Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Sep 28, 2017 at 11:18 PM
    #931
    Perfected
    Perfected New Member
    2004 Toyota Tundra Double Cab V8 4WD
  2. Sep 29, 2017 at 11:45 AM
    #932
    voodoo
    voodoo New Member
    Vinny
    2013 2wd blue tundra crewmax
    3and level kit, magnaflow dual , bully bar, liner, soft cover
    truck.jpg truck.jpg truck 2.jpg ok after 32 pages i think im more lost now then ever. forgive me. So here goes: 2013 crew base with 3and1 level. I have 275/70/18 falkens that need to be replaced and didn't really like them. Cant change rims right now so 18/9 cheapies from discount.
    I want a wider look with same hight(at least close). I will be adding fender flares so I want them to stick out slightly past flares.
    What I need help with
    getting right size i can get that gets me a more aggressive look and is wider then my 33.2 x 10.8 tires. I want to switch to a M/T look but not hard core.
    Please help so i dont buy the wrong tires. I would like to avoid spacers if possible and keep the rims
    blue16 likes this.
  3. Sep 29, 2017 at 5:35 PM
    #933
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    I hate to break this to you, but unfortunately your width, or "aggressive look" comes from your wheel offset more-so than your tire size.
    Also for the pages' reference as well as yours, below is my truck with Bilstein 5100's top setting front, stock rear. Cooper ST Maxx 275/70-18 on Method "The Standard" 18x9 +18 offset.
    If you're going to add fender flares and want them to stick out slightly past the flares with 275/70's, you're likely going to need a fairly negative offset, which will induce more rubbing against your bumper/fender when turning.
  4. Sep 29, 2017 at 5:56 PM
    #934
    voodoo
    voodoo New Member
    Vinny
    I like your look. I don't need to keep that tire size. I was more so asking what size do I need to buy to get the look I want on a .2wd? Or are you saying the rimsi have will never work no matter what size I get
  5. Sep 29, 2017 at 6:00 PM
    #935
    BeachyTundra
    Brandon
    Spokane
    If you're looking for the tires sticking out past the side of the truck, that is more dependent on wheel offset/backspacing. You can use your current wheels if you want, but then you would need to use spacers in order to get your tires to stick out.
  6. Sep 29, 2017 at 6:35 PM
    #936
    voodoo
    voodoo New Member
    Vinny
    Sorry I'm not up on this. So your saying even if I bought say a 295/65/18 because of the rims I have they won't stick out any further
  7. Sep 29, 2017 at 6:44 PM
    #937
    BeachyTundra
    Brandon
    Spokane
    They will indeed stick out a little farther, but I doubt it's as much as you're thinking. I'm not 100% on how the tire size effects it, I'm guessing if you went from an 11" wide tire, to a 13" wide tire, your tire would stick out an additional inch on the outside if you were lucky, but unfortunately I'm not positive it works like that. Somebody else will have to weigh in on that.
  8. Sep 30, 2017 at 6:29 AM
    #938
    jim65wagon
    jim65wagon New Member
    2003 Tundra SR5 4x4
    Donahoe coilovers, Deaver 3 leaf AAL, 285/75/16 Cooper ST Maxx, OBA, custom bed rack, Skid Row skidplates,
    You should be gtg. That's the same wheel I have ( mine are gloss black) and the same size tire......
    Perfected[QUOTED] likes this.
  9. Sep 30, 2017 at 10:55 PM
    #939
    Perfected
  10. Oct 2, 2017 at 11:29 AM
    #940
    Perfected
    Hey again man. Was there an issue with the wheels being lug centric rather than hub centric when you went to put em on your truck?
    Edit: Hub centric rings are the solution.
  11. Oct 3, 2017 at 9:56 PM
    #941
    Grubblife18
    Grubblife18 New Member
    2014 tundra limited
    6" readylift, rock star wheels on 33's and much more.
    Havoc h103 20’s with Nitto Trail Grappler 33/12.50. 5604037C-2183-435E-B36B-655E495B519D.jpg6F9A5C92-45DA-44F6-A0DF-621D63741974.jpg C12C08B7-2D13-4F63-81D6-6A35756EC530.jpg
    robcast52465, DalTee, xando and 4 others like this.
  12. Oct 3, 2017 at 9:58 PM
    #942
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    How far do they stick out????
