Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Feb 15, 2019 at 6:55 PM
    #1561
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Those dont look like a -12, if they are you will rub bad with 35's
  2. Feb 15, 2019 at 7:14 PM
    #1562
    76on40s
    76on40s New Member
    Angelo
    2014 Tundra Xsp-x
    My info was wrong. They only make a +30 for a tundra in the phantom so that must be correct.
  3. Feb 16, 2019 at 8:36 PM
    #1563
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    Fuel Sledge 20x10 -18mm
    Ironman All Country M/T 35x12.5x20
  4. Feb 17, 2019 at 12:19 AM
    #1564
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    Niche Scuderia 5:
    22*9.5 @ +40mm
    285/45R-22
    Before :
    After:
  5. Feb 17, 2019 at 4:29 AM
    #1565
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  6. Feb 18, 2019 at 1:55 PM
    #1566
    niscur38
    niscur38 New Member
    Finally got the lift done and the wheels/tires mounted.
    2019
    35x11.5/20 Nitto TG G2
    FBG Coils @3" and 2" Rear Block
    SPC UCA's
    Anthem Defender gloss black 20X9 +18
    Rubbed immediately on the front/rear mudflaps leaving the dealer. Drivers side front mud flap and fender liner already destroyed in 16 miles to get home. Removed the front/rear flaps and trimmed/tucked the front liner. There's clearance now on both sides front and rear with no rubbing at lock in forward/reverse but its damn close.
    Civicsi099, onetohunt and mgm16trdpro like this.
  7. Feb 20, 2019 at 4:15 AM
    #1567
    JBsTundra
    JBsTundra New Member
    2019 Leveled with 20x9
    leveled 2.25 20x9 wheel 295/60/20
    What do you guys think about this 20x9 with a +1 offset. I’m trying to decide if they stick out too much. I'm running 295/60/20.xtbgRefRRZORt3AkWF8RTw.jpg b8z%Q9zbSTu4O+ZmwbAAbw.jpg
  8. Feb 20, 2019 at 4:46 AM
    #1568
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    From those 2 pictures I don’t think it looks bad. I like it
  9. Feb 20, 2019 at 7:02 AM
    #1569
    kevin9763
    kevin9763 New Member
    Kevin
    North Carolina
    2018 tundra platinum
    Borla exhaust, k&n cai,
    Looks good! Any rubbing?
  10. Feb 20, 2019 at 7:08 AM
    #1570
    JBsTundra
    No rubbing, The place that did the level trimmed some plastic.
    TundrA145 and kevin9763 like this.
  11. Feb 20, 2019 at 5:00 PM
    #1571
    kevin9763
    Kevin
    North Carolina
    Looks great. What lift and what size tires?
  12. Feb 20, 2019 at 5:19 PM
    #1572
    11CMGray
    11CMGray New Member
    I'm trying to narrow down between a few Method race wheels. From what I've read at the beginning of this thread with size and lug patterns. Can someone just confirm if this is the 5x150 is the correct set up for a 10' tundra. I'm ordering the bilstein 5100 so once I figure these wheels out it just finding a tire size.
  13. Feb 20, 2019 at 5:20 PM
    #1573
    Baldmonkey22
    Quartz Hill, Ca
    Yes 5x150 is what you need.
    11CMGray[QUOTED] likes this.
  14. Feb 20, 2019 at 5:21 PM
    #1574
    JBsTundra
    just a front level 2.25 inches. rear is stock. the tires are 295/60/20. the rims are 20x9 offset is +1. I didn't want them to stick out that far but it looks like Im stuck with them for now.
  15. Feb 20, 2019 at 6:24 PM
    #1575
    Baldmonkey22
    Quartz Hill, Ca
    Look at mine above, i have the same tires but a +18
  16. Feb 21, 2019 at 8:02 AM
    #1576
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Question.
    Currently I have stock Toyota wheels ( 17 x 7.5; 15MM OFFSET; 5 DOUBLE SPOKE; 6 STUD/LUG; 5.5 BOLT PATTERN; SPARKLE SILVER FULL FACE)
    I have the 5100's on the top notch. My Tires are 275/70/17. I am close to the upper control arm now. I only rub at full lock in reverse once in a while.
    I attached a pic.
    I am wondering if these will fit? I was going to use the same tires just swap out the rims
    https://www.amazon.com/Method-Race-...ZVDXV3BVZ8A&psc=1&refRID=DRGTFH6P3ZVDXV3BVZ8A
    They are 17X8.5 the backspacing says 4.75
    Will this work? the same as my current wheel? will it stick out more or less?
