Official Let’s see the 2022+ midnight black metallic trucks
Discussion in '3rd Gen Tundras (2022+)' started by DimaA, Jan 5, 2023.
  1. Jan 27, 2023 at 10:15 PM
    #61
    DimaA
    DimaA [OP] New Member
    Dmitriy
    WA
    2022 toyota tundra platinum
    K&N air filter. Front windows tint, RC front leveling kit.
    Mine is the same with 6.5 bed. Love this truck
  2. Jan 27, 2023 at 10:33 PM
    #62
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Awesome!!! Yours would not fit in my garage as mine barely fits. :) Did you get Adv Package and powered running boards/step too? I can quite tell.
  3. Jan 27, 2023 at 11:19 PM
    #63
    DimaA
    Dmitriy
    WA
    Yes I did
    Maharisc[QUOTED] likes this.
  4. Jan 28, 2023 at 6:48 AM
    #64
    G_Samps
    G_Samps New Member
    Geoff
    ‘22 TRD Sport
    Picked mine up last Sept. ‘22 TRD Sport w/ every package. Received a crazy trade in paid out in a check for my ‘09 Rockwarrior with 280K.
  5. Jan 28, 2023 at 6:57 AM
    #65
    Carolina Peej
    Carolina Peej Hey can you hold the light for me real quick?
    North and South Carolina
    2022 Midnight Black Metallic 4x4 Tundra Platinum 5.5 w/ load leveling + AVS, HUD, and Power Running Boards
    Really good looking truck. Is that stock height or did you lift / level it? Do you have the air suspension in the rear?
  6. Jan 28, 2023 at 7:16 AM
    #66
    Carolina Peej
    Is the truck in the low suspension setting in this picture, or the Normal height? I struggled with a rough ride for months until I realized my air suspension was riding too low. Spec for the distance between the bumps stops and the axle are 35-45mm. Mine were both below 30mm and the truck would bang off the bump stops regularly. I adjusted the sensor arms just in front of each air spring, and set the truck to the max setting ( i might even be a few mm over 45...) Night a day difference in the ride.
    I'm not trying to start anything or create a situation for you, but if that picture is in the Normal setting, I can tell from here that your air suspension might be set too low...
    DimaA[OP] likes this.
  7. Jan 28, 2023 at 10:03 AM
    #67
    Maharisc
    Maharisc w/Patty
    Karl
    No worries, I know about the TSB, it is normal height, it is too low, just picked it up Wednesday and haven't had the time to adjust it. We been getting snow and temps to drop to single digit or less starting this weekend. It may be awhile before it gets adjusted. "Take it to a Dealer", yep, could do that too.
  8. Jan 28, 2023 at 12:44 PM
    #68
    Carolina Peej
    Ok good. Glad I'm not instigating anything. I have the identical truck and mine used to look like that...
    I took mine to the dealer, they told me people were overreacting about the air suspension, and not to get sucked into the forums and create phantom issues.... :mad: I adjusted it myself and it rides like a different truck. Took me several tries to get the adjustment where I wanted it...
  9. Jan 28, 2023 at 7:13 PM
    #69
    99ways2die
    99ways2die New Member
    Thnx.
    OEMs with 285/60/20 Cooper Discoverer AT3 XLTs (Wescott 3/1 Platinum lift/level kit (so in reality a 2" front lift)). Air suspension.
  10. Jan 28, 2023 at 10:42 PM
    #70
    R2theD2
    R2theD2 New Member
    Seattle
    2022 Tundra 1794 TRD Off-Road Lifted - Midnight Black
    TRD Lift Kit TRD Skid Plate TRD Running Boards Nitto Ridge Grapplers (35x12.5) OEM Bed Step OEM Toyota Tonneau Cover (Quad-Fold) 3M Window Tint (matched factory rear) Spray-On Bedliner
    First time to beach since lift and tires added.
    22whatwedo, =JSG=, Yaboy and 5 others like this.
  11. Jan 29, 2023 at 3:08 AM
    #71
    Dethred
    Dethred New Member
    Just picked up my new Crapstone (ha) for $3600 off MSRP. No idea what it's like because of the 17 hour round trip day to pick it up, don't even remember the drive back at all. I guess the LCA works well.
    =JSG=, SD.Tundra.858, PBNB and 3 others like this.
  12. Jan 29, 2023 at 5:00 PM
    #72
    SD.Tundra.858
    SD.Tundra.858 Family man...Toyota fan! Best spices in town!
    Travis
    San Diego, CA
    2023 Black Limited 4x4 w/ Platinum package
    How did you adjust the sensor arms?
  13. Jan 29, 2023 at 6:43 PM
    #73
    Maharisc
    Maharisc w/Patty
    Karl
  14. Jan 30, 2023 at 9:42 PM
    #74
    SD.Tundra.858
    Travis
    San Diego, CA
    So I decided to give it a go and do a test run on the rear bumper, chrome inserts on them. Was fairly easy to remove them. Just have to use a good set of long nose pliers to squeeze on about 6 clips per side to remove the top plastic piece. Then it is only 1 screw per side and 3 push clips.
    Once I got them off, I used the 2000 grit sand paper in the kit I got from touchupdirect link you shared.
    I set up a little "spray booth in the bathroom at my shop (big fart fan in there) and sprayed a few coats of primer, then color, then clear coat. I had to watch a few videos on how to do it right. I also had to watch a couple videos on how to remove the "dust nibs" that happen.
    After that I went to an auto paint supply store here in SD and got a polishing wheel/pad, some 3000 grt san paper and some 3M polishing compound. It only took me about 30 minutes to sand out the few dust nibs I had, then polish them up.
    Overall, for never painting any car parts before, it was super easy! Now I'm confident I can paint the mustache on my own. And I like the feeling knowing I did this on my own!
