Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Apr 8, 2016 at 12:02 PM
    #541
    BigBlue15
    BigBlue15 New Member
    I went with Bora spacers
  2. Apr 8, 2016 at 12:04 PM
    #542
    Joe C
    Joe C Member
    Michigan
    2015 Toyota Tundra TRD
    Toytec Radflo Coil Overs Boss rear shock with reservoir 20x9 Monster +18 offset 286/65/20 Ridge Grappler Toytec adjustable shackles SPC UCA TRD dual exhaust TRD swaybar
    What size would you recommend. That does'nt rub after installed
  3. Apr 8, 2016 at 1:51 PM
    #543
    BigBlue15
    I am running 1.5" Bora spacers and the tires sit perfectly flush with the fenders. My truck does have the factory fender flares mounted.
  4. Apr 11, 2016 at 8:36 PM
    #544
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Are those rims 18x9? Had any problems with them sitting on a 275?
  5. Apr 11, 2016 at 10:53 PM
    #545
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Spidertrax!!! That's what I run atleast. 1.25" on rock warrior wheels. Puts me at +18.24mm offset overall.
  6. Apr 12, 2016 at 2:27 PM
    #546
    Joe C
    Joe C Member
    Michigan
    Does anyone of you guys has alignment specs for lifted and larger tires?
  7. May 6, 2016 at 6:52 PM
    #547
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Ok boys, after months of checking out this site and a few minor mods. I was able to knock out my first major upgrade:
    New tires/wheels. I used the info from this site to make my decision and I appreciate the effort everyone puts in their threads to share. I decided on Cooper Discoverer STT Pros on Black Method Roost 285/65/18R with 18 mm offset. I think they came out great some minor rub on the flaps but thats an easy fix. Check these out
  8. May 8, 2016 at 7:18 PM
    #548
    Phlonx
    Phlonx New Member
    White 2012 Tundra Limited RWD
    Hey guys, just bought me a '12 tundra limited, loving it so far!
    HAVE to lift it a little and put on the right wheels/tires. I like trucks with a wide stance and a good wheel/tire ratio. Cost is important.
    Here's what I'm thinking:
    -Bilstein 5100's (2.5" front lift/level)
    -KMC XD SERIES XD807 Strike 18x10 -24mm offset
    -Nitto Terra Grappler G2 305/65/18, which are 33.58" x 12.24"
    Does that sound like it will fit? Do you think they'll stick out too far? Will I need to cut any plastic to avoid rubbing?
  9. May 9, 2016 at 9:28 PM
    #549
    BCDave
    BCDave New Member
    British Columbia
    2014 TRD double cab
    2.75/2.25 lift, Firestone airbags, TRD double exhaust and sway bar
    I'm a new member although I've been reading this tread top to bottom in the last few weeks and found it extremely helpful to pick my new tires and rims. So as a payback here's a couple pics of my truck with the new setup, hopefully it can help someone else. Rims are Worx Beast 20x9 with +25 offset, and tires are BFG KO2 305/55/20. Will need to get the heat gun on the front fender liners but I'm really happy how the truck turned out
    ajaxv2000, Uturn09, The Juice and 5 others like this.
  10. May 10, 2016 at 5:00 PM
    #550
    Phlonx
    Phlonx New Member
    Can anyone point me to a pic of a 9" wide wheel with a -24 offset on a leveled Tundra? Having a hard time finding anypics with that aggressive of an offset. Also need to know if the wheel sticking out that far will help avoid rubbing or if I'm dreaming
  11. May 10, 2016 at 5:21 PM
    #551
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Thanks for the pics, Tundra looks awesome, I have that rim as one of my finalists. :cool:
  12. May 11, 2016 at 5:57 PM
    #552
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Those methods are pretty much exactly what I am looking at except in bronze and with cooper ST Maxxs!
  13. May 19, 2016 at 6:58 AM
    #553
    David P
    David P New Member
    David
    Alabama
    2016 Toyota Tundra 4x4 CM Platinum
    BDS 7" lift with Fox coil overs and 2.5s in the rear, CB shackles w/ poly bushings, CB steering kit, CB poly rack bushings, Dakar rear leaf pack w/ CB poly bushings, Bushwacker paint to match fender flares,, Fab Fours premium bumpers font + rear, Fab Fours modular roof rack with lights all around, ARE Z series shell, BDS Traction control bars, Fuel Nutz 2 piece 22x10 wheels, Toyo MT 37X13.5, Spod overhead lighting control unit, Kenwood/JL Audio, Dynamat sound deadening throughout the cab, Morimoto 40" LED light bar hood bulge, Viper remote start alarm, Bully Dog tuner, S+B CAI, Retro'd HID Headlights, Morimoto 2-Stroke LED Fogs, Undercover tool boxes.
