OFFICIAL: Oil Analysis Report Thread ONLY
Discussion in '3rd Gen Tundras (2022+)' started by eddiefromcali, Jun 13, 2024.
  1. Sep 19, 2024 at 3:00 PM
    #181
    mfelton18
    mfelton18 New Member
    South Central Texas
    2014 Magnetic Grey SR5 4x4 crewmax
    2.5 Tundra guy here. Got my oil sample results back. What causes all the additive metals to be high?
  2. Sep 26, 2024 at 12:06 PM
    #182
    daverxa
    daverxa New Member
    Dave
    2024 White Tundra Limited TRD Offroad & TRD Lift
    Leer 100xl, ggoffroad DRV camera relocation, Decked drawer system, BF Goodrich TKO3 275/65R20, Diode Dynamics Fog lights, Go Rhino Dominator D6 Running Boards,
    Dealer did this oil change so I don't know how they took the sample. Wonder if that in any way contributed to the Fuel% being high.
    Saw this in another post. Maybe the truck was cold when they did the change:
    - Be sure to sample hot oil that’s been driven on for 10-15 mins. to allow any fuel residual/vapor to evaporate from the oil. (ok to let it cool a bit after driving for safety). Otherwise you can easily get a higher than normal fuel contamination percentage and a lower flashpoint temperature.
  3. Sep 26, 2024 at 1:42 PM
    #183
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Blackstone will tell you that those are all part of the additive pkg that the oil manufacturers add for longevity, protection, and performance. Your Silicon level will drop quickly as the sealants wash out of the motor.
  4. Sep 26, 2024 at 2:55 PM
    #184
    eddiefromcali
    eddiefromcali [OP] New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Guys, please keep the chatter off this thread. Results only
    PNW Tundra Mike likes this.
  5. Sep 26, 2024 at 2:59 PM
    #185
    Kap1
    Kap1 New Member
    San Francisco, CA
    Tundra 2022, 1794, July 2022 build date. Changed oil at 1k, 5k, 10k, 15k miles.
    STEPBRO likes this.
  6. Sep 26, 2024 at 8:31 PM
    #186
    FrankG
    FrankG New Member
    Francois
    2022 Lunar Rock Sr5 TRD Off Road
    Is there a thread for oil analysis discussion?
    daverxa likes this.
  7. Oct 2, 2024 at 4:47 PM
    #187
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Mine took about three weeks to get back. Metals are high but they don’t seem concerned.
    The majority of my trips are indeed short.
    There was a bunch of coffee grind-like material but only very fine metal debris at close inspection.
    4/24 build.
  8. Oct 4, 2024 at 10:52 AM
    #188
    FrankG
    FrankG New Member
    Francois
  9. Oct 4, 2024 at 11:29 AM
    #189
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Damn that’s awesome.
    eddiefromcali[OP] likes this.
  10. Oct 4, 2024 at 11:55 AM
    #190
    FrankG
    FrankG New Member
    Francois
    Thanks man (hope I didn’t assume your gender there). I want to run this motor for as long as possible before it gets replaced. Might try 10,000km on my current oil. We’ll see.
  11. Oct 4, 2024 at 4:43 PM
    #191
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    I know who I am.
    Tundra1988 likes this.
  12. Oct 9, 2024 at 4:50 AM
    #192
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    2022 Tundra SR5 , blueprint
    Tonneau cover
    IMG_0174.png Attached is my last sample
    Looks good so far at 40K plus
    Now if it fails after all these great oil samples then ……..
    VCheng, daverxa and ARB1977 like this.
  13. Oct 9, 2024 at 8:46 AM
    #193
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    Tonneau cover
    Just read on one of the forums here that Toyota will offer owners 20 year warranty with unlimited mileage, and during this time if the engine fails then it can be scheduled for replacement as per the recall. Not confirmed anywhere yet but this sounds like a good plan by Toyota if it’s true.
  14. Oct 9, 2024 at 9:25 AM
    #194
    FrankG
    FrankG New Member
    Francois
    I know this is not a comments thread but I’ve asked if there is one and got no reply. I also know someone else has asked this before with no answer but has anyone had an engine failure after an oil analysis so we can see what elements (if any) were elevated?
    daverxa likes this.
