Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Apr 9, 2019 at 7:21 AM
    #1711
    Tundra Marine
    Tundra Marine New Member
    Houston, Texas
    Thank you for this! I’ll be saving this info and checking you signature out. Do you think a 3 or 4 inch lift would provide enough wheel/tire clearance without it rubbing and having to cut bend or mold anything?
  2. Apr 9, 2019 at 9:34 AM
    #1712
    ToyLC
    ToyLC New Member
    That is what I was hoping for, but it did not work out for me. I also did not want spacers at all.
    Tundra Marine[QUOTED] likes this.
  3. Apr 9, 2019 at 10:35 AM
    #1713
    Tundra Marine
    Houston, Texas
    Dang, so maybe it might be worth just getting a 6 inch lift if I don’t mind not fitting in parking garages? I’m new here but wanting a lifted tundra and can’t decide between your size lift or a 6/7 inch lift. I don’t mind gas mileage, and I don’t care about sacrificing turn radius or access to parking garages etc. should I just go all out then?
  4. Apr 9, 2019 at 5:46 PM
    #1714
    ToyLC
    ToyLC New Member
    You will have to make the call, I love the look of a 6-7” lift, but for me, I still tow a couple trailers from time to time and am constantly putting shit in the bed...that tall won’t work for me. Plus I’m fat and out of shape :), so I’m making a wise’ish choice in my case.
    With the 295/70R18’s, I’ve added another inch for an overall lift of 4”...with that size tire, aesthetically I like it.
    There are a few guys on here with build threads that have the larger lift. I suspect you will love it whichever way you go. Good luck.
  5. Apr 10, 2019 at 8:39 AM
    #1715
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    any 285/65/18 on stock 3rd gen pics? Any trimming necessary or scraping?
  6. Apr 10, 2019 at 11:36 AM
    #1716
    TNTundra53
    TNTundra53 New Member
    So i would like to ask about this topic and hopefully will not get judged and blasted for it as some other groups do. I have purchased a 3/1.5 rough country kit for my 2012 Tundra. So the question have is if i go with a 20x10 what backspacing should i go with to push it just past the fenders and what size tire should i run to avoid trimming? I also have a set of 22 x 9's i could use, so if i went with them using this kit could i run a set of the 285/55/22 Nitto's effectively? Just wanting some suggestions as i am trying to do this on a budget and stretch my money as far as i can.
  7. Apr 11, 2019 at 8:36 AM
    #1717
    LiftMeUp
    LiftMeUp New Member
    Is there anyway of fitting 285/65/20s on stock rims after a 3" front lift. I was told that I should be fine with not rubbing the UCAs if I stay under 11.5 on width and those tires are 11.2. If I clear that what kind of trimming am I looking at doing? Would like to avoid wheel spacers if I can.
  8. Apr 12, 2019 at 7:23 PM
    #1718
    bennys8
    bennys8 New Member
    Toyo A/T 285/60/20 on Ultra Motorsports Apocalypse (bronze milled w/ black lip) +18 offset. Didn't go wider to avoid cutting but it still required removing front mud flaps and cutting filet size portion of front fender liner. 2.5'' leveling spacer in front. Bushwacker extend-a-fender flares. Still looking for an excellent body shop in San Jose to paint front grill bezel and front bumper end caps (want to retain front parking sensors).Tundra flares wheels.jpg Tundra flares rear.jpg Tundra flares front.jpg
  9. Apr 15, 2019 at 8:13 AM
    #1719
    LiftMeUp
    LiftMeUp New Member
    You and me both! Wildpeaks was all set, never seen a single bad thing about them, I know it's the best to go with, but some just look better.
    bigblue14[QUOTED] likes this.
  10. Apr 15, 2019 at 8:18 AM
    #1720
    LiftMeUp
    LiftMeUp New Member
    I don't or didn't want spacers but seems like you almost have to use them with stock rims and a 3" lift to get away with a 34 or 34+ tire?
  11. Apr 15, 2019 at 9:17 AM
    #1721
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I'm eyeing 295/60s next on my stock platinum rims. I have 285/55s currently with a 3/1.5 & SPC UCAs and it looks like I might need spacers to clear. I have 1" bora spacers ready. They stick out far enough that I don't need to cut studs.
    LiftMeUp[QUOTED] likes this.
  12. Apr 15, 2019 at 9:19 AM
    #1722
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    @TTU19 - Did you ever get this done? How did it turn out?
