Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jul 16, 2015 at 5:17 PM
    #331
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    Looks good. My dad bought a wheel very similar to that for his 4th gen 4runner
    tommyboy123 and JGDarcy[QUOTED] like this.
  2. Jul 16, 2015 at 6:05 PM
    #332
    JGDarcy
    JGDarcy New Member
    2015 Tundra Crewmax SR5 4x4
    Another shot of the Enkei ST6.
  3. Jul 16, 2015 at 7:48 PM
    #333
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I actually really like the style of those wheels.
  4. Jul 22, 2015 at 6:39 AM
    #334
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    3/1 lift level, 35" Toyo Trail Grapplers
    2015 Tundra TSS SR5 4x4.
    3" Coil spring spacer in the front, 1" block in the rear.
    Stock TSS wheels.
    Spidertrax 1.25" bolt on wheel spacers.
    295/65/20 Nitto Trail Grappler (35" tire).
    To use this size tire I had to of course modify the skid plate. Along with that I had to remove the front lower fender liner from the bumper. Not just the little flap, the entire liner that covers the back of the bumper. I was still having issues with rubbing the sway bar at full lock. To remedy this i purchased and installed 1.25" Spidertrax bolt on wheel spacers. At that point I had to remove the mudflap from behind the front tire but now there are no rubs, issues or any complaints from me.
  5. Jul 26, 2015 at 4:13 AM
    #335
    Cootdawg
    Cootdawg N2YOTAS
    Tony
    East TN.
    2015 TRD OffRoad Crewmax
    3x2 Readylift, 295x70x18 Nitto Trail Grapplers, TRD Shifter, Black Emblems/Decals, Window and Tail Lights Tinted, Aries Bull Bar with 30inch LED Light Plus 42 inch Led Light behind Bumper, Shorty antenna
    Check out Mickey Thompson Sidebitter 2 wheels (very close to the 4runner trd pro wheels) Hade a set on my 2014 Tacoma and loved them!! traded it yesterday for my 2015 crewmax
    T-Rex266 likes this.
  6. Jul 27, 2015 at 8:21 PM
    #336
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Calling a coilover a strut is like calling a magazine a clip.
    But I digress....
    srad750c, Patriot, Noodle and 2 others like this.
  7. Jul 27, 2015 at 10:37 PM
    #337
    csuviper
    Broomfield, CO
    Lol. I call it a coilover when it is adjustable and better than just bla.
    Just like a 10 round is bla and a 30 round is a magazine
  8. Jul 28, 2015 at 1:13 PM
    #338
    jberry813
    Lake Tahoe
    There are very distinct and key differences. Being adjustable has nothing to do with the definition and usage of a coilover. Just like capacity has nothing to do with a magazine vs clip.
    zcarpenter92 likes this.
  9. Jul 28, 2015 at 1:15 PM
    #339
    csuviper
    Broomfield, CO
    Lol, i know.
  10. Jul 28, 2015 at 1:16 PM
    #340
    csuviper
    Broomfield, CO
  11. Jul 28, 2015 at 1:22 PM
    #341
    csuviper
    Broomfield, CO
    [​IMG] [​IMG]
    Coilover
  12. Jul 28, 2015 at 1:23 PM
    #342
    csuviper
    Broomfield, CO
    @jberry813 What is the technical explanation for the difference between a strut and a coilover?
  13. Jul 28, 2015 at 1:32 PM
    #343
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    I believe in the one above the 'strut' actually takes the place of a uca and therefore most of the spindle/knuckle on a car and supports more than just linear load that the coil over takes in a truck.
    example
    jberry813 likes this.
  14. Jul 28, 2015 at 3:00 PM
    #344
    15max
    15max New Member
    Cole
    15 SR5 TSS 4x
    @Relentless hit it spot on. Struts are engineers to provide vertical and lateral support and be able to rotate. Also known as McPherson Strut. Coilover is literally coil over shock. It's basically a beefed up shock that has mounts capable of supporting the weight of the vehicle with a spring around it providing vertical support only with the control arms providing the lateral support.