    I'll post a picture of them installed once the rain stops! But here are a few of the process along the way!
    20230127_160236.jpg 20230127_160241.jpg 20230127_213324.jpg 20230127_213327.jpg
  15. Feb 3, 2023 at 2:13 PM
    #75
    23LMT471
    23LMT471 New Member
    2023 CrewMax SR5 TRD Off-Road Midnight Black
    First day and now has 14 miles.
  16. Feb 3, 2023 at 7:07 PM
    #76
    chrispage
    chrispage New Member
  17. Feb 7, 2023 at 8:29 AM
    #77
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    2023 Tundra CM Limited TRD OR Midnight Black
    Hi Folks,
    Taking delivery of a Midnight Black Metallic in a couple weeks. Have read a few posts in various threads indicating this particular paint does not hold up well to surface scratches. I know black overall is not a very forgiving colour for vehicles, but I'm wondering if there are some issues with this particular paint job overall?
    Just wanted to get your thoughts and if you have opted for things like PPF/ceramic as a precaution/response to the noted concerns. Cheers.
  18. Feb 7, 2023 at 9:39 AM
    #78
    23LMT471
    23LMT471 New Member
    I plan on using Turtle Wax Hybrid Solutions Ceramic Black Spray Wax when I get more “wear.” I looked at some videos and reviews and seems pretty sweet for black vehicles. Yeah black vehicles tend to show dirt and scratches more but I like the look when clean.
    Anybody using this now? https://www.amazon.com/Turtle-Wax-5...59&hvtargid=pla-907928667002&region_id=674469
  19. Feb 8, 2023 at 9:35 PM
    #79
    SD.Tundra.858
    Travis
    San Diego, CA
    I'm probably just going to do it...spend the $5k-6k to wrap my truck entirely in PPF that self heals. No scratches...holds up great. Protects your paint. Then have a ceramic coating on top of that! Probably going to go with a satin wrap.
  20. Feb 10, 2023 at 5:45 AM
    #80
    Byrdarian
    Byrdarian New Member
    Anthony
    2023 Tundra Limited 4x4 Crewmax 5.5' Midnight Black
    Still have some chrome to remove but I think she looks nice. Resized_20230131_143447.jpg
    22whatwedo, =JSG=, ToyoMon and 4 others like this.
  21. Feb 10, 2023 at 6:53 AM
    #81
    SD.Tundra.858
    Travis
    San Diego, CA
    Looks great. Did you swap the mustache or paint it/wrap it flat black? What tires are you running?
  22. Feb 10, 2023 at 6:55 AM
    #82
    Byrdarian
    Anthony
    I sprayed plastidip on the mustache. Need to touch up because it got nicked where the pieces fit together. Did this when I installed the heritage pro grill.
    And I'm running KO2s 275/65r20s on stock suspension at this time.
  23. Feb 10, 2023 at 7:54 AM
    #83
    TRD-JP
    TRD-JP New Member
    Winnipeg, Canada
    Well, I made a decision and got a package put together. SunTek 10year warranty PPF on partial front hood/fenders, mirrors, headlights, and rockers/lower doors (i.e. the Winnipeg winter salt and sand package). Then a mid-tier Ceramic-Pro (5year warranty) package that includes wheels and window treatments. I'm extremely happy with the price I was quoted and seemed like a no-brainer for keeping the black shiny and protecting from some of the saltiest and sandiest winter roads on the continent...
  24. Feb 11, 2023 at 11:57 AM
    #84
    alpage
    alpage New Member
    2022 Toyota Tundra SR5 Off Road Black
    I used https://www.paintedoemparts.com/painted-oem-models/tundra - wasn't the cheapest option but the quality is perfect and I'm happy with the outcome.
  25. Feb 11, 2023 at 9:18 PM
    #85
    ChrisCamp
    ChrisCamp New Member
    23 Crewmax
  26. Feb 11, 2023 at 11:50 PM
    #86
    DimaA
    Dmitriy
    WA
    Truck looks great. Can we get side view with detail of wheels and tires you using
  27. Feb 12, 2023 at 6:38 AM
    #87
    SD.Tundra.858
    Travis
    San Diego, CA
    Not the best angle for a picture, but this was the final result of using the paint kit you mentioned above. It was actually super easy. I just need to buff out the polishing compound a bit more to bring it the shine. Took me 3 days to paint them. I'm pretty confident now that I corks paint the mustache parts and they would look great.
  28. Feb 12, 2023 at 8:07 AM
    #88
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    Picked up my 2023 TRD Pro yesterday. It will unfortunately never look this good and clean ever again. Rotator cuff injuries from trying to keep a black truck clean might be in the future tracked back to this date...
  29. Feb 12, 2023 at 8:39 AM
    #89
    firefightermtn
    firefightermtn New Member
    Fourth and final iteration of my Tundra! Started out with a LR Limited TRD allocation........
    Found a MB 1794 on a lot at another dealer....put a deposit down and when I went to close the deal, they had sold to someone else.
    Went back to my original dealer and inquired about any 1794's they had en route......they did not, but had a few Platinums that weren't spoken for.
    Put my name on a MGM with only floor mats, but it was a few weeks out. Called to check in and they had this sucker all ready to go after the buyer backed out. Grabbed it that day. Couldn't be happier. Power running boards and AVS......options I didn't know I needed!!
    This black is unreal. I dig the blue flakes!
    22whatwedo, =JSG=, Syclone91 and 6 others like this.
  30. Feb 12, 2023 at 12:56 PM
    #90
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Beautiful truck!! My build date is scheduled for tomorrow. Seeing this baller pic is getting me even more excited.
    ryanwgregg likes this.
