Official Rave Offroad TRD Pro Marker Light Thread
Discussion in '3rd Gen Tundras (2022+)' started by brucega7x, Aug 27, 2022.
  1. Sep 7, 2022 at 4:41 PM
    #61
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    That’s just blinker fluid. Completely normal.
    t300 likes this.
  2. Sep 7, 2022 at 8:24 PM
    #62
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    I might order just the housing and find my own LED and install it myself
  3. Sep 8, 2022 at 7:36 AM
    #63
    jmay86
    jmay86 New Member
    Josh
    Columbus, Ohio
    '22 Lunar Rock LTD DC TRD-OR
    ^^THIS^^
    9OH1, iiawah808 and Brums like this.
  4. Sep 11, 2022 at 8:36 AM
    #64
    Dmon187
    Dmon187 New Member
    DFW
    2022 Tundra SR5 TRD OFF ROAD
    18x9 Method 316 wheels, TRD skid plate, Cat plate, Heritage grill with color match front end, TRD suspension OEM Lift kit with Toyo Open country At3
    The lights fit great in the heritage grill. I installed them yesterday but did not actually connect them because of the moisture water issues. I washed my truck this morning and sure enough it had moisture in it. Any of you guys that actually connected it to power have issues? If it is connected will it cause a short of some kind? I wrote a review on the Rave website to see what they come back with. CF18F2C9-77D0-4168-9C01-EEE1D0644409.jpg16CF8A94-1DF8-4467-84EB-34AD39044B39.jpg 16CF8A94-1DF8-4467-84EB-34AD39044B39.jpg
  5. Sep 11, 2022 at 8:50 AM
    #65
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I've been talking to Rave and they tested a light, fully powered dunked inside a glass of water and it was fine. I'm not a fan of seeing condensation inside the housing so I haven't installed it. From what I was told, the lights are water resistant and will operate just fine but again, not a fan of the look. I also asked if removing the housing from the 3d print was an option and was told the light was never intended to be removable.
  6. Sep 11, 2022 at 9:26 AM
    #66
    M11s n B&T’s
    M11s n B&T’s New Member
    2022 Tundra TRD Pro
    over time the leds and board will start to corrode and they will eventually fail. to test for winter have him dunk them in a salt water mix then take them out and let them run a while see how long they go.. only way they would last is if they have a well covered poly marine coating over the entire board.
    eddiefromcali likes this.
  7. Sep 11, 2022 at 9:28 AM
    #67
    eddiefromcali
    Eddie
    100% Stock
    I did ask for salt water test because I go to the beach quite often and salt water condensation would definitely get in there overnight. I'm thinking about adding a bead of silicone around the 3d housing and dunking them in water to see if that stops water intrusion
    Dmon187 likes this.
  8. Sep 11, 2022 at 10:34 AM
    #68
    paradizecityz
    Richmond, TX
    Hopefully there will be more options. YotaLEDs is another but not sure when they will release theirs. They finally released it for the SR5/TRD grill and I was waiting for that for many months before I switched grills
    Yoda_Lance likes this.
  9. Sep 11, 2022 at 11:33 AM
    #69
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Installed mine 2 days ago and went through the car wash yesterday. Low and behold moisture in all 3
  10. Sep 12, 2022 at 7:12 AM
    #70
    paradizecityz
    Richmond, TX
    Geez, I feel like they should pull the product until they can fix this issue. I wouldn't want to buy something brand new and moisture inside of it, even if it "won't hurt" the LEDs....
  11. Sep 18, 2022 at 11:23 AM
    #71
    paradizecityz
    Richmond, TX
    Well, ordered just the housing from Rave Offroad and got my own lights, perfect fit. I’m already pre-wired so ready to go but didn’t see an easy way to install without taking off the front.
    I got some amber marker lights coming in from Alibaba so I guess I’ll just wait to do it all at once
  12. Sep 18, 2022 at 11:28 AM
    #72
    eddiefromcali
    Eddie
    100% Stock
    I'm confused....are you doing the alibaba TRD PRO knock off ambers or the Rave housings?