    I think I have a disorder as I cannot narrow this down so I need professional help and possibly medication ;)
    Here is what I have - 2016 Tundra Platinum - Black 4x4 CM
    Current set up is this.
    Front - Bilstein 6112s upfront set on the highest setting plus one CB shims on each side for @ 3 inches of total lift
    Light Racing UCAs
    Rear - CB +3 shackles
    The wrench in the deal - I need to stay just slightly below 83 inches for max cab height, say a max of 82.5 inches to get into the garage unless I raise the higher of the door opening. This is where the disorder really takes over. Lol
    Considerations:
    Option 1 - most economical option; front - add another set of CB shims to the front for another 1/2 inch in lift
    Also I would be adding the CB steering kit
    rear - Add a leaf in the rear providing another 1-1 1/8 inch of lift in the rear @ $600-700 investment
    This would essentially give me a total life of 3.5 in the front and @ 3.6 in the rear - Does that sound right?
    Option 2 - Get a 4" system to replace what I have. Estimated to @ $1,200-1,300 minimum
    Factory platinum wheels with BFG KO2s 285 65/20
    Looks good but I'm on the fence when it comes to my next move. I want to get custom wheels and possibly different tires if need be so it seems between these; 18x9 or 20x9 both with either a +18 or +20 offset. I like semi aggressive but the tucked look as well - a double edge sword of sorts. I like the wider tire but how the vertical sides of the wheels and tires look flush-ish and visually add height to the truck. Several things that I like about 20s but I have seen some very good looking truck with 18s and cannot ignore that I read the 18s ride better. I'm not an off roader but would obviously like some utility if needed.
    Among the sea of options, does anyone have suggestions, ideas and or pics. Here are couple of trucks that I like as examples.
    The black one is mine with 1" Bora spacers on it as it's seen there. Those had to go bc I had some issues so this is why I'm at the current cross road with wheels and adding some lift. I'm pretty set on the XD Monsters in chrome bc I had them on a Tacoma previously and loved them.
    White one at night is a 4 inch lift. Red one is pretty much the same set up. The second white one is a 6 inch lift so I'm looking for the in between although I pretty sure that a 4.5 inch lift will get me to 83 inches which might be too close so that's why I'm on the 4 inch.
    Biby likes this.
  14. May 19, 2016 at 3:52 PM
    #554
    csuviper
    Broomfield, CO
    3.5 in the front and @ 3.6 in the rear will leave you ~2" higher in the rear. If you want level you need to be at 3.5" front and ~1.5"-1.75 rear.
    I have heard that add a leafs make the rear too stiff, unless you tow all the time.
    Adding too much top spacers to a shock designed for a certain lift can be bad and cause failure to the shock.
    David P likes this.
  15. May 19, 2016 at 10:38 PM
    #555
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    If yours is that black one posted...I wouldnt change a thing
    David P likes this.
  16. May 20, 2016 at 4:26 AM
    #556
    trialstroy
    trialstroy New Member
    Troy
    2016 Tundra
    Window visors, tint, 3 inch level kit, Fuel wheels, Cooper tires, N Fab nerf bars, TRD Pro grill, blacked out emblems.
    Nice!
  17. Jun 3, 2016 at 11:11 PM
    #557
    Skidmarks
    Skidmarks New Member
    Thanks for all the great advice and pics on this thread. After reading all the posts Im thinking the 5100s up front should be all I need to clear 295-60-20 Toyo OC AT2 with a 20x9 wheel with an +18 offset.
    Do you think Ill have any rubbing?
  18. Jun 3, 2016 at 11:43 PM
    #558
    Crboy2016
    Crboy2016 New Member
    2016 MGM TRD off-road
    Pro comp 3/1 level kit, 18" Fuel Cleavers 20 offset, 305/65/18 BFG AT Ko2. Just had to massage inner front fender liner and remove front mudflaps.
    Biby, r1-superstar, tuna813 and 2 others like this.