    This article is a great read covering all the different type of suspension designs there are:
    http://www.carbibles.com/suspension_bible.html
    jberry813 and Relentless like this.
  15. Jul 28, 2015 at 3:32 PM
    #345
    MCZX2
    MCZX2 New Member
    I haven't read through all the posts so if this has already been answered, my bad.
    I just put on Bilstein shocks and struts with a 2.5 inch lift on the front and 275/60 - 20 tires.
    As far as the wheels go, do they need to be 20x8, 20x8.5 or can they be 20x9?
    I want to keep it as close to OEM as possible with regards to offset and backspacing.
  16. Jul 28, 2015 at 3:59 PM
    #346
    csuviper
    Broomfield, CO
    Look at the specs on the tire you want. It gives a req wheel width range.
  17. Jul 28, 2015 at 4:03 PM
    #347
    csuviper
    Broomfield, CO
  18. Jul 28, 2015 at 5:55 PM
    #348
    jberry813
    Lake Tahoe
    Winner winner chicken dinner!
    A coilover doesn't dictate KPI/SAI. The ball joints on the end of the double a-arms do. You can place the lower mount anywhere on the LCA that fits your needs for the shock ratio you are trying to achieve.
    With a McPherson strut, everything (linear and lateral load) rests on the lower strut mount (and there is no upper a-arm). While this works great for vehicles that have limited travel (namely passenger cars), it doesn't lend itself to moderate (let alone significant) travel numbers or any spirited offroad driven vehicle.
    Coilovers obviously are also used heavily in linked suspensions. But for all intensive purposes, links are the same thing as double a-arm. Trailing arms and upper links are the equivalent to lower/upper control arms.
    Relentless[QUOTED] likes this.
  19. Aug 4, 2015 at 4:49 AM
    #349
    corey_white4
    corey_white4 New Member
    corey
    2015 tundra sr5 double cab
    2015 tundra with 20x10 -24 offset Fuel Mavericks with nitto terra grappler G2 275/60r20, 3inch in front
    Biby, King R 808, ajaxv2000 and 2 others like this.
  20. Aug 4, 2015 at 7:08 AM
    #350
    csuviper
    Broomfield, CO
    @corey_white4 thanks for posting the wheel tire setup here too
  21. Aug 4, 2015 at 8:14 AM
    #351
    csuviper
    Broomfield, CO
    3/1 lift. Goodyear Wrangler Duratrac 315/70R17 Tires. Factory TRD Rock Warrior wheels 17x8 +50mm offset. 1.25" wheel spacers. No Rock Rings
    With Rock Rings
  22. Aug 4, 2015 at 12:55 PM
    #352
    csuviper
    Broomfield, CO
    Updated original post with members setups :bananadance:
  23. Aug 4, 2015 at 1:07 PM
    #353
    That was my last Tundra. @JC303 now has it.
  24. Aug 4, 2015 at 1:20 PM
    #354
    csuviper
    Broomfield, CO
    Why are your replying to messages from May 15, 2014 ?
  25. Aug 4, 2015 at 1:47 PM
    #355
    Because zero fucks.
    Kidding. Idk. I saw it pop up when I scrolled to the bottom. Strange.
  26. Aug 6, 2015 at 6:49 PM
    #356
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Just want to say here, I went out to my truck today and thought my 35s didn't look big anymore. Glad I went with them over the 33s
  27. Aug 26, 2015 at 8:40 PM
    #357
    jchung6287
    jchung6287 New Member
    Toytec boss kit 3"
    20" fuel anza +20
    Toyo open country MT 35 x12.5 x20
    Had to remove front plastic and do body mount chop
  28. Aug 26, 2015 at 9:32 PM
    #358
    How do you like the @ToyTec Lifts BOSS kit?
  29. Aug 27, 2015 at 6:48 AM
    #359
    jchung6287
    I'm not a big off roader. I also have SPC UCAs and everything seems smooth. I am not quite sure what to look for also to truly grade it.
  30. Aug 27, 2015 at 7:51 AM
    #360
    TNTundra08
    Blake
    2008 DC 4x4
    That looks so good, the truck/ wheel color combo is perfect :eek: I like your truck more than mine :rofl:
