Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jul 13, 2017 at 4:36 PM
    #841
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Are you asking how can you tell if your Tundra has a big brake kit? You will know when you pull off your wheel. Not trying to insult your intelligence, just making sure I'm understanding
  2. Jul 13, 2017 at 4:40 PM
    #842
    Creek
    Creek New Member
    Southern California Coast
    2017 Tundra SR5 Double Cab 4x4 w/ Sr5 Upgrade Package.
    none so far
    No worries about insulting me..;-) I have not taken the front tires off the truck. I had the bigger rotors on my 2000 limited but yes It seems like it would be on the window sticker if they were installed.. Reason for the question is, the owner of these rims said that they were made to accommodate the bigger TRD brakes..
    rons23 likes this.
  3. Jul 13, 2017 at 4:45 PM
    #843
    rons23
    Ron
    Kill Devil Hills
    Agreed. What year is your Tundra
  4. Jul 13, 2017 at 4:46 PM
    #844
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There's a big brake kit on 3rd gens?
  5. Jul 13, 2017 at 4:51 PM
    #845
    Creek
    Creek New Member
    none so far
    2017 SR5 dbl cab 4x4 I have to tool up here.. sold my jack and stands after a move.. back in the house now time to upgrade.
  6. Jul 13, 2017 at 4:52 PM
    #846
    rons23
    Ron
    Kill Devil Hills
    Really Joon. Is it the Trd big brake kit, because that kit is pricey.
    Black Wolf, joonbug[QUOTED] and Creek like this.
  7. Jul 13, 2017 at 5:11 PM
    #847
    Creek
    Creek New Member
    none so far
    I guess the Power assist 4 wheel disk brakes is enough for the tow package.. but the TRD upgrade would be nice.. owell back to tires and rims..;-)
  8. Jul 13, 2017 at 5:14 PM
    #848
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Oh, you're asking if a big brake upgrade would fit in those wheels? Not if your truck came with a big brake kit. Gotcha.
    rons23 likes this.
  9. Jul 13, 2017 at 5:17 PM
    #849
    rons23
    Ron
    Kill Devil Hills
    Yes definitely if your towing a lot. Brembo makes a kit too. I guess when it comes to stopping power while towing your camper, big boat, etc then money shouldn't be a problem.
  10. Jul 13, 2017 at 9:10 PM
    #850
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    Big brake kit should have drilled rotors
    Creek[QUOTED] likes this.
  11. Jul 15, 2017 at 12:27 PM
    #851
    Creek
    Creek New Member
    none so far
    Thanks Puud.. I looked at the TRD big brake kit last night.. looks like one of those items that fall pretty low on the list.. I am concerned about the Hub diameter of these wheels.. reading on another forum right now.. pays to do some research..;-/
    Puud likes this.
  12. Jul 18, 2017 at 9:42 AM
    #852
    kin3156
    kin3156 New Member
    2020 Limited Crewmax 4x4
    Can someone please help me, I'm trying to find out what the largest size tire and rim I can put on my 2017 1794, without all the trimming other than the small flap in front and the mudguards. I am having the pocket style flares installed on it and would like an aggressive stance but not outside the flares. My math skills suuuck! I'm wanting to install the BF ko's with some black rims. Thanks in advance
  13. Jul 18, 2017 at 10:31 AM
    #853
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    3" lift with 285/70/18 Nitto Exo Grapplers on 18x9 +18 offset Raceline Shift wheels. Had to push the front wheel liner forward and adjust the front mud flaps.
    silverstreak16, Hsteven916 and phm14 like this.
  14. Jul 18, 2017 at 11:23 AM
    #854
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Are you looking for a stock height application or lifted?
  15. Jul 18, 2017 at 1:52 PM
    #855
    da_jeep_luva
    da_jeep_luva New Member
    Paul
    2017 CM and 2008 RCSB
    TRD Pro suspension, powder coated bumpers, wheels, tires, lowered, coated, list keeps going.
    275 65 20
    +25 offset
    Slight rub when backing up.
    17 drop to 14mpg
  16. Jul 18, 2017 at 8:10 PM
    #856
    kin3156
    kin3156 New Member
    I'm looking to do a 3/1 leveling kit.
  17. Jul 18, 2017 at 8:29 PM
    #857
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Well you could most likely fit up to a 35 or a 305/70-18 if you have the right rim. @matluth has 295/70-18 STT Pros on +12's and his tires are even or slightly outside with his flares. The rim width and offset is what matters in determining how far it'll stick out.
