Official Rave Offroad TRD Pro Marker Light Thread
Discussion in '3rd Gen Tundras (2022+)' started by brucega7x, Aug 27, 2022.
  1. Sep 21, 2022 at 11:27 AM
    #91
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  2. Sep 21, 2022 at 11:35 AM
    #92
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Really? I didn't know that. Don't know what supplier they use but no, I did not plug the vent holes. I was going to rinse off the truck but now it's too hot lol
  3. Sep 21, 2022 at 6:16 PM
    #93
    brucega7x
    brucega7x [OP] New Member
    2022 Tundra SR5 CrewMax 4X4
    There's absolutely zero reason to remove the entire grille lol.
    Literally just loosen the bottom three shutter bolts a bit and remove the top three and you can install these lights with plenty of room to work.
    Yoda_Lance likes this.
  4. Sep 21, 2022 at 7:24 PM
    #94
    eddiefromcali
    Eddie
    100% Stock
    No, but I didn't use the fuse they suggested
  5. Sep 21, 2022 at 7:31 PM
    #95
    eddiefromcali
    Eddie
    100% Stock
    I'll check the specific location but it's in the driver side fuse box.
  6. Sep 21, 2022 at 8:26 PM
    #96
    eddiefromcali
    Eddie
    100% Stock
  7. Sep 22, 2022 at 7:24 AM
    #97
    paradizecityz
    Richmond, TX
    I wouldn't say plenty of room lol but I got it done :)
    Where is the DRL fuse? I wired mine up to a switch so I can turn on and off as I want but I found that it doesn't stay on after I turn off the truck and turn back on. I would have to flip the switch to off and then back on again for the lights to come on so I'm thinking of going directly to DRL and be able to control it with the stalk
  8. Sep 22, 2022 at 7:29 AM
    #98
    paradizecityz
    Richmond, TX
    Is that on the passenger side or driver side?
  9. Sep 27, 2022 at 1:29 PM
    #99
    eddiefromcali
    Eddie
    100% Stock
    Used some rtv and sealed the hole where the wiring harness exits the housing as well as all around the led. After about 2 hours of being submerged underwater, absolutely no water inside the LED housing itself.
  10. Sep 27, 2022 at 1:44 PM
    #100
    eddiefromcali
    Eddie
    100% Stock
    I've gone ahead and sealed the other 2. Once the rtv cures on those, I'm going to ceramic coat the housing. I noticed air bubbles starting to form after a while under water. I'm assuming water was starting to get in and the ceramic should help repell any last bit that might want to permeate through.
    KroppDuster likes this.
  11. Sep 27, 2022 at 1:49 PM
    #101
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Awesomesauce. Thanks for this. I'll pull out some RTV and seal these up tonight so they have time to cure.
    I started my front tear down this weekend and will wrap it up Saturday. Doing the TRD Pro grill, replacing the front chrome stache, a bunch of lighting, my winch install, and my CBI bumper all at once. I don't really want to take the front end off again so I'm doing it all at the same time. lol.
    Dmon187 and eddiefromcali like this.
  12. Sep 30, 2022 at 7:33 AM
    #102
    paradizecityz
    Richmond, TX
    Yeah, their tape isn't the best. I've been driving around with only 2 lights as 1 fell off and was dangling for who knows how long lol. I had some 3M tape at home but it seem pretty thin. Now I need to come up with better solution
  13. Sep 30, 2022 at 10:56 AM
    #103
    brucega7x
    I cleaned my grille with alcohol prior to install and mine have been fine for a month now. And that’s driving down some absolute GARBAGE and bumpy south Louisiana roads daily lol.
    paradizecityz[QUOTED] likes this.
  14. Sep 30, 2022 at 11:12 AM
    #104
    paradizecityz
    Richmond, TX
    I cleaned mine off too so idk. I ended up taking them off. Another one was holding on my a thread or something because I barely touched it and it fell off lol
  15. Sep 30, 2022 at 12:36 PM
    #105
    KroppDuster
    Bilstein 5100s
    Hoping to wrap up my front end work this weekend and install these light this tomorrow. What kind of tape did they use on your lights? Mine is 3m VHB Doublesided tape. That's usually pretty good stuff and I keep a roll of it in my garage for various things.
    Are you guys running into issues with that tape adhering or did they use a cheaper tape on your lights?
  16. Dec 17, 2022 at 7:52 AM
    #106
    LeoYota
    LeoYota New Member
    leonel
    2022 Tundra Limited
    I have a new set from Rave that I won't be using if anyone interested. My front grill it's the the Limited trim I ordered while back the Rave marker lights were backorder and I ordered the front TRD grill which should be at home anytime soon that comes with the marker lights and the light bar.
  17. Dec 17, 2022 at 9:28 AM
    #107
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Did anyone buy the entire Grill Kit from Rave? It looks like a complete set with the grill, light bar, switch and marker lights (that are leaky). I am wondering if the light bar leaks and the grill is a cheap knock off?
