Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jan 20, 2025 at 4:43 PM
    #3241
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I recently purchased a new set of wheels from @memario1214 at HotShot Offroad. Colton hooked me up with a set of Fuel Offroad Covert D716 wheels in Gunmetal and Gorilla spline lug nuts in black gloss.
    5 x 150
    20” x 9
    20mm offset
    I had a local shop, Round 2 Offroad, mount my current tires on the wheels, install new TPMS sensors, balance, and a front end alignment. (The front end alignment had been done incorrectly at 2 previous shops. Scott at Round 2 got me fixed up).
    Truck sitting across the street from Round 2, after getting the new wheels on, waiting it's turn with the alignment wizard.
    The tires currently on the truck are Kenda Klever R/T KR601 33x12.5R20.
    Suspension is Eibach Stage 2R’s (adjustable coilovers in front, reservoir shocks in back) and Dirt King Gen2 UCA’s. (Also sourced through @memario1214 at HotShot Offroad). 2” lift in front, nothing lifted in the rear. (That is, from the top of the tire to the fender, the front measured 5” and the rear measured 8”. After replacing the stock shocks and adjusting the front coilovers to 2”, the front measured 7”, and the rear measured 8.5”. The rear shocks were so worn out that I was able to compress them with my hands holding them at arms length in front of me. So the extra .5” in the back may have been just compensating for the sag from the old shocks).
    No rubbing. The front mud flap thingy’s are removed, otherwise it would be much closer. But as of right now, no rubbing.
    My old wheels, which were stock BBS steel 20” wheels that came with the SR5 Texas Edition Tundras at that time, had an offset of 50. The new wheels have a 20 offset, so I have a little over 1” of poke that I didn’t have with the factory wheels (which sat flush to the side line of the truck prior to changing wheels.
    I love the ride, and I love the look.
    I'll get some better shots on a sunny day.
    ATV25 and Gaston like this.
  2. Feb 1, 2025 at 9:31 AM
    #3242
    steve yobs
    steve yobs New Member
    Stock 2021 SR5 except...
    • Canopy: SNUGtop Hi-Liner
    • Tires: Falken Wildpeak AT/4W
      • LT285/70R17
      • As you'd expect, E rated makes for a rough ride without weight. Other than that, no complaints.
      • They've been impressive in the wet, ice and snow for their first winter (~1000 miles).
    • Wheels: Icon Recon SLX, Charcoal
      • 17x8.5, 25mm Offset
    Stock suspension w/ the front plastic splash guards/fender well protector removed fits this set up without rubbing--that's no rubbing at full turn forwards or backwards. The splash guards posterior to the front wheels were only slightly modified. I took the heat gun to em for a little reshaping. Worked a charm as others have described. Hope this helps someone with stock suspension get the right fit and function for their truck.IMG_7692.HEIC.jpg IMG_7802.HEIC.jpg IMG_7798.HEIC.jpg
    Poke: I wasn't sure how I'd feel about the look of the +25mm offset. Turns out I like it. It's far less noticeable than the calculated 2+inch protrusion would suggest. It's difficult to tell in this first picture, but the contact patch is out from the body by an 1 1/4inch at most. As you're approaching the vehicle you can really only see side wall, and its minimal protrusion.
    This picture below is the best representation of how the poke looks in real life.
    Fender Plastics Modification:
    I followed the advice given elsewhere. Take the front plastic off. Reshape the back one. No cutting, just heating and bending.
  3. Feb 1, 2025 at 12:14 PM
    #3243
    bucketlintels02
    bucketlintels02 Newish Member
    NW Georgia
    2021 Tundra TRD-Pro Crew
    RAS Road-Active Suspension System HD. 2" (estimated) Spacer and Block Lift . S&B CAI - closed VLED Footwell lighting MESO Customs Interior Lighting 285/65/18 KO2 Gator Hard Cover Tri-Fold AJT Designs interior trim CSU 9 - year ceramic coating Rigid Amber Fog Covers Full Tint (70% Windshield) 20% all others.
    285/75r18 BFG KO3
    Slight rubbing on the sway bar at full lock.
    Wanting to put wheel spacers but but I would have to cut/reshape the forward trim
  4. Feb 3, 2025 at 11:37 AM
    #3244
    COTundra23
    COTundra23 New Member
    these look great and glad BFG is finally making this size
    I’ve had to run wheel spacers in order to clear this size
    do you think the measure at a true 35” tall?
