Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Aug 27, 2015 at 8:00 AM
    #361
    jchung6287
    jchung6287 New Member
    Haha thanks!!
  2. Sep 5, 2015 at 3:32 PM
    #362
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Stock other than bull bar and steps.
    Looking for the expert answer. I have a stock Tundra TRD Pro. I want to purchase new aggressive tires. I'm wanting to get the biggest I can fit under it now without any mods and on stock rims. I'm going to lift in future but for now just want new tires. Willing to add spacers if needed.
  3. Sep 5, 2015 at 6:45 PM
    #363
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    Just a quick question but why buy the Pro if your going to do a lift or spacers and mess up the Pro's TRD suspension?
    I'm going with 285/65 18's but I know others have done larger but some have an aftermarket front bumper that gives extra room for the larger tire not to rub and room for 295/70 18
  4. Sep 5, 2015 at 7:10 PM
    #364
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Why would I not get the TRD PRO?!? It has a lot more than the 2inch lift to offer. The sticker on my base model '08 I bought new was $39k and this one is $41k. In 7 years they difference is $2k but with all the upgrades it is cheaper.
    Well I'm not sure about lifting until after I see the stance it gets from bigger tires. I may or may not. I want 305/65r18.
    Tundra Toy likes this.
  5. Sep 5, 2015 at 7:22 PM
    #365
    Flobrandx
    Brandon
    2015 TRD PRO
    I'm aware it has more than the 2" lift with TRD springs and Billstein reservoir shocks and it also has the TRD Pro specific interior, the front skid plate, TRD Pro grill and headlights, TRD Pro stamped bed, TRD dual exhaust, and TRD Pro wheels. That's why I bought one but a BIG part of the Pro package is the suspension.
    To each their own...it was only a question
  6. Sep 5, 2015 at 8:43 PM
    #366
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Yeah they are sweet and the ride is great. I had 285s on my '08 with the 3&1 leveling kit. It was about 1" to 2" lower than I wanted but it worked. I just like the looks of a lifted truck. I'm hoping that I can get away with putting 305s on it. If not I'll go with 295 like you stated. I just wish someone could give e a defiante answer.
    Thanks for your info it's a starting point and may be the finishing.
  7. Sep 6, 2015 at 8:57 AM
    #367
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    You can stuff 35's if you are willing to cut some plastic and skid plate.
  8. Sep 6, 2015 at 10:39 AM
    #368
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Have you put done this or seen it done? Does it rub when you hit a hard bump or only where need trimmed?
  9. Sep 7, 2015 at 11:49 AM
    #369
    jberry813
    Lake Tahoe
    Yes I've seen it done. Hell there's a guy that posted in this thread.
    https://www.tundras.com/threads/off...re-setups-pics-and-info.95/page-10#post-31069
    Hitting a bump isn't the problem. It's turning and rubbing skids and plastics. All of which are an easy fix with a BFH and a grinder.
  10. Sep 8, 2015 at 9:25 AM
    #370
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Good deal. I work in the gas field and swinging a 10 lb BFH is an everyday job. Lol. I was hoping a little fabrication was all that would be needed.
    Thanks for the input.
  11. Sep 8, 2015 at 9:49 AM
    #371
    jberry813
    Lake Tahoe
    If you decide to run wheel spacers, you may need to do a little bit of fabrication. My wheels are +18 offset so they are pushed out farther than stock. I was ever so slightly rubbing my cab mount on...."aggressive" turns. You can do a cab mount chop to gain clearance tho:
  12. Sep 9, 2015 at 4:59 PM
    #372
    sigpi11
    sigpi11 New Member
    2015 TUNDRA TRD PRO
    Thanks. I was scoping your pics out and they are awesome.
  13. Sep 11, 2015 at 6:47 PM
    #373
    Smdg32
    Smdg32 New Member
    Steven
    2012 Tundra crew max TX edition
    Linex front grille, M1Bumper, 7" BDS Suspension with Fox Shocks, Linex Buschwhacker fender flares(Linex), 295/65/r20 Nitto MT, 20" Raceline Mamba, Trd Cold Air Intake, Weather Tech floor liners, Spyder Ubar smoked headlights & Taillights, Tonno Pro hard bed cover, Recon extended range antenna, Pioneer head unit, Rockford Fosgate Prime speakers, front/back/dash....More to come
    Hey guys, so I gave been looking at a lot of pics of your trucks and different offsets. My issue is you see my truck below, I have 305/55/r20 on Racelines. I want to go for some matte black wheels and get a more aggressive stance. I know pics are bad but you can see I'm tucked still. Do you guys think that a -12 offset would accomplish this or do I need to go to a -24. I don't want to be way out but enough. Was thinking Jesters 20x9 -12?
    Thanks
  14. Sep 11, 2015 at 7:22 PM
    #374
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Negative offset? That will be very aggressive and you will probably have a lot to trim. A +12 would probably be perfect with your fender flares. Your tires will probably stick out a bit still with that offset.
