Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Oct 10, 2015 at 9:12 PM
    #391
    speal
    speal New Member
    Thanks so much. Dealership says that I can only go with the 275/70/18r. With the spacer do you know if I could go with a 285/70/r18. I just like to have the look of the wheel wells filled up a bit.
  2. Oct 19, 2015 at 8:16 PM
    #392
    Ttprodr
    Ttprodr New Member
    15 CM 4X4 Tundra
    18x9 level 8 Guardian wheels 275/65/18 Coopers ATP Weathertech Mats (black)
    No lift, stock height, level 8 guardian 18x9 ri ms 25mm off set on copper
    Stock height, Rims 18x9 level 8 guardian with 25mm offset wrapped on 275/65/18 coopers ATP tires,no rubbing 20151018_145854.jpg 20151018_145854.jpg2015-10-18 15.07.56.jpg
  3. Oct 20, 2015 at 1:47 AM
    #393
    big rig
    big rig New Member
    2015 tundra crewmax
  4. Oct 20, 2015 at 1:51 AM
    #394
    big rig
    big rig New Member
    2015 tundra crewmax
    2&1 leveling kit
    275/70 R18 BFG ko2
    Offset +30
    Threads about 1/4" outside fender
    Bulge about an inch outside
    pannelld likes this.
  5. Oct 20, 2015 at 1:52 AM
    #395
    big rig
    big rig New Member
    2015 tundra crewmax
  6. Oct 20, 2015 at 1:54 AM
    #396
    big rig
    big rig New Member
    2015 tundra crewmax
    Filled my tire well pretty nice even with a 2" lift.
  7. Oct 27, 2015 at 6:33 AM
    #397
    pretty
    pretty New Member
    Ok I have 2014 Tundra double cab TRD I just bought 17x9 wheel with -6mm offset. I was thinking on going with a 285 or 295/70. Just wondering if i will have any rubbing issues. No lift currently but will be leveled out with bilstein 5100's in the front and coachbuilder shackles in the rear in the near future. Any advice would be great. Might sell the wheels if its too much hassle. Not even sure if the 17's will fit yet but they used to come on the rock warrior models so technically it should work.
  8. Nov 5, 2015 at 5:59 PM
    #398
    N4SIR
    N4SIR New Member
    2016 Tundra Platinum Black
    Dual exhaust, Rivet fender flares, ICON coilovers (adjusted to 3 inches), Fuel Anza wheels, 285/75/r18 Toyo MT's.
    Here is my 2016 Platinum. I installed ICON coilovers and adjusted them to a 3 inch lift. 18x9 Fuel Anza wheels with a 20mm offset. 285/75/r18 Toyo MT's. I had to do a small amount of trimming on the front right due to rubbing when I would hit the slope on the driveway at a decent speed. Once I trimmed a little, no issues at all! Here are some before, during, and after pics.
  9. Nov 5, 2015 at 7:23 PM
    #399
    Stelly
    Stelly New Member
    2016 TRD Pro, Crew Max, Metallic Gray
    TRD Rock Warrior 17" Wheels, BFG Tires 315/70/17 KO2's, 1.25" front spacers, TRD Intake, N-Fab BAJA Pro Bumper, Hella Lights, LED fog bulbs
    285/70R17 on TRD Rock Wheels. Mounted up on a 2016 TRD Pro, 1.25 Spidertrax Spacers up front only
  10. Nov 7, 2015 at 1:45 PM
    #400
    Bp_tundra14
    Bp_tundra14 New Member
    2014 white tundra sr5
    6 inch rough country kit 20x12 metal wheels 33x12.50x20 toyos rt
    6 inch rcx , 20x12 moto wheels on 33x12.50x20 toyo rt
  11. Nov 8, 2015 at 1:58 PM
    #401
    pretty
    pretty New Member
    Will I be able to run a 305/65/17 with a -6mm offset rim and not hit the cab mount or the upper control arm?? I don't mind getting rid of some fender material or skid plate material. Truck is a 2014 sr5 trd double cab.
  12. Nov 8, 2015 at 2:38 PM
    #402
    Hell ya. Nice tube bumper and skid plate. Time to fill the gap with a nice lightbar.
  13. Nov 8, 2015 at 3:50 PM
    #403
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    2nd pic has a light bar on it. :notsure:
  14. Nov 8, 2015 at 4:07 PM
    #404
    Touché. First one didn't.
  15. Nov 8, 2015 at 4:25 PM
    #405
    Virgils12
    I was confused also. Not on first and third pic but on the second.
  16. Nov 11, 2015 at 7:43 AM
    #406
    electro1012
    electro1012 New Member
    chris
    07 tundra reg cab 4x4 TRD
    hello! I just recently bought an 07 tundra reg cab TRD and have some 20x9 +18 wheels. I have a 3 inch lift on the truck. What would be the biggest tire i could run without extreme clearance issues? I wouldn't mind to trim some plastic or something but wouldn't want to get more involved than that. what would be the recommendations?