  19. Jun 4, 2016 at 2:49 AM
    #559
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    17x9 Rock Warrior Wheels : 37/12.50/17 Toyo Open Country RT Will have a better photo soon. Hope it helps.2BCCA345-E58B-4431-955D-29DE671117D0.jpg8AE9A44E-8795-49AF-84A4-885B78D6CE91.jpg666D48ED-F1CB-44B4-B33D-ABD0A8FE0F18.jpg
    driverdog, T-Rex266 and jim65wagon like this.
  20. Jun 4, 2016 at 6:14 AM
    #560
    BigBlue15
    BBS 20x9 +50mm (but have 1.5" spacer installed)
    Toyo OC A/T2 35x12.5x20
    5100s on top setting
    zcarpenter92 likes this.
  21. Jun 18, 2016 at 3:44 PM
    #561
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Bilstein 5100s at the top setting, 1.25" Spidertrax spacers, Michelin Defenders LT 295/70-R18 on stock steel rims, no rub. I did take the spats off, they would have rubbed. Beer can clearance on the fronts.
  22. Jun 21, 2016 at 2:29 AM
    #562
    Zibo95
    Zibo95 New Member
    Need help! Just gave my wife 2016 1794 edition for bday. She loves the truck but thinks the tires look small and wimpy. I just want to get bigger tires on the rims that came with the truck without mods. Possible? If I need to do something like a leveling kit is this something the dealership can do.
  23. Jun 27, 2016 at 3:16 PM
    #563
    2012RCSB
    2012RCSB New Member
    Ottawa, Ontario Canada
    2012 rcsb and 2016 1794
    52" light bar 22" boss rims w/ 33" toyo m/t 2x10" kicker subs Amp research running boards Custom wrap and graphics Diamond back tonneau cover K&n air intake Magnaflow exhaust
    I have some 305/60/r18 tires on my tundra and it is stock height and it doesn't rub anywhere... And yes the toyota dealership can install a leveling kit. The only thing was that i found that the tires were sticking out a bit too much so I installed bushwacker fender flares.
  24. Jun 29, 2016 at 6:50 PM
    #564
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Anyone think it is possible to run a 37x12.5x17 tire and 0 offset wheels with 3.5-4" of lift, body mount chop and prerunner bumper?
  25. Jul 7, 2016 at 3:01 PM
    #565
    LTD15
    LTD15 New Member
    2015 Limited
    Hi guys, I am new to this forum but have been lurking around here for some time now. I just finished installing a ready lift 3/2 kit for my 15 limited. I have a few questions if you guys can chime in to help out. I am not a mechanic but had the tools to do it at home.
    Will be taking it to get aligned on Sunday.
    1) when i jack up my front at the side frame, the UCA falls so low that it gets past my spring causing a scrape on my spring. Is this normal when doing a 3" spacer lift? I feel like i have to jack it from under the LCA now to not have this issue.
    2) i want to keep my stock 20's but want bigger tires to fill in the wheel wells. I was thinking 275/65/20 (34") or 285/65/20 (34.5"). Does one size benefit another?
    Will i need to trim anything etc. ?
  26. Jul 7, 2016 at 3:14 PM
    #566
    bandit
    bandit New Member
    Duh Tundra
    37's will clear the rear if you don't do any crazy off roading. the front should fit. Don't quote me on the front though. Here's 37's with fiberglass and long travel and we still needed to do a small amount of clearancing.
  27. Jul 18, 2016 at 6:53 AM
    #567
    Yotalifted
    Yotalifted New Member
    2015 crewmax
    i need some help with figuring out this whole back spacing offset thing. I just bought a 7" lift says I can fit 37" tires with a 20" rim but need a back space of 6.25...would a +25 offset be similar to that?
  28. Aug 5, 2016 at 3:53 PM
    #568
    Biggie1309
    Biggie1309 New Member
    2014 1794 edition tundra
    3inch front 2 inch back leveling kit
    New to the forum guys i have a 3/2 leveling kit on my 2014 1794 edition. And i was wondering if i can fit a 20x12 -44 offset wheel. And if so how much trimming. Also what do yall recomment. I really want my tires to stick out
  29. Aug 26, 2016 at 4:23 PM
    #569
    Edh2428
    Edh2428 New Member
    2014 Crewmax
    3/1 Pro Comp leveling kit. 295/70/R18 Toyo Open Country A/T
    I'm running 295/70/R18 Toyo Open Country A/T's with a 3/1 leveling kit on my 2014.
  30. Aug 26, 2016 at 6:52 PM
    #570
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Don't go negative on the wheels. They'll stick out like 4" and turn your Tundra into a bro truck. You can get your tires to stick out with around an 18-25mm offset.
