER ,I'm having trouble understanding the 17 inch RW wheels which have B F Goodrich 285 70 R17 that are on my truck ,with an 18 inch wheel and tire as a spare. What would the right size tire on the spare need to be? Thanks for having patience with me.
  21. Jun 4, 2019 at 5:15 PM
    #1791
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    275/65/18 (stock size) will be very very close to the 285/70/17. And cheap
    equin likes this.
  22. Jun 4, 2019 at 5:33 PM
    #1792
    Benny63
    Benny63 New Member
    Thanks Hbjeff, that's great ,I thought I was screwed if I needed to swap out a flat, again thanks for the information. Benny 63
  23. Jun 5, 2019 at 2:43 PM
    #1793
    Hippo442
    Hippo442 New Member
    2016 Sunset Mica 1794 Tundra
    Needing some advice. Looking to finally wrap my SCS ray10s with some rubbers. Im pretty set on Goodyear Druatracs. My truck has stock suspension and I was hoping to get them in 275/70/r18, only I just realized this size in this tire is only good for 7-8.5in rim range. So, wasn't really planning on doing suspension, but would you guys recommend I drop to 275/65? or go up to 285/65? I'm pretty certain from the research I've don't that the 285/65 would require a leveling kit. Any advice is appreciated, thanks all.
  24. Jun 5, 2019 at 2:59 PM
    #1794
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    Plenty of folks run 275/70/18 on SCS wheels. My Duratracs are 295/65/18 but my front is lifted 2". My spare (mounted on a matching SCS SR8 wheel) is 275/70/18.
    Without leveling, either a 275/70 or 285/65 will work. The 275s are only .39" narrower than the 285s but IMHO the taller 275s fill out the wheel well a little better.
  25. Jun 5, 2019 at 3:29 PM
    #1795
    Hippo442
    Hippo442 New Member
    Thanks for the advice. So far I really like the 275/70 look on stock suspension. But on the Goodyear duratrac website, that size tire for duratracs only fit a 7-8.5in rim, and the Ray10s are 9in if I'm not mistaken. Honestly at this point I think I might just start doing my research on suspension/ leveling kits, I was going to add it later down the road but seems like sooner is better.
    Your truck is super clean by the way, always loved that white with black accents.
    sr5shark[QUOTED] likes this.
  26. Jun 8, 2019 at 1:44 PM
    #1796
    Hippo442
    Hippo442 New Member
    I Ended up going with 275/65 for now, until I can pull the trigger on some suspension. Overall really happy with how it made the truck.
  27. Jun 8, 2019 at 2:22 PM
    #1797
    Well8302Tundi
    Well8302Tundi New Member
    Chad
    MN
    2007 Tundra Limited SSM
    Rancho Quick-Lift 2", Line-X Bedliner
    2007 Tundra Double Cab
    20" Fuel Coupler 20mm Offset
    275/60 Falken Wild Peak
  28. Jun 8, 2019 at 3:50 PM
    #1798
    effect
    effect New Member
    I have a 2019 Tundra Tundra Double Cab SR5 stock with P275/55R20 on right now. I was wondering if I would be safe from rubbing if I went with P285/70R17?
  29. Jun 8, 2019 at 5:32 PM
    #1799
    Lighterknot1974
    Lighterknot1974 New Member
    Jake
    2019 crew max SR5 4x4
    Black out badges, 4/2 lift level, led lights inside and out
    2019 tundra CM MGM
    Readylift 4/2 lift/leveling kit with tubular upper control arms
    20 x 9 Panther off road 0mm offset
    305 55R 20 Atturo trail blade x/t
    2CFC9377-AE91-41A2-AF2D-81D372B85E2B.jpg 331F3261-44EB-4493-AA01-7F20A44F7AC9.jpg CE21239D-56C8-414E-9889-4C9B5F297936.jpg 2D31470B-351D-4A3D-A32E-8FB8BEEED171.jpg
  30. Jun 22, 2019 at 5:44 PM
    #1800
    paradox2311
    paradox2311 New Member
    24x12 intro’s -56 offset
    35x13.5x24 amp MT
