Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jan 25, 2019 at 8:11 AM
    #1531
    Jhicksmedic
    Jhicksmedic New Member
    James
    2011 SR5 Tundra 4X4 5.7
    I have 275/70/18 KO2's on +18 offset and mine don't rub at all. I'm stock height I don't even have a leveling kit on yet. All I did was take the mud flaps off the front. Wonder why mine don't rub.
  2. Jan 25, 2019 at 8:22 AM
    #1532
    jlind
    jlind New Member
    2016 Tundra Limited CM
    I have no clue. It could be slight differences in the tire or possibly where the tires meet the well without the lift. IDK.
  3. Jan 25, 2019 at 9:01 AM
    #1533
    Marty McFly
    Morty McBoonJug
    Just take that as a win LOL let’s see pics of your set up :thumbsup:
  4. Jan 25, 2019 at 9:02 AM
    #1534
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    2019 MGM TRD Offroad
    TBD
    These arrived yesterday, install scheduled for Monday morning. 285/70R17 KO2s, 17x8.5 Icon Rebounds.
    lionix, equin, Degausser and 4 others like this.
  5. Jan 25, 2019 at 9:03 AM
    #1535
    Marty McFly
    Morty McBoonJug
    Very nice! Post some pics once you get em on :thumbsup:
  6. Jan 25, 2019 at 9:08 AM
    #1536
    Marty McFly
    Morty McBoonJug
    Stock TRD PRO suspension (2016 - pre Fox) 285/70/R18 Toyo OC MTs method mesh 306. I did rub on the front plastic, had to push and trim.
  7. Jan 25, 2019 at 9:19 AM
    #1537
    Jhicksmedic
    James
  8. Jan 28, 2019 at 10:24 AM
    #1538
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    TBD
    Fresh from the installer, 285/70R17 KO2s, 17x8.5 Icon Rebounds.
    Before / After
    +25 offset lines up perfectly with the factory fenders
  9. Jan 28, 2019 at 11:11 AM
    #1539
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Looks good. How much do you want for your factory wheels?
  10. Jan 28, 2019 at 5:21 PM
    #1540
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    TBD
    A few better pics and initial review...
    The 17 inch combo has done exactly what I was hoping. The extra sidewall provides more of a cushion, making for a better ride. It's not mushy, it just soaks up the bumps and holes better. It has also tamed down the tendency of the Tundra to be "jumpy" in the rear over high speed bumps. Oh, it also happens to look awesome...
    The tires are load range C, which was another reason I wanted 17s, you can't get KO2s in a C rating for any 18 inch size tire that's close to a fit for stock suspension. I'm currently running 38 lbs in the front and 36 in the rear. I'll probably play with the pressures a bit, but they seem good for now.
    From a noise perspective, they may be just slightly louder than the michelin ltx A/T2 car tires that came on it from the factory. There certainly is no loud whine or drone like you get from some of the rougher A/T treads I've had in the past.
    On the wheel side of things, the Icons look sharp, and the +25mm offset is absolutely perfect. The rears sit perfectly level with the fenders, and the fronts stick out just ever so slightly, you can see just a bit of the outside-most tread block.
    So to summarize, I couldn't be happier with this setup. And now to the pics. Please overlook the muddy wheel wells, I got it packed up a little yesterday on an excursion through a wet field. I didn't get a chance to spray they out until after dark tonight.
  11. Jan 28, 2019 at 6:11 PM
    #1541
    easleycrawler
    Travis
    This has definitely peaked my interest in 17's instead of getting some trd Offroad wheels. Do you have any rubbing at all and have you noticed any mpg loss?
  12. Jan 28, 2019 at 6:27 PM
    #1542
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    TBD
    No rubbing at all, though I removed the front flaps prior to the installation, partially because from what others have posted I thought they might rub, but mostly because they look stupid and serve no purpose I can discern. But definitely nowhere near cab mounts, fender liners, or anything like that. Keep in mind, these tires are only about a half inch larger than factory.
  13. Jan 28, 2019 at 6:54 PM
    #1543
    easleycrawler
    Travis
    Yeah, I'm running 285/55r20's now, I did the comparison chart on Tacoma world and the 285/70 is just a smidge taller than what I'm running now. Plus, I've been thinking about doing a 1/2" coach builder shims on each side. Does that size BFG ko2's have white letters on the other side?
  14. Jan 28, 2019 at 6:59 PM
    #1544
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    TBD
    The ones I got do not have a white letter side. But it seems like BFG has a lot of different model numbers in the same size and same load rating, so they might have one that does have white letters.
  15. Jan 28, 2019 at 7:10 PM
    #1545
    easleycrawler
    Travis
    I just checked, load range c does not have white letters, but load range E does. About $16 more per tire for the E's.
  16. Jan 28, 2019 at 8:19 PM
    #1546
    ClintsTundra
    ClintsTundra Member
    Clint
    VA
    TBD
    That sounds about right for an E. If you really want white letters, E rated BFGs will do you right. I ran them on my last couple trucks and they were fine.
  17. Jan 28, 2019 at 8:52 PM
    #1547
    easleycrawler
    Travis
    I'm running them now. I won't run nothing but BFG'S. My wife's Tahoe has them, my oldest son's Tacoma has them.
  18. Jan 29, 2019 at 9:18 PM
    #1548
    Firemagoo
    Firemagoo New Member
    2016 CrewMax Magnetic Gray
    416C2728-281C-42E2-9333-83D0A009375D.jpg FBA6B4DC-A985-4A04-8D88-EC170254857E.jpg Finally. After a delay in parts and my indecision. 6112 up front on highest setting, 5100 on rear. Falken Wildpeak a/t3w 295/60r20 on fuel vapor d560. A little skid plate trim and heat mild on inner front fender and here we go into the abyss of forever mods!!! Road noise:none. Ride characteristics:better. Toytec shackles next to level/slight rake. And then full blackout.416C2728-281C-42E2-9333-83D0A009375D.jpg
  19. Feb 1, 2019 at 11:47 PM
    #1549
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Icon Stg 2 w/icon UCA
    XD Hoss 2 20x9 +18
    295/60/20 Ridge Grappler
    Removed all 4 flaps and need to mod liner or shim
    Update: Bumper shimmed 1/2" and pushed liner forward and redrilled 1 small hole to hold it, no more rubbing.
    bumper.
  20. Feb 2, 2019 at 12:32 AM
    #1550
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    What deavers do you have ?
  21. Feb 3, 2019 at 8:56 AM
    #1551
    Jakestundra89
    Jakestundra89 New Member
    Jake
    2017 stock for now
    Working on it
    F85D9138-AEA3-41DA-B0D4-E13EBE34B88C.jpg 71BD401F-526E-4D57-A73F-AE87691B55EF.jpg A9C03251-DDBF-4BCB-A41F-23968211B698.jpg DF451021-13D0-4D90-A5DB-7857354B4631.jpg
    My set up 20s on 33X20X12.5 0 offset King coilovers in front king shocks in rear with icon add a leaf pac
  22. Feb 4, 2019 at 6:45 PM
    #1552
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    295/70R18 Cooper Stt Pro with Camburg leveling kits. 65B5F09E-CB70-418C-BC40-6F7978071FDB.jpg42F5D10E-2127-4AA4-983E-C42B49CAAC1F.jpg0C17D12F-9040-4E21-BB5B-EAB33CC6A136.jpg
    superdenk, JPB_VT, chuck416 and 19 others like this.
  23. Feb 8, 2019 at 5:38 PM
    #1553
    gravity
    gravity New Member
    Maryland
    2016 Sequoia Platinum
    2016 sequoia platinum
    Stock suspension
    Fuel sledge 20x9 +20 offset
    Falken at3w 305x55x20
    Slight rub at full lock
    In front, removed front mud flap. Took inner mudflap off and heated with a torch and re-molded it.
    Now there is no rub. Drove the side up on a curb and tested. No rubbing.
    silverstreak16, equin and mgm16trdpro like this.
  24. Feb 9, 2019 at 12:35 PM
    #1554
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Stupid question. If the hub size changed by half mm in 2014, does that mean the gen 3 wheels are not true hub centric on gen 2 models?
  25. Feb 9, 2019 at 2:17 PM
    #1555
    kevin9763
    kevin9763 New Member
    Kevin
    North Carolina
    2018 tundra platinum
    Borla exhaust, k&n cai,
    Nice build. What lift are you running? What size tires?
    chuck416 likes this.
  26. Feb 9, 2019 at 2:51 PM
    #1556
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Beautiful Sequoia! Loved my 2004. Love the wheels too.
    gravity[QUOTED] likes this.
  27. Feb 9, 2019 at 4:34 PM
    #1557
    gravity
    gravity New Member
    Maryland
    Now i just need to finish blacking it out and get some tint
    Snowcat4360[QUOTED] likes this.
  28. Feb 14, 2019 at 6:45 AM
    #1558
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Here's my setup:
    FN BFD wheels - 0 offset wrapped with Toyo Open Country AT2 295/70/18.
    TRD Pro Stock Suspension / Adjustable Shackles - highest setting.
  29. Feb 14, 2019 at 9:47 PM
    #1559
    stevechumo
    stevechumo New Member
    Mine is 05 with 4x4. The tires are 275/70/17.
    Jbickel, equin and mgm16trdpro like this.
  30. Feb 15, 2019 at 6:26 PM
    #1560
    76on40s
    76on40s New Member
    Angelo
    2014 Tundra Xsp-x
    I’m new to this forum and I have a wheel tire setup question. I have a 2014 Tundra with the Xsp-x package. It has Ultra racing 20x9 wheels with +30 offset and 285/55/20 BFG A/Ts. I have added Billstein 5100s on the highest setting in the front to level it. I want to put a set of Nitto Ridge Grapplers on it. Anyone running this setup? I was thinking 35/12.5/20. Will it fit?
    onetohunt likes this.