  15. Sep 11, 2015 at 7:27 PM
    #375
    TruckyTruck
    Gary
    Skinny 35s.... Stock wheel offsets with too wide of a tire may rub your upper control arm.
  16. Sep 11, 2015 at 7:32 PM
    #376
    Smdg32
    Smdg32 New Member
    Steven
    So positive offset would still give me an outside fender wall stance? Had trouble finding rims with negative so that would be better for my wallet. Found a good deal on matte black Racelines with 0+ would you think that's too much with the 305/55's?
  17. Sep 11, 2015 at 7:32 PM
    #377
    TruckyTruck
    Gary
    I just looked at this link. I can't believe those tires didn't rub the uca. There was no way I could have run a 35 before I got different rims.
  18. Sep 11, 2015 at 7:38 PM
    TruckyTruck
    Gary
    Zeros are going to push past the flare and would look good, but you will most likely rub the body mount. Which is fine if you don't mind chopping it.
    Here is a pic of +12 jesters with 305 55s. +10 Or +12 will most likely be perfect.
    DalTee and Smdg32[QUOTED] like this.
  19. Sep 12, 2015 at 7:20 AM
    #379
    Smdg32
    Smdg32 New Member
    Steven
    Sweet this looks perfect. Crazy though looking at custom offset website tundras with -12 & -24 offset don't look that far out but probably just the picture. Glad I didn't order -12 now.
    Thanks again bro
    TruckyTruck[QUOTED] likes this.
  20. Sep 12, 2015 at 8:42 AM
    #380
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Just for another comparison, 20x9 +18 offset 305/55/20. No rubbing or trimming. Anything closer to 0 offset it definitely would. I probably have 1/4 inch max between tire and plastic fender
    Bgilley, rons23 and TruckyTruck like this.
  21. Sep 12, 2015 at 12:32 PM
    #381
    Smdg32
    Smdg32 New Member
    Steven
    Love the setup you have, silly question as I feel I should know this, but being that yours is a 4x4 doesn't affect the natural stance right?
  22. Sep 12, 2015 at 1:18 PM
    #382
    TNTundra08
    Blake
    2008 DC 4x4
    What do you mean by natural stance?
  23. Sep 12, 2015 at 2:46 PM
    #383
    Smdg32
    Smdg32 New Member
    Steven
    I did not know if the setup was wider naturally on a 4x4 but figured it out
  24. Sep 19, 2015 at 11:39 AM
    #384
    Grizzly660
    Grizzly660 21 Army Green Sport
    North Dakota
    2021 Army Green Sport
    20 inch XD Hoss wheels with Nitto EXO Grappler Wetokole seat covers
    20" XD hoss, +38 offset. 275/60r20 BFG Ko2 and 2" leveling.VZM.IMG_20150918_172932.jpg
    KEG89 likes this.
  25. Sep 22, 2015 at 3:50 PM
    #385
    Lstar
    Lstar New Member
    Northwest Montana
    2011 Gray CrewMax Rock Warior
    3" Kore, Toyo Open Country A/T II LT285/75R17 on stock wheels
    What back is the back spacing on the Moto's
  26. Sep 28, 2015 at 8:49 AM
    #386
    Markus51
    Markus51 New Member
    Ok Gang,
    I did a search and not even sure where to look from the results. I'm new to my tundra and I'm trying to keep it somewhat simple (for now ;) ) I'm looking at the XD monster rims with either +35 or +18 offset in an 18" rim. I'm keeping my stock tires for now (275/65/18). I have a 2014 with TRD package. No brake upgrades. I do have fender flares and I'd like to fill them. Will the +18 rims fit without any trimming or is it better to go with the +35?
    Thanks!!!
  27. Sep 28, 2015 at 8:50 AM
    #387
    Markus51
    Markus51 New Member
  28. Sep 28, 2015 at 10:28 AM
    #388
    TruckyTruck
    Gary
    With your flares, +18 is better. It still may not come out even with the flares with stock tires though. Once you get a wider tire it will though.
    With the stock tire, you probably won't have to trim, but depending on the size tire you go with afterwards, there may be trimming involved.
  29. Oct 10, 2015 at 9:00 PM
    #389
    speal
    speal New Member
    Thread is super helpful but I'm new to the options with wheels and tires on pick-ups. I have a 2016 Tundra with the TRD package. I was planning on keeping the stock wheels but putting on 275/70/18r tires on with a leveling kit. If I leave the stock wheels would getting wheel spacers from spidertrax make for a more aggressive stance. They only seem to make them in a 1.25" width. Don't know if it would look good, cause any other issues, etc. Any advice would be great, thanks in advance.
  30. Oct 10, 2015 at 9:06 PM
    #390
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I have 1.25 wheel spacers on mine much better stance. Check out my build thread. Don't go smaller than 1.25 or you will run into issues with the lugs not fitting.