  18. Dec 28, 2022 at 7:20 PM
    #108
    charlieyankee88
    charlieyankee88 Taco to Tundra
    22 SR5 TRD OR
    TRD 3" Lift, 18” Vision Manx 2, BFG KO2, Fas-Top
    Installed pro grille and Rave marker lights yesterday. Love them so far. Very easy install and are working fine. I am wondering if there is a way to get them to come on with the other marker lights on the truck. My intent would be to have them turn on similar to the other ones when you lock and unlock doors. Right now they are in an empty fuse slot and turn on when the truck turns on, which is great. I was just thinking it would be cool to get them to just work with the other amber lights. Does anyone know if there is a way
    of doing this without wiring them into those lights? I was thinking maybe there is a fuse or something associated with that. Not an electrition by any means, haha
  19. Feb 2, 2023 at 1:12 PM
    #109
    tony22longBed
    tony22longBed New Member
    tony
    2022 lunar rock long Bed
    Any leaks in those 3 led? did you seal them?
  20. Feb 2, 2023 at 6:30 PM
    #110
    charlieyankee88
    22 SR5 TRD OR
    I did not seal them. Moisture can come in and then evaporate. That is what the drain holes are for according to rave. The leds themselves are for waterproof ipx7, I believe. I am not submerging them, so they should have no issues. For price I am more than happy.
    tony22longBed[QUOTED] likes this.
  21. Feb 2, 2023 at 7:50 PM
    #111
    eddiefromcali
    Eddie
    100% Stock
    Dust won't get out and it'll start accumulating and eventually cause a muddy mess. Won't take much for water to get in, you'll see
  22. Feb 2, 2023 at 7:58 PM
    #112
    charlieyankee88
    22 SR5 TRD OR
    I disagree, but you are entitled to your opinion. I also stated that water does get in and then evaporates. They have been on for over a month. They have seen snow, rain, dirt, and mud and they are clean and still working fine.
    WrapCO likes this.
  23. Feb 10, 2023 at 9:38 PM
    #113
    Jgrunst
    Jgrunst New Member
    2023 Tundra SR5 TRD - Off Road
    Has anyone used their amber/amber lights (everything I’m seeing on here is the clear/amber option). They look brighter and website says they are moisture seal, while the clear/amber have drain holes. They are also cheaper.
    eddiefromcali likes this.
  24. Feb 10, 2023 at 9:40 PM
    #114
    eddiefromcali
    Eddie
    100% Stock
    The amber amber lights are the ones we all got from alibaba or aliexpress..wherever it was. Those will not bolt up to an oem heritage grille. I've had a set for months and are nice and bright, no flickering and look oem. Get those lights but from someone else
  25. Feb 11, 2023 at 6:02 AM
    #115
    Jgrunst
    Jgrunst New Member
    Ahh I see. Thanks.
    anyone ever used the rave off road aftermarket grill? Website says the amber/amber lights bolt on to their aftermarket grill but not oem. Customer service said the aftermarket grill is the same except for the bolt on abilities for their lights and it has a flatter finish where OEM is more satin. Wondering about quality though..
  26. Mar 18, 2023 at 11:17 AM
    #116
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
    Anyone wire these to a spot other than the fuse box? Not excited about poking a hole thru the fuse block. They can’t draw hardly any amps.
  27. Mar 18, 2023 at 2:19 PM
    #117
    eddiefromcali
    Eddie
    100% Stock
    There's a fuse box under the hood, where I tapped into for the markers
  28. Apr 11, 2023 at 5:52 PM
    #118
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    I'm assuming you have the LED, non-premium headlights? Do you recall which wire you tapped for the parking lights? Appreciate your insight!
  29. Apr 11, 2023 at 10:41 PM
    #119
    SC4333
    SC4333 New Member
    Grant
    LED, NON-PREMIUM HEADLIGHTS
    Did some digging around and found the parking light +12vdc parking light wire. I took some pictures that I'll attach below. It was very easy to access once removing the passenger side air-box. The air-box just pops out, but make sure you disconnect the MAF sensor and remove the wiring stay before yanking it out. Pull straight up and the rubber grommets below will let loose. tip: spit on the rubber grommets before putting the air-box back in.
    I've traced the wiring loom we are looking for in blue, and the two other headlight connectors for reference. There is (3) total. The parking light / turning signal connector is very difficult to reach from the engine bay. you'll see in one of the pictures below I was able to access it by partially removing the wheel liner. You will not need to access this connector, I only did so for testing voltage. I was not able to even see this connector(s) from the engine bay FWIW.
    Once the air-box is removed, peel back the electrical tape that the loom is wrapped in so you can isolate the GRAY wire that supplies +12vdc to the parking lights. Either use some wire strippers and solder in your tap w/ 18-22 gauge wire or use a posi-tap. Make sure you have some quality electrical tape on hand to cover up your new tap and close the loom once finished.
    **Note that this circuit is not designed to carry any significant load. I would highly recommend using a this as a relay trigger if used for anything other than a couple small LED lights (fender flair LEDS, grille LED running lights, etc.). Do this at your own risk. If you are not confident with your wiring abilities, it might be best to practice on something else before taking a stab at your brand new truck.
  30. Oct 26, 2023 at 6:24 PM
    #120
    jhuseby
    jhuseby New Member
    Johannes
    2023 Tundra Limited Lunar Rock
    18" Black Rhino Wheels, 35" Toyo Open Country ATIII, King Shocks
    Hi there, I followed what you did and used an add a fuse in that same slot and mine also come on randomly some times even when the truck is off. What fuse is the fuse for when the headlights are on? Many thanks for any extra info you might have.
