Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Oct 14, 2018 at 6:40 AM
    #1381
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    Yes, I installed an rcd 6 inch suspension with.icon extended coil overs made for this lift. Also got camburg upper control arms, 4 inch body lift. Replaced all new front end parts at same time of lift install
  2. Oct 16, 2018 at 3:25 PM
    #1382
    jacklduffy
    jacklduffy New Member
    Jack
    05 Tundra Limited Crewcab Phantom Gray 4x4
    K&N air filter, Flowmaster
    Hoping people still look at this thread from time to time, I have an 05 Double Cab, recently purchased a 2.5/1 leveling kit and I would like to run the 285/70R17 tires. But my question is, I don’t quite have the funds for wheels just yet, so will I rub with my factory wheels?
    Secondly, if I go against my better judgment and get spacers, how much will they affect?
  3. Oct 17, 2018 at 4:42 PM
    #1383
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Enkei Commander
    18x8.5
    25 offset
    275/70-18
  4. Oct 17, 2018 at 6:21 PM
    #1384
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    So 295 60 20 were too big?
    Too much tire?
  5. Oct 17, 2018 at 6:34 PM
    #1385
    DalTee
    DalTee New Member
    Dal
    That’s a great look
  6. Oct 18, 2018 at 8:42 PM
    #1386
    bozly
    bozly New Member
    Stealth Custom Series Ray10 18'' with 295/70/18
  7. Oct 22, 2018 at 9:33 AM
    #1387
    Big E
    Big E New Member
    Eric
    Ohio
    '08 Slate CrewMax TRD
    3/1 Leveling, Bushwacker Flares, 20x9 Fuel Kranks
    Hi everyone. Long time Tundra owner (9 years now), first time posting. I know I need to post up some pics of my current ride, and I promise I will :-}. Currently running some Fuel Krank wheels on my '08 Crewmax, which I love dearly. Been in deliberation about trading it in for a '18 Limited. Looking at the OP on this thread, it looks like despite having the same bolt pattern, the hubs on the new one would have a .5mm larger center than the '08 hubs. So I guess I'm wondering if I can use the existing Fuel wheels on the new one (if I trade), and if so, I'm assuming I would need to have them milled out another .5mm. Sorry if this is a dumb question, but I'm sure everyone knows the cost of aftermarket wheels and tires
  8. Oct 22, 2018 at 6:27 PM
    #1388
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Sweet looking ride! Did you LineX your front grill?
  9. Oct 22, 2018 at 7:07 PM
    #1389
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    You have a lift? How much trimming did you have to do?
  10. Oct 22, 2018 at 7:46 PM
    #1390
    trd4life
    trd4life New Member
    2015 Black Limited CC 4x4 5.7
    2” lift 285/65/20 Nitto Terra Grapplers
    2” Trailmaster leveling kit
    Stock 20” Limited wheels
    Trimmed the skidplate
    Barely rubs the sway bar at full lock
    Removed front bumper flaps.....doesn’t rub anywhere else
    Have about 1/2” of clearance on the UCAs......never had any concern about it
    silverstreak16 and My14Tundrs like this.
  11. Oct 24, 2018 at 4:35 AM
    #1391
    Robw777
    Robw777 New Member
    Robert
    2010 Toyota tundra
    4" tuff country lift, carrier bearing drop, aries pro 3" bull bar, method double standard 17" wheels, 35x12.5 nitto Terra grappler g2.
    Hey guys. 2010 tundra. 4" tuff country lift.
    17" method double standard wheels. 0 offset. 35x12.5 nitto Terra grappler g2.
    Tiny bit of rubbing on bumper liner. I just took it out until I have more time to take the heat gun to it. But no rubbing on the longer mounting points.
    On an incline nose up, at full lock I get the smallest tiny bit of rub on the cab mount. On level ground it looks like I've got about 1/16 clearance at full lock.
    I think a solid whack with a big hammer would take care of it without having to do cmc.
    silverstreak16 likes this.
  12. Oct 24, 2018 at 8:48 AM
    #1392
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    Here’s a pretty good shot showing the poke of this particular wheel and tire setup. Details in sig
    My14Tundrs likes this.
  13. Oct 25, 2018 at 6:28 AM
    #1393
    Teflondon100
    Teflondon100 New Member
    2018 Tundra TRD Limited
    I’m running 285x70x18 on factory TRD wheels. No rubbing. Had to remove the small mud flap attached to the bumper.
    I have lifted to front 2 inches.
    I am now running spacers and barley rub the mud flag on passenger side in reverse at hard lock. And I mean barely...
    Pillslinger and equin like this.
  14. Oct 25, 2018 at 8:55 AM
    #1394
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    I thought of going with that size if I had stayed with 18" wheels. I'm running 285/75/17s, which are roughly the same size, and about 2" of lift as well. I noticed jacklduffy says his is an ' 05, though, so I don't know the fitment limitations on the 1st gen Tundras.