  5. Feb 4, 2025 at 3:07 AM
    #3245
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    BFG lists them as being 34.8"
    COTundra23[QUOTED] likes this.
  6. Feb 4, 2025 at 12:16 PM
    #3246
    COTundra23
    Yup but am still looking for real life measurements
    my 35x12.5 KO2 are really only 33.5”….
  7. Feb 9, 2025 at 10:56 AM
    #3247
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    2021 Platinum Tundra MGM
    6 window Ceramic tint, TRD Exhaust, TRD front and rear sway bars, TRD BBS wheels, temporary 2" front leveling spacer.
    Is your truck stock? I have a 2021 platinum with a coil spacer leveling kit up front temporarily and I put the TRD BBS wheels on it. Im wanting to run a larger tire but the offset on the TRD wheels seems to limit large tires pretty greatly.
    Tripleconpanna and ATV25 like this.
  8. Feb 9, 2025 at 2:44 PM
    #3248
    bucketlintels02
    NW Georgia
    No, has a 2” spacer front and rear
  9. Feb 9, 2025 at 2:50 PM
    #3249
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    The TRD Pro already rides higher than my truck i believe, but im wanting to do the same sort of set up you've got. Do you happen to know what clearance you have to the UCA? Just trying to figure out if I need to wait on the bigger tires until I get coilovers and UCA's
  10. Feb 12, 2025 at 5:19 PM
    #3250
    Vsolano
    Vsolano New Member
    Vic
    SoDak
    2010 5.7 V8 Tundra Grade
    Wheels & Tires Icon Thrust Satin Black — 17x8.5 25mm Falken Wildpeak AT4W — 35x11.5/17
    Wheels: Icon Thrust 17x8.5 25mm
    Tires: Falken Wildpeak AT4W 35x11.5/17
    All fit with no lift. Only had to do a CMC, pinch weld flatten and removal of the front wheel well liner. (Could also just push the liner with a heat gun).
    No rubbing even in reverse at full lock. That might change if going off road though.
  11. Feb 12, 2025 at 6:22 PM
    #3251
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    Glad you posted this, im hoping to fit the same size tire on 18" wheels on my truck. Truck looks damn good with them too!
    Vsolano[QUOTED] likes this.
  12. Feb 12, 2025 at 6:31 PM
    #3252
    Vsolano
    Vsolano New Member
    Vic
    SoDak
    Thanks. It should clear the UCA with an offset closer to 0. I know most stock tundra wheels come with higher positive offset (around in the 50s). So a 15-30 positive offset would be ideal for clearing bigger tires.
    However, if you rather keep your current stock wheels you can look into running wheel spacers to bring you closer to a 0 offset and give you a better chance at not rubbing on the UCA.
    Badknees likes this.
  13. Feb 18, 2025 at 10:53 AM
    #3253
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Here's my UCA clearance (Clarence) for a 2016 Tundra with TRD Pro suspension, TRD Pro wheels, 295-70 R18 Cooper Tires, and 1" Bora wheel spacers:
    TacomaTRD4x402 likes this.
  14. Feb 18, 2025 at 2:16 PM
    #3254
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    Did you happen to try them without the wheel spacer? And did you have fender liner rub with this setup?
  15. Feb 19, 2025 at 4:33 AM
    #3255
    Badknees
    Badknees New Member
    South Carolina
    Hello,
    Even though I thought it would be OK, I installed the wheel spacers first as I didn't want to take a chance on any rubbing on the UCAs. I like the look/stance with wheel spacers better anyhow. I did have a little fender liner rubbing. I removed the front fender "flap" and used a heat gun and rubber hammer to reshape the front fender well and rear mud flap a bit - easy work. I think others have used fender spacers to eliminate the rubbing. The front sway bar does rub a tiny bit at full lock but not enough to worry about.
    Best of luck.
  16. Feb 22, 2025 at 10:05 PM
    #3256
    Knoxh458
    Knoxh458 New Member
    Knox
    05 Land cruiser
    Needed something new so I went ahead and threw some BBS’s on the 1794
    Setup:
    TRD PRO BBS wheels
    285/75r18 Toyo RT Trail
    3/1 LevelIMG_9456.jpg IMG_9461.jpg
    It scrubs a tiny bit on my sway-bar. My old 35x11.50R20’s did too. It’s no big deal
    Already ordered some Heritage Caps to get rid of the red center caps.
    TacomaTRD4x402, COTundra23 and ATV25 like this.