    Black Wolf likes this.
  18. Jul 19, 2017 at 5:34 AM
    #858
    Definitely correct. The tread edge is flush with my flares. The sidewalls stick out further. Maybe a 1/2".
    zcarpenter92[QUOTED] likes this.
  19. Jul 19, 2017 at 6:39 AM
    #859
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Exactly how they're supposed to look with flares IMO.
  20. Jul 19, 2017 at 6:41 AM
    #860
    kin3156
    kin3156 New Member
  21. Jul 19, 2017 at 6:44 AM
    #861
    9" and I'm using Stampede flares made by Bushwhacker. Stampedes aren't as wide as the Bushwhackers.
    Patriot likes this.
  22. Jul 19, 2017 at 6:51 AM
    #862
    kin3156
    kin3156 New Member
    Thanks, I'm new to the Tundras. Is there much difference between a 1st or 2nd Gen tundra compared to the newest ones as far as wheel well clearances?
    zcarpenter92 likes this.
  23. Jul 19, 2017 at 8:17 AM
    #863
    zcarpenter92
    Zach
    NE Colorado
    In sig
    There looks to be quite a bit of difference between 1st and 2nd gen, with 2nd gen being quite a bit bigger. I've yet to see someone on here running much bigger than a 285/70-17 on a 1st gen, whereas 295/70-18 is pretty common on 2nd and 3rd gens. I think the 3rd gen is slightly larger than the 2nd.
  24. Jul 20, 2017 at 9:15 PM
    #864
    danielclever
    danielclever New Member
    daniel
    2017 Crewmax SR5 w/TRD package
    I just bought (like I have a 1000 miles on it) 2017 Tundra sr5 crewmax w/trd package. This is my first Toyota pickup and i'm trying to figure out what size tires i can fit on the stock rims/suspension. It came with 275/65R18's after reading through the posts i was wondering can i fit 295/70R18's? if not would 285/70R18 fit? i'm looking to avoid leveling/lift kits if possible {well for now anyways :) Btw my "other" car is a 2015 Focus ST and focusst.org is not nearly as helpful/patient as you guys!
  25. Jul 20, 2017 at 9:21 PM
    #865
    zcarpenter92
    Zach
    NE Colorado
    In sig
    You won't be able to fit either size without a lift/level. 275/70-18 or 285/65-18 will fit on stock suspension, but that's it. You'll need a 3/1 to fit 295/70's, and I think you'd need at least Bilstein 5100's on the 1.9" or 2.28" setting to fit 285/70's. And I'm inclined to think you'd need spacers or different wheels to fit 285/70's even on 5100's, and you'd definitely need either for 295/70's with a 3/1.
  26. Jul 20, 2017 at 9:37 PM
    #866
    danielclever
    daniel
    Ok, wow Toyota didn't leave a lot of room in there. was hoping a little trimming might fit the 285/70's but i defer to yall's experience. maybe i ought to leave well enough alone till i'm ready to lift it.
  27. Jul 20, 2017 at 9:41 PM
    #867
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Not much with stock suspension at least. I guess the better way to put that in regards to the 285/70's is that I've never seen a stock Tundra with them, almost all I've seen running that size on here have at least 5100's.
    And I feel ya, if I'd of known better I'd of had my dealer put LT 275/70's on when I bought it. They look less puny IMO than the P275/65's.
  28. Jul 20, 2017 at 9:43 PM
    #868
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I had 285/70 on stock wheels. They fit with a little room to spare with 2.5" lift. It might work with 2", but less or none and you would be doing some trimming.
  29. Jul 21, 2017 at 1:37 PM
    #869
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Thursday I will be putting on the Pro Comp Nitro 3/1 leveling kit. I decided to go with 295/70r18. The overall tire size is roughly 34.5" I have the Magnum bumper on the front so don't think rubbing will be an issue there. Anything you guys suggest I look at before the install? Btw I got +18 offset on the rims
    Hsteven916 likes this.
  30. Jul 25, 2017 at 5:06 PM
    #870
    JMB
    JMB I buy Nickelback albums at Target.
    Chesapeake, VA
    2013 Super White Tundra DC
    I've got 295-70-18 on the stock steel rims (18X8). No issues, but I have 5100's on the top setting and 1.25 spacers. Without both there will be issues, at least on a 2nd gen.