  15. Oct 25, 2018 at 1:33 PM
    #1395
    jones83
    jones83 New Member
    2016 Blue Tundra CrewMax 4x4
    For those with the 5.7L and 295/70/18 on stock TRD wheels; are you feeling the loss of power from the added weight of the tires? Do you wish you had went with 285s instead? I got to pick tires with black friday in a few weeks and I am miserable over these two choices.
    *side note* I have a 2016 4x4 CM with JBA UCA installed and 6112 @ 1.9" setting.
  16. Oct 26, 2018 at 3:37 PM
    #1396
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I have the same truck with 18 inch TRD wheels running the same shocks at 1.9 front. Went with 275 70 18’s pre lift with no issues. The truck runs fine but my mileage dropped about 10%. 19 to 17 HW and similar around town. These tires were significantly heavier 10 ply. I have not noticed a power difference, but physics would say otherwise, because work is work. I can’t speak to your size. The 5.7 is still pretty nasty with power when you want it. These just cost more to run but they are pretty to look at
  17. Oct 28, 2018 at 8:06 PM
    #1397
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Can you post pics?
  18. Oct 28, 2018 at 8:54 PM
    #1398
    bozly
    bozly New Member
    OME 2.5'' coil lift in front, and OME rear shocks with Toytec shackles. I had to remove both front mud flaps. I also pushed the front fender liner forward a bit but it wasn't actually necessary.
  19. Nov 1, 2018 at 10:20 AM
    #1399
    Fish2eat88
    Fish2eat88 New Member
    Jay
    2018 silver sky double cab
    295/75 3/2 lift
    Was the spacers necessary to clear the 35x12 from contact? Thinking of this route
  20. Nov 1, 2018 at 11:13 AM
    #1400
    hypa
    hypa New Member
    I wish I could hang with some of the setups on here, but I guess I'm doing okay.
    2018 TRD Pro Bilstein 6112/5100 combo, and 1.25" Spidertrax spacers. Stock wheels with 275/70/18 BFG KO2 rubber. It's too bad that I undertire'd the truck with the small rubber. In hindsite, I should have gone 285 or even 295.
    Still, not a bad transition since April 1st when I bought the truck.
    Week 1.
    This morning.
  21. Nov 5, 2018 at 6:34 AM
    #1401
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    SCS Ray10 18s with 295/70/18 Ridge Grapplers
    IMG_05112018_093141_(1333_x_1000_pixel).jpg IMG_05112018_093150_(1333_x_1000_pixel).jpg
  22. Nov 5, 2018 at 6:44 AM
    #1402
    3mxdivr
    3mxdivr New Member
    NorCal
    2018 Limited Crewmax TRD Off Road
    Suspension setup please?...... looks awesome!
  23. Nov 5, 2018 at 6:47 AM
    #1403
    Degausser
    Kevin
    GA
    2024 LR SR5
    Thanks! It's the Toytec/Eibach 3" coilovers with 1.5" shackles in the back.
    OBXTundra likes this.
  24. Nov 5, 2018 at 4:36 PM
    #1404
    Uturn09
    Uturn09 New Member
    Roscoe
    2017 Grey Tundra SR5 TRD
    None to day....that’s why I’m here.
    What setting are the 6112’s on?
  25. Nov 7, 2018 at 4:32 PM
    #1405
    Poplar Grove TRD
    Poplar Grove TRD New Member
    20x9 Dropstars +18
    275/55/20 Nitto Terra Grapplers
    FA118492-FF4E-4A58-BDCF-7D27562E82D8.jpg C66020E7-CFFF-4AC3-91EA-31F18ED1D4CA.jpg
    Bluechord04 and easleycrawler like this.
  26. Nov 7, 2018 at 5:15 PM
    #1406
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Looks to be stock suspension, do they rub anywhere?
  27. Nov 7, 2018 at 5:30 PM
    #1407
    Poplar Grove TRD
    Stock suspension and no rubbing. When these tires need to be replaced I’m probably going to do 33’s and a 3&1” lift.
    easleycrawler[QUOTED] likes this.
  28. Nov 10, 2018 at 8:38 PM
    #1408
    Storm
    Storm Elite Member
    2018 TRD SPT
    Which Method Wheels are these?
  29. Nov 11, 2018 at 2:04 PM
    #1409
    RZRrider112
    RZRrider112 New Member
    Lance
    Waynesville NC
    2018 Blazing blue pearl crewmax limited tundra/2003 White Tundra SR5
    2.5 inch leveling kit, 285/70-17 Nitto Terra Grapplers
    Just came home with yesterday a 2018 Tundra CM blazing blue pearl Limited. Got a great deal on a 3 inch toytec lift rolled into the price of the truck which I will have installed this week and before I even signed papers for the truck yesterday I ordered a set of rims and tires. The wifey is paying for it to get tinted next month for Christmas. And so the fun and money dumping begins!
  30. Nov 13, 2018 at 9:46 AM
    #1410
    Toyo_project909
    Toyo_project909 New Member
    Highland,CA
    2018 SW Tundra SR5 CM
    18x9 +12 Vision Wheel
    285-65-18 Cooper stt pro tires
    Stock suspension with Rough Country 3/1.5 level kit