  13. Oct 3, 2017 at 10:03 PM
    #943
    Grubblife18
    2014 tundra limited
    They probably stick out about 3-4 inches. Gives it a mean stance. DFA0C45A-AEDC-418B-92B7-65FA685CE3BE.jpg
  14. Oct 3, 2017 at 10:04 PM
    #944
    4x4_Angel
    Bree
    Funky Town, Texas
    Nice! I like it!
  15. Oct 3, 2017 at 10:06 PM
    #945
    Grubblife18
    2014 tundra limited
    Thanks just put em on today. Took off Rock Stars 2’s. 8FC406D3-7B23-40E6-92B8-5BAC31907A8C.jpg
    DalTee and 4x4_Angel like this.
  16. Oct 3, 2017 at 10:14 PM
    #946
    4x4_Angel
    Bree
    Funky Town, Texas
    One day I'll have the $$$$ fit wheels, ties and a lift
  17. Oct 3, 2017 at 10:22 PM
    #947
    xando
    xando New Member
    Oregon
    Tundra TRD OFF ROAD 2015 crewmax/ silver metallic
    Selling?
  18. Oct 4, 2017 at 3:40 AM
    #948
    Grubblife18
    2014 tundra limited
    Yes I am. Asking $1800. Not really sure about how to ship them out to somewhere. That would be my only problem.
  19. Oct 4, 2017 at 4:25 AM
    #949
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    I've used Fastenal before. Pretty reasonable, you just have to put them on a pallet.
  20. Oct 4, 2017 at 9:39 PM
    #950
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The first number is the width of the tire in mm. Going from 275 to 295 will give you a 20mm wider tire but only half of that goes to the outside of the wheel. So your tire will stick out 10mm more. Less than half an inch. Won’t be enough for flares. You’ll either need new wheels with a lower offset or spacers.
    4x4_Angel likes this.
  21. Oct 7, 2017 at 2:36 AM
    #951
    Grubblife18
    2014 tundra limited
    Sorry @xando i sold them here locally.
  22. Oct 7, 2017 at 3:26 AM
    #952
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    That looks really nice
  23. Oct 7, 2017 at 3:29 AM
    #953
    Perfected
    Well I got the new tires and wheels on. Looks amazing IMO. Not too big, not too aggressive, wheels aren't 'brodozer'y.
    What do you guy suggest for PSI? The guys at the shop set them at 35, but I think I might do something like 40, 42, or 44?
    Thanks in advance.
    285 / 75 / 16 btw.
    silverstreak16 and Newm like this.
  24. Oct 7, 2017 at 3:30 AM
    #954
    DalTee
    DalTee New Member
    Dal
    That's a great look
    Grubblife18[QUOTED] likes this.
  25. Oct 7, 2017 at 3:32 AM
    #955
    DalTee
    DalTee New Member
    Dal
    Nice color on the truck
    New word - brodozery lol that's funny
  26. Oct 7, 2017 at 3:33 AM
    #956
    DalTee
    DalTee New Member
    Dal
    That a great looking ride
    Crews44[QUOTED] likes this.
  27. Oct 7, 2017 at 7:34 AM
    #957
    Grubblife18
    2014 tundra limited
    Thanks. I love my ride.
  28. Oct 9, 2017 at 4:28 PM
    #958
    delta6b
    delta6b New Member
    2016 limited TRD 4x4
    Backflip Tonneau Cover Bilstein 5160/6112 Fuel Maverick 20x9 +20 Offset Toyo Open Country RT 305x55 R20 Pop & Lock Tailgate Lock Husky X-Act Contour Mats TRD 4x4 Off Road replacement Husky Logo Center Console Safe AJT Design Key Fob ESP Rear Seat Storage FRAC V2 Oh Shit Handle
    Anybody running a Fuel Maverick 20x9 with a toyo Rough Country RT 33x12.5 +20 offset or close to that on a 3rd Gen? That’s what I’m looking to buy but not 100% sure on the offset. I have a 2016 limited n it’s currently stock height but I did order some Bilstein, 6112 for the front and 5160 for the rear! Thanx for any help you guys can give!
  29. Oct 9, 2017 at 9:31 PM
    #959
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Just have a noob wheel question....at the beginning of this thread the center bore on a gen 3 is 110.5mm......looking at fuels website the center bore on most wheels is 110.3.....how are they fitting correctly? Getting ready to buy rims online and just want to make sure I get the right ones.....
  30. Oct 9, 2017 at 10:58 PM
    #960
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    It fits
