Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 7, 2019 at 12:49 PM
    #1621
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    3" toytec coil over lift
    Just my personal opinion, but I hate anything aftermarket when it comes to electronics. I'm in the business and have seen WAY too many "Gremlins" introduced this way. I just know that I'm off 2-3 mph @ HWY/Freeway speeds. Close enough for me. But again, just my $.02
  2. Mar 7, 2019 at 12:58 PM
    #1622
    airgunner
    airgunner New Member
    N-KY
    2015 DC MGM TRD
    I am really curious to see how this one turns out? I hope for your sake that I'm wrong but I don't see those fitting on a stock suspension, especially with +1 offset wheel?
  3. Mar 7, 2019 at 1:14 PM
    #1623
    Scavezze1971
    Scavezze1971 New Member
    Greg
    2018 SR5 Plus TRD Off-road (Canadian)
    What size leveling kit and what is the backspacing on those wheels? This is the look I want. Great looking truck!
    SK_Tundra likes this.
  4. Mar 7, 2019 at 1:37 PM
    #1624
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    Thank you sir! Camburg put a kit together and it’s a combination of fox 2.5 coilovers and rear 2.0 fox shocks with Camburg UCA. The wheel offset is 18x9 5x150 offset +25.
  5. Mar 7, 2019 at 1:48 PM
    #1625
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Haha me too but said it should be ok. So we’ll see. If it requires too much trimming I may have to get a small lift, but trying to avoid it. We shall see on Tuesday.
  6. Mar 7, 2019 at 1:49 PM
    #1626
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I've added bigger tires to every truck I've ever had in the past 25 years and have never done anything to recalibrate the speedometer. I just remember to make a mental note to myself that I may be going a bit faster than what the speedometer indicates and adjust my speed accordingly.
    Pjholt and TTU19[QUOTED] like this.
  7. Mar 7, 2019 at 6:59 PM
    #1627
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    By GPS, the speedo is off by 1.15 mph (slower) at 60mph. Speedo reads 60, GPS reads 61.15. I'm sure it will be slightly more off at higher speeds.
    equin likes this.
  8. Mar 8, 2019 at 6:57 AM
    #1628
    itsBryantP
    itsBryantP New Member
    B
    yep, your speedo is off by 1.92% and the higher the speed, the higher the value that 1.92% will be.
    r1-superstar[QUOTED] likes this.
  9. Mar 11, 2019 at 11:50 AM
    #1629
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    I have a 2018 sr5 4x4 off-road CM. I have a set of fuel sledge 20x9 +20. I plan on getting a 3/1 level and tires/wheels put on at the same time. I’ve been waiting for Uncle Sam to give me my money back and he’s finally paid up so I’m ready.
    I’ve spent many hours looking through the different wheel and tire threads. Issue I’m having is conflicting info around here. Some people say they put on 35x12.5 with the setup I’m going for with no cmc, some people got the cmc. I’m good with trimming/bending plastic and removing mud flaps but don’t want the cmc. Are the 35’s gonna fit or do I need to go down to a 34x11.5 ?
  10. Mar 11, 2019 at 12:08 PM
    #1630
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    I cant say 4 sure or not, but can tell u the reason theres conflicting reports. That's due to offset as main factor. The more negative offset the more likely u will need a cmc. Another factor wheel width and true tire size, the more narrow the less likely. Hope this helps.
    walter93 and Tundra$[QUOTED] like this.
  11. Mar 11, 2019 at 12:10 PM
    #1631
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    Every vehicle is slightly different, but I would be amazed if the CMC was not needed with full 35 x 12.5's. See pics of my 18 CM. I have the same lift/level with 315/70x17 (34.5" x 12.6") on ICON 6 speeds +25. I rub the cab mount ever so slightly in reverse at full lock.
    Check the tire manufacturer for actual dimensions as there is quite a range between tire brands/models
  12. Mar 11, 2019 at 12:20 PM
    #1632
    mgm16trdpro
    Northern NJ
    35x12.5 Pitbull Rockers on 17x8.5 method 313s matte black in 0 offset. A very aggressive bmc and front bumper cut was needed.
  13. Mar 11, 2019 at 12:25 PM
    #1633
    Tundra$
    Las Vegas
    I’m looking at the Nitto ridge grapplers. The 2 sizes I’ve been contemplating are the 35x12.5r20 (34.76x12.52) and the 285 65 r20 (34.8x11.5). My understanding is the width is the issue not the height so much right? Would an inch less of width solve the possibility of rubbing the cab mount?
    walter93 likes this.
