Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Apr 11, 2017 at 7:18 AM
    #751
    thekorymiller
    thekorymiller New Member
    Kory
    2019 Tundra SR5 Cement 5.7 V8
    OFFSET HELP!
    I just bought some K02's 275/60r20 with new Fuel Maverick's 20x9 (+35mm) I also got some flares, I want a flush look, how "big" of a spacer should I buy to get the flush look with pocket style fenders? I'm currently on stock height and dont want to trim, I am open to installing a toytec 3/1 if needed.
    HELP!
  2. May 5, 2017 at 1:33 PM
    #752
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    So with all this information in mind... I have a question and sorry if its been answered in this thread already... So many pages was hard to skim through it all... I have a TRD Pro which sits 1'' higher than normal to my understanding. So would I be under the category of 1.5'' lift?
  3. May 5, 2017 at 3:53 PM
    #753
    rayngraphics
    rayngraphics New Member
    2006 Phantom Gray Tundra Limited
    Bilstein 5100, Flowmaster 2-Chamber Exhaust, Alpine INE-W940, 16" SSR Auswuch III, LT265/75R16 BFG All-Terrain KO2's, PIAA Ion Crystal fog lamp bulbs, Opt7 LED headlamp bulbs.
    16x7.5" SSR Auswuch III, +30 offset. BFG LT265/75R16 AT KO2. Spidertrax 1.25" Spacers. Bilstein 5100's at lowest setting.
    Will eventually rebuild these wheels to proper 16x8" specs, and go with larger 285/75-16s, but for now, it is what it is.
    MDHinSD likes this.
  4. May 5, 2017 at 4:01 PM
    #754
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    A TRD Pro is 2" higher in the front and same on the rear as a non Pro.
    niru316[QUOTED] likes this.
  5. May 5, 2017 at 7:35 PM
    #755
    niru316
    niru316 New Member
    Bleh! So does that mean I need to raise the back end 2'' to use the above sire sizes?
  6. May 5, 2017 at 7:55 PM
    #756
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Mama rollin!
  7. May 5, 2017 at 8:17 PM
    #757
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    No, the back has no relevance to max tire size. There's a lot of space back there. It's the front that has rubbing issues. What size were you thinking?
  8. May 5, 2017 at 8:24 PM
    #758
    niru316
    niru316 New Member
    I'm not sure exactly yet... From what your saying on my stock trd pro on stock 18" wheels I can do 295/65 r18? Front and back without having to lift anything? Just some trimming in the front? Sorry this is all new to me... I really appreciate the help!
  9. May 5, 2017 at 8:30 PM
    #759
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    On stock Pro wheels? You'll be really close to your UCA's, but it should fit with some trimming. I've seen a few Pros get 295/70/18 in there with no problems.
  10. May 5, 2017 at 8:32 PM
    #760
    niru316
    niru316 New Member
    So if I do that and do a wheel spacer that would get me away from the uca? 295/79/18 would sound good to me also lol
  11. May 5, 2017 at 8:32 PM
    #761
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
  12. May 5, 2017 at 8:39 PM
    #762
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    The good thing about Pro wheels is that they're +60 offset. They're tucked in and have a lot less rubbing issues. But they don't stick out much and don't give the aggressive stance many are looking for. Also, the tire gets close to the UCA's. If you do happen to hit the UCA, yes you can use a spacer, but that'll create a little more rubbing. It's a trade off. The further you go out, the higher chance you'll need a CMC. But I think you'll be fine without spacers.
  13. May 5, 2017 at 8:46 PM
    #763
    Puud
    Puud Graveyarder
    Nebraska
    2017 Crewmax
    I agree with Joon. But if you throw a 1.25 spacer on there, I think you would be around a +28 offset which would probably not require any kind of hardcore trimming.
    Jsena, niru316 and joonbug like this.
  14. May 5, 2017 at 8:58 PM
    #764
    Voyagermike
    Voyagermike New Member
    California
  15. May 7, 2017 at 6:16 AM
    #765
    sweatnblood
    sweatnblood New Member
    Tony
    2008 Tundra 2wd SR5/ TRD
    6" Pro Comp lift, 35x12.50's on 20's
    So torn right now...hell of a good deal with 20% off, but I really want a "0" offset rather than a "25"...decisions decisions
  16. May 7, 2017 at 7:10 AM
    #766
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Several Pro owners have run 295/70/18 stock wheels no suspension mods. You should be fine, but they looked stuffed.
    Wheel spacers aren't necessary. Wheels spacers will make you rub using the aforementioned tires/wheels.
    Darth Tundra and niru316[QUOTED] like this.
  17. May 7, 2017 at 8:37 AM
    #767
    niru316
    niru316 New Member
    Mmm need to look this up... Lol
  18. May 7, 2017 at 9:02 AM
    #768
    Darth Tundra
    Curt
    17 CM TRD Black
    Revtek 2.5 spacer
    295/70/18
    Stock rims
    Trimmed skid plate
    Took of front mudguard
    Note that photo shows factory UCA....PLENTY OF CLEARANCEIMG_1190.jpg IMG_1191.jpg IMG_1192.jpg
  19. May 7, 2017 at 9:07 AM
    #769
    Darth Tundra
    Curt
    17 CM TRD Black
    I apologize for not noting that my truck is not a Pro !!.....Its an SR5...2017
    GNTundra and niru316 like this.
  20. May 7, 2017 at 9:09 AM
    #770
    niru316
    niru316 New Member
    Looks good!
  21. May 7, 2017 at 9:10 AM
    #771
    Darth Tundra
    Curt
    17 CM TRD Black
    And offset rims = ROCK CHIPS DOWN THE SIDE OF YOUR RIG !!!.....But to each their own....everyone has different tastes in regards to wheels and tires :]
    757TUNDRA and niru316 like this.
  22. May 7, 2017 at 9:12 AM
    #772
    Darth Tundra
    Curt
    17 CM TRD Black
    Thanks BRO !!!...I like my set up for reasons stated above...tires sit in just enough as to not destroy the side of my truck with rocks and debris....and my set up doesn't look STUFFED !!
  23. May 7, 2017 at 9:13 AM
    #773
    niru316
    niru316 New Member
    Ya trying to find some pictures of stock trd pros with 295/70/18 to see how stuffed they look lol
  24. May 7, 2017 at 9:14 AM
    #774
    Darth Tundra
    Curt
    17 CM TRD Black
    I am leaning toward plasti-dipping the wheels....seen a few guys do it on here and I LIKEY !!!!
    niru316 likes this.
  25. May 7, 2017 at 9:16 AM
    #775
    Darth Tundra
    Curt
    17 CM TRD Black
    NICE LOOKING TRUCK BY THE WAY !!!
  26. May 7, 2017 at 9:16 AM
    #776
    Voyagermike
    California
  27. May 7, 2017 at 9:19 AM
    #777
    niru316
    niru316 New Member
    Voyagermike[QUOTED] likes this.
  28. May 7, 2017 at 9:22 AM
    #778
    Voyagermike
    California
  29. May 7, 2017 at 9:25 AM
    #779
    niru316
    niru316 New Member
  30. May 7, 2017 at 9:28 AM
    #780
    Voyagermike
    California
    Ordered tires yesterday through discount tire, had them price match Amazons price on the st maxx. They are about $241 a tire right now. The total was just under $1200 before there certificates.
    Patriot and Darth Tundra like this.