  17. Feb 23, 2025 at 8:01 AM
    #3257
    COTundra23
    Looks great! And good call…
  18. Feb 23, 2025 at 10:17 AM
    #3258
    CyborgXCZ
    CyborgXCZ New Member
    2014 Black Tundra Limited
    Maybe this will be good place for pictures as well. Finally kick the bucket as my tires were getting bad and I was trying to figured out if I go with new tires or whole setup but I guess whole setup it is it was cheaper in long run and better looking :) besides the old wheels are up for sale so will get some $$ back
    Before
    20x10 -18 Tires 305/50
    Slight Rub on Body Mount at full lock Wheels poking about inch outside of flares.
    After
    17x9 +12 Tires 305/70
    2" Lift, Aftermarket Bumper, Fender Flares
    No rub anywhere and tires are almost even with the flares maybe ever slightly poking out.
    J&ATundra and Ace96 like this.
  19. Mar 10, 2025 at 3:35 PM
    #3259
    JackB8675309
    JackB8675309 New Member
    Nebraska
    2012 Black Tundra Limited
    Center console safe, Tonneau cover, Leveling kit
    Im looking to get a similar if not the same wheel and tire set up. Is there anything you do differently that I should know, I saw you were rocking a slightly lower PSI and maybe no front mud guards? Anyways Im new to this scene and love the way your truck looks, please let me know if anything comes to mind!
    ATV25 likes this.
  20. Mar 19, 2025 at 7:16 PM
    #3260
    NotSpongeWorthy
    NotSpongeWorthy i member
    Ricky
    Valkenvania, PA
    2020 Tundra SR5 TRD Sport Crewmax
    Furry steering wheel cover
    looks awesome. I’m leaning towards thrusts for my new wheels. I just wish they had a higher offset for no poke, but that being said, nobody really does.
  21. Mar 21, 2025 at 9:31 PM
    #3261
    Ksilva130
    Ksilva130 New Member
    2022 Tundra SR5 Off Road
    I’ve been looking at the Black Rhino Chambers 18x9.5 +12 offset on Toyo 265/70R18, what are the chances of this rubbing? Thanks in advance!
  22. Mar 22, 2025 at 10:56 PM
    #3262
    mr_schiz
    mr_schiz New Member
    Caleb
    2020 TRD Sport Double Cab
    Fox 2.5 Resi's, 315/70R17 Toyo MT, Diamondback Switchback Tonneau
    Icon Rebound 17x8.5 5x150 25mm offset wrapped in Toyo MT 315/70/17
    Fox 2.5 Resi All around, Coachbuilder +2 shackles in Rear. BMC, minimal rubbing at full lock (liner, I'm lazy and didn't wanna cut anything)
  23. Mar 28, 2025 at 1:41 PM
    #3263
    textundra12
    textundra12 New Member
  24. Mar 28, 2025 at 2:02 PM
    #3264
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Those look good in silver! I was tempted by the silver when I ordered my BFDs but I couldn’t find any pictures and was worried it may not look right on my silver truck. I went with graphite gunmetallic. upload_2025-3-28_17-1-52.jpg
    Tripleconpanna, ATV25 and atc250r like this.
  25. Mar 28, 2025 at 3:03 PM
    #3265
    textundra12
    Are you running rays center caps? I was thinking of doing that
  26. Mar 28, 2025 at 3:36 PM
    #3266
    Silver17
    Northeast
    I wish, but rays center caps are for 114mm center bore and will not work with these wheels. I made my own knockoff rays caps by modifying some caps for black rhino wheels and getting some rays raised resin decals.
  27. Apr 8, 2025 at 5:14 PM
    #3267
    TRD OR in bronze on a LX570. Look pretty good
    nowayout, Badknees, BlackNBlu and 5 others like this.
  28. Apr 10, 2025 at 5:28 AM
    #3268
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Did you have cab mount rub?
    Badknees[QUOTED] likes this.
  29. Apr 10, 2025 at 11:03 AM
    #3269
    therealjonwick
    JR
    2019 OR
    Any body mount rub?
    Tundra Texan likes this.
  30. Apr 10, 2025 at 5:30 PM
    #3270
    therealjonwick
    JR
    2019 OR
    Really debating going to 295/70 18. Have 6112/5160. Top setting with 2cb shims driver 1 passenger. 3”+ front lift. Cb +3 with 1” spacer rear. Going to get +25 rims. Really don’t want a BMC.