  15. Oct 9, 2024 at 4:35 PM
    #195
    BabyMoose
    BabyMoose New Member
    2023 Tundra Limited TRD Off-Road
    CBI bed rack, Decked storage, OVS Nomadic 2 RTT, Ironman DeltaWing 270
  16. Oct 11, 2024 at 9:09 AM
    #196
    Teddyk1
    Teddyk1 New Member
    Teddy
    Wisconsin
    Tonneau cover
    That’s a great question. Is there anyone out there that had oil analysis and their engine failed. There should be a trail that leads up to failure and that’s why we do oil analysis.
    daverxa likes this.
  17. Oct 13, 2024 at 12:24 AM
    #197
    PNW Tundra Mike
    Southern Cal
    First one that came up when I searched and there are more - https://www.tundras.com/threads/blackstone-lab-oil-results.148399/
  18. Oct 17, 2024 at 2:12 PM
    #198
    FrankG
    FrankG New Member
    Francois
    daverxa likes this.
  19. Oct 22, 2024 at 7:09 AM
    #199
    NVspearo
    NVspearo New Member
    S. NV
    2022 Lunar Rock Tundra SR5 TRD Offroad CM 6.5
    51k miles 2022 SR5, lots of towing, lots off offroad
  20. Nov 7, 2024 at 5:09 PM
    #200
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Got my 3rd oil analysis back today from Speed Diagnostix. High Copper level, said it's more likely from turbo bearing material, to change to higher Moly oil, said to try Toyota (ExxonMobil) oil, but not a fan of ExxonMobil products, so looking at Redline, now for the silicone, I read on this thread (if I remember correctly, Lake Speed had said) it maybe the Toyota Oil Filter, to use Wix Filter instead.
  21. Nov 8, 2024 at 4:21 AM
    #201
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    I don't like that copper level at all. You're running the best off the shelf 0w20 available. How many miles on the truck?
  22. Nov 8, 2024 at 5:15 AM
    #202
    machd08
    machd08 New Member
    CLARENCE
    4115 miles, probably go with redline, it’s suppose to be top tier oil, suppose to have more moly in it.
  23. Nov 8, 2024 at 5:28 AM
    #203
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Mebbe look at Liquid Moly engine oil?
    machd08[QUOTED] likes this.
  24. Nov 8, 2024 at 5:29 AM
    #204
    Jettster
    Jettster New Member
    Brand of oil is not the issue, hope I'm wrong, btw when you change brands it can throw off reports due to differences in formulation and additive pack. So far so good on mine. Did Blackstone at 14,850 looked good Toyota changed at 5000, 10,000, and 14,850 using factory oil and filter. Are you on the recall list? My production date is 2/23 and so far not on the naughty list.
  25. Nov 8, 2024 at 6:37 AM
    #205
    machd08
    machd08 New Member
    CLARENCE
    Not on recall, Lake was thinking the copper could be from the Turbo bearings, 3/21/24 build date, have used Pennzoil Ultra Platinum on 2 of 3 oil changes, 1st was the OEM oil, next 2 were the Pennzoil.
    The copper just showed up on this last analysis. Lake Speed was saying to get a higher moly based oil. Silicone has been smaller problem, will probably change to a Wix filter.
  26. Nov 8, 2024 at 6:45 AM
    #206
    hoki06
    hoki06 New Member
    2023 non-hybrid with March 2023 build date looking good so far. Bought new and changed the oil at 500, 5.5k, and now 10k. Saw some fine flakes at the 500 change but was expected for break in. We’ll see how 15k looks next year.
  27. Nov 8, 2024 at 10:36 AM
    #207
    Jettster
    Jettster New Member
    Lake tells the truth as best he can...way better than most. That said I wish you luck could be a turbo could be front main bearing but I don't like it at all...at your low mileage oil should be oil.
  28. Nov 8, 2024 at 12:22 PM
    #208
    machd08
    machd08 New Member
    CLARENCE
    Agree 100%, just ordered redline oil, going to use it as it’s high in moly, which Lake said to use high moly to see if it helps
  29. Nov 8, 2024 at 12:31 PM
    #209
    Retired...finally
    I hope it meets Toyota specs. Should you have any problems due to lubrication Toyota is likely to deny a warranty claim is the improper oil is used and for good reason.
  30. Nov 8, 2024 at 1:55 PM
    #210
    machd08
    machd08 New Member
    CLARENCE
    It says it meets Toyota standards