    @Javelin - Is that a special run by FN because I don't see that wheel option on their site?
  13. Apr 15, 2019 at 9:45 AM
    #1723
    LiftMeUp
    LiftMeUp New Member
    I've seen that in a couple of post about cutting the studs. What's the issue with that?
  14. Apr 15, 2019 at 10:30 AM
    #1724
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I did, but I ended up adding a lift after all, ha. I got the 6112s in the font on 2.5", and 5100 in the back at 1". I absolutely love the way it turned out an very happy I added the lift.
  15. Apr 15, 2019 at 11:09 AM
    #1725
    bigblue14
    Craig
    The .75" Bora spacers aren't deep enough to clear the factory studs. Those will stick out and would likely interfere with your wheels. Some wheels have casting reliefs but the platinums are in the wrong spot. For mine the 1" are good - adding that qualifier since everyone seems to be a little different.
  16. Apr 15, 2019 at 12:21 PM
    #1726
    airgunner
    N-KY
    2015 DC MGM TRD
    Yeah I didn't think those tires were going to fit on a stock suspension. What did you do for the 1" in the back? (5100's don't add any height)
  17. Apr 15, 2019 at 1:16 PM
    #1727
    motod6
    motod6 New Member
    David
    2015 White TRD
    17" ICON Rebounds W/ BFG AT 315 70 17. Rubbed on front mud guard. No BMC/CMC was needed
  18. Apr 15, 2019 at 6:13 PM
    #1728
    ToyLC
    ToyLC New Member
    Yes, seems like most do. There ok, but really would prefer not to have them, it’s just a preference for me...always has been.
  19. Apr 16, 2019 at 6:18 AM
    #1729
    LiftMeUp
    LiftMeUp New Member
    I'm guessing the only way around it is either smaller tires (nooooo) or aftermarket wheels with the proper offset. To make up for not having spacers, what kind of offset would I mostly likely need. Not looking for improved stance, just clearing the UCAs.
  20. Apr 16, 2019 at 6:25 AM
    #1730
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    The past couple of months of looking around at different topics is that +25 to +35 is the "sweet spot."
    LiftMeUp, equin and bigblue14 like this.
  21. Apr 16, 2019 at 8:02 AM
    #1731
    ToyLC
    ToyLC New Member
    Yes, exactly. With the 1" spacers and the factory wheel, offset is right at +35
    This^
    LiftMeUp[QUOTED] and bigblue14 like this.
  22. Apr 16, 2019 at 8:11 AM
    #1732
    DMB4x4
    DMB4x4 New Member
    2014 Tundra SR5 CM 4x4
    Icon 17” Rebound
    285/75/17 BFG KO2
    Bilstein 5100 (Middle Setting)
    Trimming was needed on passenger side.
    No BMC.
  23. Apr 16, 2019 at 8:45 AM
    #1733
    TundraLaw
    Northern Nevada
    Highly considering load range C Toyo open country's on 275/65/18 on stock suspension. Anyone with pics like that?
  24. Apr 16, 2019 at 11:05 AM
    #1734
    LiftMeUp
    LiftMeUp New Member
    Seems like I've seen the same.
  25. Apr 16, 2019 at 6:44 PM
    #1735
    ToyLC
    ToyLC New Member
    I’d be interested in a confirmation as well. Specifically, in my case with the Cooper Discover AT3 XLT. :oldglory:
  26. Apr 16, 2019 at 7:13 PM
    #1736
    Hyperlite33
    Hyperlite33 FN-2187
    2018 White Platinum 4x4
    :popcorn:
  27. Apr 18, 2019 at 5:50 PM
    #1737
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Finally got a good picture with it cleaned up.
    DaBoro54, equin, 11CMGray and 2 others like this.
  28. Apr 20, 2019 at 12:47 AM
    #1738
    KenSeltzer
    KenSeltzer New Member
    Big fan of Icon Rebounds. Anyone have them/anyother Icons on a Cement Tundra and can share photos please.
  29. Apr 20, 2019 at 5:39 AM
    #1739
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I love my Rebounds! Not a Cement, but here are some Titaniums on a Silver Sky with 285/75/17s (33.8”):
  30. Apr 22, 2019 at 9:35 AM
    #1740
    Nate20105
    Nate20105 New Member
    Nathan
    2014 Silver Tundra SR5 CrewMax
    Is anyone running 20x10 Fuel Assault wheels? I went to a wheel place in town and they told me they wouldn't fit .
    LiftMeUp likes this.