  14. Mar 11, 2019 at 12:27 PM
    #1634
    dlos
    dlos Truckin'
    2019 Cement Off-Road
    Mods Mods Mods....
    I'm running 18x9 Fuel Sledge +1 offset, I also didn't want them to stick out as far as they do (about 2"+). I decided after a couple weeks of driving around getting covered in mud and hearing rocks kicking up into the door panels to add fencer flares. I like the way the tires look sticking out, just don't want to constantly deal with the mess. I'll post up some pictures once the flares are on (at body shop getting painted).
  15. Mar 11, 2019 at 12:28 PM
    #1635
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I freaking love this truck. My favorite part is that it isn’t lifted sky high on those meaty tires.
    mgm16trdpro[QUOTED] likes this.
  16. Mar 11, 2019 at 2:37 PM
    #1636
    03tundra4x4
    03tundra4x4 New Member
    Jordan
    Bristol, TN
    lifted 03 tundra access cab
    2 in front spacer with bilstein 5100s, wheelers 3 pack springs in the rear and 16x8 -10 level 8 mk6 on lt285/75/16 falken wildpeak at3
    New to this forum and the tundra platform. Here's my 03 tundra. 2 inch front spacer up front, wheelers 3 pack leafs in the rear, bilstein 5100s (coming soon), fallen wildpeak at3 lt285/75/16 on level 8 mk6 16x8 -10 offset. 20190311_163313.jpg
  17. Mar 11, 2019 at 2:54 PM
    #1637
    Tundra$
    Las Vegas
    What size are the tires ?
  18. Mar 11, 2019 at 4:36 PM
    #1638
    Pjholt
    Pjholt New Member
    Pete
    18 CM 5.7
    Man, sorry I can't say for sure. I originally had 35-12.50x17's same measurements as the nittos, they rubbed only in reverse at full lock. Hard to say for sure with the 285-65's. Most reputable tires shops will mount them up for you to try. Sorry, every truck is just a little different. My gut says the narrower tire would be good to go. I am on a 3" coilover lift toytec/eibach w/Zone UCA's
  19. Mar 11, 2019 at 5:54 PM
    #1639
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    looks nice. what lift do you have ?
    dlos[QUOTED] likes this.
  20. Mar 11, 2019 at 6:31 PM
    #1640
    Tundra$
    Las Vegas
    No worries. I’ll get it figured out. I’m just excited to get them on after 6 month wait.
  21. Mar 11, 2019 at 7:26 PM
    #1641
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    My contribution to the cause...
    Nitto ridge grappler 35x11.50r20
    Black rhino pismo wheels 20x9.5 +6 offset
  22. Mar 11, 2019 at 7:43 PM
    #1642
    mgm16trdpro
    Northern NJ
    Thank you. Yeah I'm gonna say you cant fit anymore tire in there on 3 inches upfront and still have full suspension travel. I love the look.
  23. Mar 11, 2019 at 8:15 PM
    #1643
    Tundra$
    Las Vegas
    Looks pretty much what I expect mine to come out like. What did you have to do to fit them?
  24. Mar 11, 2019 at 9:28 PM
    #1644
    SoCalTundy
    It has a 3 inch lift. Some minor trimming to the front inside of the wheel well and removal of the mud flaps was required. No metal trimming needed which is what I was really trying to avoid.
    ManoTundra and Tundra$[QUOTED] like this.
  25. Mar 12, 2019 at 9:32 AM
    #1645
    dlos
    dlos Truckin'
    Mods Mods Mods....
    I have a Toyota installed Ready Lift 3/2 lift, the wheels are Fuel Sledge 18x9 +1 offset, tires are Nitto Ridge Graps 285/65r18. Definitely could have gone bigger on the tires, next time....
  26. Mar 12, 2019 at 9:57 AM
    #1646
    dlos
    dlos Truckin'
    Mods Mods Mods....
    Nitto Ridge Grapplers - 285/65r18
  27. Mar 12, 2019 at 9:59 AM
    #1647
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    3/2 or a 4/2 READYLIFT?
  28. Mar 12, 2019 at 10:02 AM
    #1648
    dlos
    dlos Truckin'
    Mods Mods Mods....
    3/2 -
    3"F / 2"R SST LIFT KIT - TOYOTA TUNDRA TRD / SR5 / ROCK WARRIOR 2007-2019
  29. Mar 12, 2019 at 11:53 AM
    #1649
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Thanks !!!!!!
  30. Mar 12, 2019 at 1:47 PM
    #1650
    crossroads95
    crossroads95 New Member
    Louisiana
    White 2019 CM 1794 4x4
    What are the specs on the tires? Great looking setup. I'm running a white 1794 and want to do the same...
