OFFICIAL: MY22-23 Toyota Tundra HV TRD Pro - LIMITED SERVICE CAMPAIGN - 24TD01 - PREMATURE TIRE WEAR
Discussion in '3rd Gen Tundras (2022+)' started by ryanwgregg, Feb 29, 2024.
  1. Apr 25, 2024 at 10:19 AM
    drewpweinerMD
    drewpweinerMD Just left your moms house
    Jeremy
    2024 CM TRD OR
    RB20 Slims, RC bed mat, BAK Revolver X4s
    I just received the same response yesterday. What a joke - Toyota should be ashamed of themselves.
  2. Apr 25, 2024 at 10:28 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    The specific reasons they gave me were that I didn't get the work done at a Toyota dealership and the tires weren't the same size. I asked them how was I supposed to do that when the tires were out of stock? They said I should have waited. So stupid.
    I filed a complaint with the BBB. Not sure it will change anything, but you miss every shot you don't take.
  3. Apr 25, 2024 at 10:38 AM
    drewpweinerMD
    Jeremy
    2024 CM TRD OR
    Yeah i went back and forth with them since I did the same thing. I wont use the dealer for anything - They do shit work and are more expensive. I told Toyota that too, more eloquently of course.
  4. Apr 25, 2024 at 6:55 PM
    jdram11
    jdram11 New Member
    Hi all, I’m officially waiting from brand engagement to decide how they will help me or if they will at all. According to their systems my 2023 trd pro is not part of the recall, but is sure as shit wearing and trashing the tires! Which I hate anyways.
    I want credit for new tires. If I get real wildpeaks, that would be a win for sure. At least I can resell those.
    I would be filing with the BBB for sure as well, this “aggression would not stand” as the dude said In the Big Lebowski movie quoting president Bush.
    Ah, fvck it, let’s go bowling!
    I hope I can resolve this In a Positive way. If anyone on the Oregon area has had a dealership that has replaced them, pls share the name.
  5. Apr 29, 2024 at 4:02 PM
    overl4nd
    overl4nd New Member
    I am currently struggling with brand engagement. Toyota dealerships have this service campaigns for May 2023 and earlier TRD PRos.
    Mine was manufactured later in August.
    Since there are no changes between May 2023 and August 2023 (New. control arms came with MY2024) I am wondering why should this not cover me. Toyota insists there is no remedy/recall active for my vehicle.
    Toyota dealership machine has my Toe at .60 total toe, while from the TSB it seems it should be 0.3 total (0.15 on each side).
    Toyota also asked me to contact Falken for tire wear, and they came back saying its due to alignment and I should take it up with Toyota
    Basically a run-around. All Toyota is giving me is free alignement, and no word on the tires
  6. May 2, 2024 at 8:20 AM
    MrMitch96
    MrMitch96 New Member
    Mitch
    ME
    2014 Toyota Tundra SR5 TRD-Off Road
    Is the tire wear still a problem to worry about? I'm currently searching for my first TRD Pro 22-24 and wondering if I should be concerned? Should I search for a specifc month/year manufactured?
  7. May 2, 2024 at 3:17 PM
    jdram11
    jdram11 New Member
    I have an update on my case.
    Took the truck for an alignment check. And guess what, my alignment numbers called on the service manual or whatever system they use to get their specs info DOES NOT, match the alignment specs from the recall.
    I called my case manager and provided the information. I asked why would my trd pro have different spec numbers on the system, different than to the new specs that fix this problem? I said, there should be no reason why my truck has a different alignment spec than the “fixed new spec”.
    I said, perhaps there is a bigger problem where the new trucks are being aligned properly at the factory, but then when they come back to the dealership after they have been In service and do an alignment they will get dial back to the wrong setting!
    It seems to me that they updated the system to only give new specs to the vins affected, instead of blindly updated the spec to the trd pro line.
    waiting another week to see what they tell me now, but now I know, it has diff alignment specs than what the recall asks for!
  8. May 2, 2024 at 7:01 PM
    Upfront1
    Upfront1 New Member
    2023 Tundra TRD Off Road
    I noticed excessivewear on the outside part of my front tires. My 2023 Tundra TRD Off Road truck has only 19000km. Got the truck back from my Toyota dealer today and they noted the tire wear and confirmed that my tire alignment is to Toyota specifications. They agreed to speak to Toyota Canada to see what the fix is. I mentioned the current service campaign for the Tundra Pro trim models L85 and that they need to extend the service to more models as I don't want to replace my tires every couple years for a problem that originated at the factory. We will see how this goes.
  9. May 5, 2024 at 12:52 AM
    overl4nd
    overl4nd New Member
    Same issue here. My dealer insists on total toe of .50-.60, while the new specs which a helpful tech from another dealership on the east cost (opposite coast shared with me) says total toe not more than 0.25
    I have out edge wear and falken has asked me to contact Toyota. They have assigned a case manager who is looking into it.
  10. May 8, 2024 at 1:14 AM
    overl4nd
    overl4nd New Member
    Toyota says my 2023 TRD pro is not covered in this TSB. Only vehicles upto May manufacture are covered.
    Now I am confused
    1. I have a 2023 Pro manufactured in August probably, so mechanically identical to other 2023s (new control arms came for MY2024)
    2. I have the 0.60 total toe alignment from factor, as well in the dealership machine, which is supposedly too much.
    How come its not covered.
    Falken have washed their hands off as its an outer edge wear, and Toyotas told me to pound sand. I have filed a NTSB complaint.
  11. May 22, 2024 at 9:22 PM
    416taco
    416taco New Member
    I went to the dealership today, and was told I'm eligible for 4 FREE tires.
    BUT,
    the tires (exactly the same at3w without 3pmsf sign) are on back order till August, so they are considering to find a better line of tires to avoid the long wait.
    Does any have the same experience and what "better tires" can be upgraded to?
    Thanks,
    ryanwgregg[OP] likes this.
  12. May 23, 2024 at 4:58 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
  13. May 23, 2024 at 7:42 AM
    jdram11
    jdram11 New Member
    I was told they are trying to give me 4 tires but have to be the same crap-imazing tires… anything better than that trash would be great.
    I hope there is a tire god somewhere and takes care of all this mess!