  13. Sep 18, 2022 at 11:29 AM
    #73
    paradizecityz
    Richmond, TX
    I'm going to have both to choose from. I still can't decide on the amber lens or the blacked out lol
  14. Sep 18, 2022 at 11:33 AM
    #74
    eddiefromcali
    Eddie
    100% Stock
    I have both and can tell you that the Rave leds are way brighter but the grille looks like it's missing the lights from afar when they're not on. I'm in the middle of sealing up the lights to the housing so I can swap in the Rave lights and remove the knockoffs
    paradizecityz likes this.
  15. Sep 18, 2022 at 10:40 PM
    #75
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    What are you using to seal them? I was thinking some sort of clear resin that is UV resistant would be a good option.. Suspect mine will have the same issue most everyone else seems to be having with water intrusion :/
    eddiefromcali[QUOTED] likes this.
  16. Sep 18, 2022 at 10:48 PM
    #76
    eddiefromcali
    Eddie
    100% Stock
    I'm going to try clear silicone on one, black silicone on another. So far I have plugged all 3 housings where the wiring comes out at. I have 1 housing drying with clear silicone and I'm going to dunk it in water tomorrow to see if it's properly sealed. My guess is that they will both equally attract dirt but that the black one will blend in better. This is just to seal the LED against the 3D printed housing. As far as sealing the entire housing, I was thinking some ceramic coating. I have some cquartz leftover and was going to apply a few coats of that.
    SC4333 likes this.
  17. Sep 19, 2022 at 11:25 AM
    #77
    paradizecityz
    Richmond, TX
    Do you have to take the entire front off when installing these lights or did I miss something?
  18. Sep 19, 2022 at 11:31 AM
    #78
    eddiefromcali
    Eddie
    100% Stock
    I would...Instructions say you can do it by loosening the shutters but I'd just take it off..doesn't take long
  19. Sep 19, 2022 at 4:23 PM
    #79
    Dmon187
    Dmon187 New Member
    DFW
    I installed them without removing anything but loosening the shutters
  20. Sep 19, 2022 at 5:18 PM
    #80
    eddiefromcali
    Eddie
    100% Stock
  21. Sep 19, 2022 at 8:38 PM
    #81
    paradizecityz
    Richmond, TX
    Man, how did you do that!?! I loosened the 3 bolts for shutter but couldn't stick my arm in there
  22. Sep 19, 2022 at 8:46 PM
    #82
    Dmon187
    Dmon187 New Member
    DFW
    I had to get creative man.. it was a pain in the ass. You’re not gonna be able to pull the shutters back far enough to get you hand in there I dropped the lights in between the shutters and the grill and used the holes in the front of the truck including the light bar slot to move them back up into position. It was difficult but I can be done. Hard to explain lol
    paradizecityz[QUOTED] likes this.
  23. Sep 19, 2022 at 8:49 PM
    #83
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Let us know what works. I’m going to start working in mine this weekend and plan on sealing them before installing.
  24. Sep 19, 2022 at 10:07 PM
    #84
    eddiefromcali
    Eddie
    100% Stock
    Should have an update tomorrow
  25. Sep 20, 2022 at 8:02 AM
    #85
    paradizecityz
    Richmond, TX
    Haha, I'll see if I can get creative then lol
  26. Sep 21, 2022 at 11:06 AM
    #86
    paradizecityz
    Richmond, TX
    Well, I did it…without taking the front off. Somehow managed to angled my fingers through enough
    Using Rave Offroad housing and bought my own lights instead
    Dmon187 and eddiefromcali like this.
  27. Sep 21, 2022 at 11:11 AM
    #87
    paradizecityz
    Richmond, TX
    The housing fitment is ok, wish it filled in just a little bit more. Nothing bad, but nothing great.
    Dmon187 likes this.
  28. Sep 21, 2022 at 11:13 AM
    #88
    eddiefromcali
    Eddie
    100% Stock
    What lights did you put in the housings?
  29. Sep 21, 2022 at 11:13 AM
    #89
    Dmon187
    Dmon187 New Member
    DFW
    I mean it works, I know exactly what you mean but it’s better than the empty slots. I haven’t plugged mine up yet.
  30. Sep 21, 2022 at 11:24 AM
    #90
    paradizecityz
    Richmond, TX
