Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Feb 16, 2016 at 6:44 PM
    #481
    Island woody
    Island woody New Member
    Scott
    2016 crew max 4x4
    Lift kit, Borla exhaust, 35 inch tires
    I run a 6 inch lift with 20x9 and 35 nitto's had to massage the front plastic piece that covers the back of the fog lights but no rubbing, trucks ride like a truck should, not to hard, not to soft it's just right
  2. Feb 25, 2016 at 7:25 PM
    #482
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Not gonna lie man, I absolutely love maroon Tundras! Wish I could've found one when I was looking.
  3. Feb 26, 2016 at 4:25 AM
    #483
    Island woody
    Scott
    2016 crew max 4x4
    Good looking rig
  4. Feb 26, 2016 at 6:33 AM
    #484
    BigGuy31
    BigGuy31 New Member
    2017 tundra trd pro
    I am going to put on a leveling kit they recommend a 305/65. I am looking at getting a 275/70 which both are a 33 just one is only 11 wide instead of 12. what's the biggest tires anyone has put on with a leveling kit without cutting or rubbing
  5. Feb 26, 2016 at 3:56 PM
    #485
    watsonc3
    watsonc3 New Member
    Sumter, SC
    2014 Tundra 1794 Edition 4x4
    6 in Skyjacker Lift 24x12 Rockstar II's LT315/50R24 Nitto Grapplers Gibson Performance Dual Exhaust Fabfours Veangeance Series Front and Rear Custom bumpers Fabfours side steps Fabfours roof rack with 4 pod face plate Fabfours headache bar 10 Rigid Industries 2x2 lights
    24x12 Rockstar II's
    315/50R24 Nitto Terra Grappler's
    ajaxv2000 and xando like this.
  6. Feb 29, 2016 at 6:18 AM
    #486
    DTMCobra
    DTMCobra New Member
    Northern Colorado
    2013 Black Toyota Tundra Crewmax Platinum
    Toytec leveling kit
    So, I recently joined the Tundra family, with the purchase of my 8th different Toyota vehicle that I have owned! I am the proud owner of a Black 2013 Toyota Tundra CrewMax Platinum! I have been doing enough research to make my eyes cross, and brain go numb planning out a series of modifications I want to make to this truck. I have looked through this thread and didn't find what I was specifically looking for. What I have established thus far is...
    - Suspension - 7" BDS suspension lift (with Icon reservoirs, and Icon UCA's)
    - Tires - 37x12.5R20 (or possibly 37x13.5R20) Cooper Discoverer STT Pro tires
    - Wheels (this is where it gets interesting) - Fuel Anza 20x9 with either a 1 offset, or 5 backspace (plus 1.25 Spydertech wheel spacer for a grand total of 6.25 backspace which is identified in the BDS lift info), or 20x9 KMC XD807 Strike wheels 18 offset with 5.71 backspace, and then adding the 1.25 wheel spacer to get up around 7 backspace.
    Hoping someone might be able to share some insight into this. Thank you!
    dannysmith604 likes this.
  7. Feb 29, 2016 at 7:19 PM
    #487
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Everything's looking good, but I would try to go with an offset you don't have to use wheel spacers with. In my opinion, since your wheels and tires will stick out pretty far, the less stress you put on he axels the better. Spacers will put extra stress on the axels.
  8. Mar 1, 2016 at 7:17 AM
    #488
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Your math is wrong. Adding wheel spacers reduces back spacing. 1.25" spacer on a wheel that has 5" back spacing effectively gives you 3.75" BS.
    DTMCobra[QUOTED] likes this.
  9. Mar 1, 2016 at 3:33 PM
    #489
    DTMCobra
    DTMCobra New Member
    Northern Colorado
    Toytec leveling kit
    I had the same thought on the way to work this morning as well. It took a minute to click but I "think" I have this backspacing nonsense figured out. This math has been messing with my brain. What I have concluded is that a backspace of 6.25 is ideal for 37" wheels. A larger backspace measurement actually means that the tire will be coming in closer towards the vehicle, a smaller backspace measurement will push it away from the vehicle. Thanks for pointing out the spacer Jason, I would have missed that! THIS is why I am glad I am planning things well out in advance :bowdown:
  10. Mar 1, 2016 at 3:35 PM
    #490
    DTMCobra
    DTMCobra New Member
    Northern Colorado
    Toytec leveling kit
    Thank you! Also good points to take into consideration. Now I am waivering back and forth between 35's and 37's again...
  11. Mar 1, 2016 at 9:38 PM
    #491
    Jbrady.801
    Jbrady.801 New Member
    2014 tundra
    Tons of great info in here. I thought I could just go get some wheels and tires, lift my truck and have no issues. I was hoping someone with some experience could help me out a little though. I just got my Toytec 3/1 in the mail. I want to run an 18" +18 wheel. Ultimately I want to run 295/70's. First question is, will this offset on the wheel interfere with the body mount for the 295. Or is that an issue mainly with 35's. Second if too many wheel well mods are necessary for the 295 does anyone run 275/70 with this same kit and do they appear more like stock and too small. Again thanks for all the great info and for keeping the thread going.
  12. Mar 2, 2016 at 9:25 AM
    #492
    I run 295/70/18 (for now) with a +18mm offset on the Toytec BOSS 3/1 kit. I also have a CMC. No rubbing issues here
  13. Mar 2, 2016 at 3:32 PM
    #493
    Jbrady.801
    2014 tundra
    Thanks Sean. I think I will also go with the 295's.