    Ive been trying to figure this out and be 100% sure before I order them.
    Id hate to buy rims that wont fit.
    Thank you, for the help guys
    silverstreak16 likes this.
  17. Feb 21, 2019 at 8:42 AM
    #1577
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    The more negative offset, for example 0 in your wheel of choice will get u further away from uca. However, if u rub in reverse at full lock now, with more negative offset u will probably rub more. It might not be drastic though if ur current wheel has +15 offset. I can't say for certain if it will work or not. My guess is they will. U might want to ask method, or distributor. Even better, find someone running same specs methods on your gen.
  18. Feb 21, 2019 at 8:53 AM
    #1578
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    The only place I rub is the UCA at full lock.
    I have never rubbed the frame or the cab mount.
    I'll try contacting Method.
    mgm16trdpro[QUOTED] likes this.
  19. Feb 21, 2019 at 9:04 AM
    #1579
    mgm16trdpro
    Northern NJ
    Oh ok, then the more negative offset should help u get further away from the uca rubbing.
  20. Feb 21, 2019 at 9:18 AM
    #1580
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Sweet.
    I contacted Method to see what they say as well.
    If these wheels work out they should look great on my truck.
    I was going to try to photo shop it to see how they would look. But can't do it from my crappy phone.
    Thank you for your input,it's greatly appreciated
  21. Feb 21, 2019 at 9:55 AM
    #1581
    mgm16trdpro
    Northern NJ
    No problem Jerry. Just fyi theres also a wheel simulator on 1 of the wheel distributor sites, where u can see ur truck, color and all, with wheels on it. Think maybe its tire rack wheel simulator. If not, them, it is out there. Just don't remember exactly which site.
    Jerry311SD[QUOTED] likes this.
  22. Feb 21, 2019 at 1:23 PM
    #1582
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Got a Reply from Method Wheels
    Method Race Wheels - Info
    12:53 PM (28 minutes ago)
    to me
    Hi,
    The wheels you are looking to purchase will fit and stick out a little more with the 0 offset. However your tires will rub and you would have to trim your fender wells for clearance.
    Thank you,
    Method Race Wheels Customer Service
    Method Race Wheels | Tensor Tires
    p:866.779.8604
    e: info@methodracewheels.com
    a:15500 Cornet Ave. Santa Fe Springs, CA 90670
    w:methodracewheels.com | tensortire.com
  23. Feb 21, 2019 at 2:09 PM
    #1583
    mgm16trdpro
    Northern NJ
    See almost seems like I know what I'm talking about. Lol
    TundrA145 and Jerry311SD[QUOTED] like this.
  24. Feb 21, 2019 at 2:09 PM
    #1584
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Any way to tell how much more they would stick out ?
  25. Feb 21, 2019 at 2:10 PM
    #1585
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    LOL
    I know how dare I second guess you.
    Now what are the winning lotto numbers please lol
  26. Feb 21, 2019 at 2:12 PM
    #1586
    mgm16trdpro
    Northern NJ
    There is a conversion of inches from offset. However off hand I do not know it. I'm sure you can find by looking around. Or perhaps a fellow member can help.
  27. Feb 22, 2019 at 3:40 PM
    #1587
    Jebell4747
    Jebell4747 New Member
    2018 Tundra TSS
    Not a good pic. 2018 crewmax, 3.5” rough country lift ( with 1/2” toytec spacers to compensate for winch/bumper ) 20x9 Ultra wheels with +25mm offset, with 35 x 12.50 x 20 toyo mt’s.
  28. Feb 25, 2019 at 6:53 AM
    #1588
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    2013 CrewMax 4x4. 6112s up front on top setting, Built Right UCA, 5100s in the rear, 285/75/18 Toyo AT2......stock wheels for now.
  29. Feb 26, 2019 at 1:30 PM
    #1589
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Looking for some recommendations. I want to get new tires and wheels, but keep my truck at stock height ('16 SR5 TSS Crewmax). What offset could I get to push my tires out a little bit and what is the biggest tire I could go, without having to worry about it hitting anything and trimming? Want to get an 18" wheel. I also have the pocketed fender flares, so I'd like to get as close to even with them as I could.
    Anyone else done this without a lift?
  30. Feb 26, 2019 at 3:10 PM
    #1590
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    I've seen a couple. +18 is the norm without any rubbing with the stock 275/65's.