  17. Nov 12, 2015 at 9:22 AM
    #407
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Will the Grade/SR5 fit a 17 inch wheel? I kinda figure it would since the RW can fit 17's, just want verification.
  18. Nov 12, 2015 at 9:26 AM
    #408
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Depends on the wheel. No, not all 17's fit. Yes, some 17's fit but scrape wheel weights. Yes, some other 17's fit without scraping weights.
    Sefferston[QUOTED] likes this.
  19. Nov 12, 2015 at 9:29 AM
    #409
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Thanks. I'm looking at the Double Standards from Method, or the Fat 5. Just gotta figure out if I want to do 17's or 18's
  20. Nov 12, 2015 at 9:35 AM
    #410
    jberry813
    Lake Tahoe
    Don't know about the fat 5's, but for the methods, do the 18's. The 17's have a pretty wicked backspacing. IIRC like 4.75 (which is a full inch difference than my wheels).
  21. Nov 12, 2015 at 9:43 AM
    #411
    Sefferston
    Seth
    ERMERGERD TOYOTA
    At this point, it's going to be a red version of your truck :anonymous:
  22. Nov 12, 2015 at 9:47 AM
    #412
    jberry813
    Lake Tahoe
    Imitation is the sincerest form of flattery?
    I'm running the Method Standards. I hate cleaning spokes, and you'll have twice as many to clean with the Double Standards. :)
  23. Nov 12, 2015 at 10:00 AM
    #413
    Sefferston
    Seth
    ERMERGERD TOYOTA
    It is, but maybe great minds think alike?
    Cleaning spokes doesn't bother me too much, Not like they are going to have more than brake dust on them for a while anyway
    jberry813[QUOTED] likes this.
  24. Nov 28, 2015 at 3:19 PM
    #414
    XRAY
    XRAY New Member
    2007 Pyrite Tundra Ltd TRD
    Toytec ultimate lift. 3-1 Level Goodyear Wrangler Duratrac 295/65/18 Fuel Beast Wheels
    My 07 with new Goodyear Wrangler Duratracs (295/65r18) and 18x9 Fuel "Beast" with a 1 offset, and FullSizeRender(2).jpg FullSizeRender(3).jpg FullSizeRender(2).jpg FullSizeRender(3).jpg FullSizeRender(4).jpg a Toytec Ultimate Lift (3/1 level kit).FullSizeRender(2).jpg
  25. Dec 1, 2015 at 7:03 AM
    #415
    tommyboy123
    tommyboy123 New Member
    mark
    okla city
    2012 black v8 crew
    2inch front level lift Weather Tec mat front and back Plastic Dip 20 inch wheels, Magnafow 22 Exhaust.
    Sweet lookin ride.
  26. Dec 6, 2015 at 8:46 PM
    #416
    Smdg32
    Smdg32 New Member
    Steven
    2012 Tundra crew max TX edition
    Linex front grille, M1Bumper, 7" BDS Suspension with Fox Shocks, Linex Buschwhacker fender flares(Linex), 295/65/r20 Nitto MT, 20" Raceline Mamba, Trd Cold Air Intake, Weather Tech floor liners, Spyder Ubar smoked headlights & Taillights, Tonno Pro hard bed cover, Recon extended range antenna, Pioneer head unit, Rockford Fosgate Prime speakers, front/back/dash....More to come
    So I ended up going with the 0 offset. And with my 305/55/20 Nittos I had no issue. Just put 295/65/20's on and it looks great. However at full lock and more in reverse I get rubbing. I get it on the a arm and body. A local shop says they do this mod on Tundras a lot because of the Tundras clearance. Any of you guys get the mod? Should I just pony up and get the 6" on it?
  27. Dec 6, 2015 at 8:58 PM
    #417
    jberry813
    Lake Tahoe
    0 offset means nothing unless you include the wheel width. It would help if you say where you are rubbing on the body. And a 6" lift won't fix rubbing the a-arm.
  28. Dec 6, 2015 at 9:14 PM
    #418
    Smdg32
    Smdg32 New Member
    Steven
    Thanks, don't know what I don't know.. The wheels are 20x9. Was told by a shop that 6" would fix but 6" doesn't clear the wheel well altogether so don't see it. Thought maybe a spacer. Or just spend the $150 and have the shop mod it.
  29. Dec 7, 2015 at 7:23 AM
    #419
    tommyboy123
    mark
    okla city
    2012 black v8 crew
    Good lookin tundra
  30. Dec 7, 2015 at 7:25 AM
    #420
    Smdg32
    Smdg32 New Member
    Steven
    thanks man, its getting their. Got to get the suspension done and the rear bumper, and the steps...awh hell i'll never be done. May be divorced due to the $$ i spend but not done.