  14. Mar 2, 2016 at 3:52 PM
    #494
    2012RCSB
    2012RCSB New Member
    Ottawa, Ontario Canada
    2012 rcsb and 2016 1794
    52" light bar 22" boss rims w/ 33" toyo m/t 2x10" kicker subs Amp research running boards Custom wrap and graphics Diamond back tonneau cover K&n air intake Magnaflow exhaust
    Going to get them installed as soon as winter is over... 33" toyo m/t and 22" custom painted boss rims. image.jpg
    dannysmith604 and NewImprovedRon like this.
  15. Mar 2, 2016 at 8:40 PM
    #495
    PfdHoser
    PfdHoser New Member
    Pueblo, Co
    2013 Tundra, Bone Stock... For Now
    I just wanted to say this thread is awesome. I now know I will be going with 18x9 wheels with either a +12 or +18 offset and 35x12.50x18 BFG KO2 tires. I really like the Fuel Assault wheels but I can't get the offset I want to be flush with the fender flares. My biggest dilemma was what lift to go with. I was between the ToyTec 3/1 or the BDS 4.5. They are the same price if you get the new UCA's with the ToyTec so I think I have decided on the BDS lift. For all of you sharing your expertise on here thank you.
  16. Mar 2, 2016 at 9:15 PM
    #496
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have the Toytec Ultimate lift on for 2 years. No issues. Love it. Gives a good stance and rides well. The Boss are a bit better choice with custom valving for the Tundra. Don't have experience with BDS.
  17. Mar 4, 2016 at 9:41 PM
    #497
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Stock suspension so far. 18x9 +25mm MB 352s with 275/70/18 BFG AT/KO2s. They rub up front when turning in reverse.
    Tundra%20new%20MB%20352s%20and%20BFGs_zp_b410e68b0fdfb5642da0f783cbcff20d58629d91.jpg
    thedonn likes this.
  18. Mar 4, 2016 at 9:44 PM
    #498
    equin
    Ed
    DFW, TX
    Close up of rear:
  19. Mar 4, 2016 at 9:44 PM
    #499
    equin
    Ed
    DFW, TX
    Front:
  20. Mar 5, 2016 at 4:29 AM
    #500
    Island woody
    Scott
    2016 crew max 4x4
    A heat gun will allow you bend front plastic piece in so it won't rub
  21. Mar 5, 2016 at 5:58 AM
    #501
    equin
    Ed
    DFW, TX
    Thanks, Island Woody. I have some 6112s on order. If an extra 2" of lift doesn't fix it, I'll use the heat gun trick.
  22. Mar 5, 2016 at 9:02 AM
    #502
    csuviper
    Broomfield, CO
    Yea I was thinking you should just add the Bilstein 5100s
    equin[QUOTED] likes this.
  23. Mar 6, 2016 at 7:28 AM
    #503
    equin
    Ed
    DFW, TX
    Yes, 5100s are another good option and set at around 2" of front lift should hopefully do the trick. I decided to go with 6112s, though.
  24. Mar 6, 2016 at 7:31 AM
    #504
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    How do you like the 6112, considering them over ultimate lift. Was was the max lift you got? Says 2.5" just curious. Thanks
  25. Mar 6, 2016 at 7:56 AM
    #505
    equin
    Ed
    DFW, TX
    I haven't received them yet, but I'll let you know once I install them. From what I understand, they're rated to provide 2.5" of lift at the top setting, but I plan to put it at the 2nd to top setting for about 2" of lift. Some folks have reported getting 2.75" of lift on the top setting, though. But I don't know if that's before or after they've settled or if maybe 2wd trucks, which are a bit lighter up front, achieve slightly higher ride height.
    rons23 likes this.
  26. Mar 6, 2016 at 8:05 AM
    #506
    rons23
    Ron
    Kill Devil Hills
    You have any plans for the rear, that's what she said, seriously thought about going with the 5160 's like they have on the pro's, but @a 100+ each I will just go with the 5100.
    zcarpenter92 likes this.
  27. Mar 6, 2016 at 8:48 AM
    #507
    equin
    Ed
    DFW, TX
    I also ordered the 5160s from AJUSA at $166 a piece and free shipping, but that was well over a week ago. I've since read on another forum that that vendor is backordered but that Amazon may have them in stock for about $171 a piece. I also got the aluminum billet mounts for the 5160s from autoplicity for $39 or so a piece ($10 shipping for both) after reading how the hose clamp style mounts broke on someone else's.
    For now, I don't plan on lifting the rear. But if I ever do, I may just go with Coachbuilder shackles.
  28. Mar 6, 2016 at 8:53 AM
    #508
    rons23
    Ron
    Kill Devil Hills
    Cool beans, my truck is 2wd smack!, looking for ride quality and the Tundra prerunner look, hahaha. I will be looking for some pics equin. :cool:
  29. Mar 6, 2016 at 8:55 AM
    #509
    tommyboy123
    tommyboy123 New Member
    mark
    okla city
    2012 black v8 crew
    2inch front level lift Weather Tec mat front and back Plastic Dip 20 inch wheels, Magnafow 22 Exhaust.
    5100s all around 1 1/2 up front lift looks great rides smooth as Butta
    rons23 likes this.
  30. Mar 6, 2016 at 12:46 PM
    #510
    csuviper
    Broomfield, CO
    Have you considered the Toytec Boss over the Toytec Ultimate? I like my ultimate a lot but heard very good things about the Boss. Rode in Sean's and it does feel a little smoother.
