Official 3rd Gen Magnetic Grey Metallic Photo Thread
Discussion in '3rd Gen Tundras (2022+)' started by Outbound, Jun 24, 2022.
  1. Dec 8, 2024 at 5:49 PM
    #271
    vichmr
    vichmr New Member
    Scott
    Suwanee, GA & Highlands, NC
    '25 MGM Platinum TRD OR 6.5 w/ factory lift
    Go Rhino Dominator D6, Diamondback HD
    How do you like your tonneau cover? I'm interested in buying one, but for the cost want to make sure it's really what I want. TIA!
  2. Dec 8, 2024 at 6:45 PM
    #272
    vichmr
    vichmr New Member
    Scott
    She's a KEEPER!!! The truck too! :rofl:
    wing-2[QUOTED] likes this.
  3. Dec 8, 2024 at 6:58 PM
    #273
    vichmr
    vichmr New Member
    Scott
    Looks amazing!!!
  4. Dec 8, 2024 at 7:03 PM
    #274
    Outbound
    Outbound [OP] SSEM #2.5, AmeriCanadian, OG 1st Gen Rabble Member
    Aaron
    Northern Alberta
    No complaints so far.
    vichmr[QUOTED] likes this.
  5. Dec 9, 2024 at 4:00 AM
    #275
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    '24 1794 HV 6.5' MGM w/ AVS-LL, HUD, RB
    I am interested to see a photo of the tailgate of a MGM with the accessory black letters and chrome letters installed. If your Tundra has this could you share a photo. Thanks.
  6. Dec 9, 2024 at 7:44 AM
    #276
    euroshowoff
    euroshowoff New Member
    Ronnie
    2024 Limited
    wondering why you swapped the elevate racks for the yakima? i have the elevate slot rails...was thinking about the elevate rack. thanks.
  7. Dec 9, 2024 at 7:47 AM
    #277
    euroshowoff
    Ronnie
    2024 Limited
    any chance you can share the wheel/tire setup?
  8. Dec 9, 2024 at 8:21 AM
    #278
    Hammertimerrrr
    Hammertimerrrr New Member
    2024 MGM Limited OR
    Elevate rack is heavy-duty and I'm sure works for the needs of many. If you have t-slot rails, the Yakima would also work with the t-slot kit.
    Elevate is a heavy rack - too heavy for me to be able to take on and off when I need to a few times a year at least not without likely beating up my truck in the process. Adjustability isn't great - there are only a few different height positions that are fixed. Adjusting the height is a pain also given the weight. Aesthetically I wasn't a big fan either.
    Yakima is just a better-designed rack IMO, at least for my uses. It's lightweight yet still strong, the height can be adjusted anywhere within the height range. The bars and towers all have markings on them so you can easily get things even without measuring. I also like the rack angles in toward the cab which better follows the lines of the cab for a more seamless fit. Also, the side bars on the Yakima (add on) rest higher on the towers. With the Elevate rack, the side bars attached to the same point as the cross bar towers - so if I had the elevate in the lowest position, I lost the ability to reach in the bed due to the side bar blocking.
    I also have a lot of Thule and Yakima mounts - the kind that have brackets that go around the crossbars. The crossbars on the Elevate are so big, they really aren't designed to use mounts that aren't t-slot mounted. I tried to adapt some of mine, but ended up needing ridiculously long bolts to cover the size of those bars.
    Benefit of the Elevate is certainly with a trifold or roll-up cover. Since they mount at a 90 degree angle, you can easily use this type of cover. I have a Retrax Pro so mine is retractable and I did not need this feature of the Elevate.
    My overall uses for a rack are largely for kayaks, mountain bikes, and my raft. I like to keep the bars just below cab height unless I'll be using my raft, in which case, I raise them over the cab height. I also will carry ladders and lumber when needed, and will also raise it as needed in those situations
    RealTruck likes this.
  9. Dec 9, 2024 at 11:43 AM
    #279
    euroshowoff
    Ronnie
    2024 Limited
    Thanks for the well detailed response.
    I have a trifold tonneau cover, and the racks would mainly be to support my fishing kayak, which is around ~120lbs.
    Hammertimerrrr likes this.
  10. Dec 9, 2024 at 12:39 PM
    #280
    Hammertimerrrr
    2024 MGM Limited OR
    Elevate is probably your best bet. It's relatively inexpensive in comparison and works perfect for tri-fold covers
  11. Dec 10, 2024 at 6:17 AM
    #281
    ngoshawk
    ngoshawk New Member
    2025 Tundra Platinum 6.5' bed
    Rough Country wheel liners, mud flaps, TufSkinz gloss black tailgate lettering, JDMCAR console organizer. That’s it.
    2025 Platinum 6.5’ bed, running boards. Still less than 250 miles on it.
    We needed a smoother riding truck than our Tacoma and more cargo capacity for carrying pellets for use in the pellet stove. Plus a 4x8 piece of plywood will fit better. Loved the Taco, love the Tundra so far. And we are still figuring out all the bells & whistles.
    Cheers.:)
  12. Dec 10, 2024 at 6:24 AM
    #282
    24LTD
    24LTD New Member
    Installed the TRD tailpipe.
    Taikowaza and RadixRyder like this.
  13. Dec 26, 2024 at 7:34 PM
    #283
    vichmr
    vichmr New Member
    Scott
    I'll try to get you a picture tomorrow of mine with the black lettering.
    PGW85706[QUOTED] likes this.
  14. Dec 30, 2024 at 8:22 AM
    #284
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Do you have the peel-n-stik lettering installed on the tailgate? What color is the lettering?
  15. Dec 31, 2024 at 7:56 AM
    #285
    vichmr
    vichmr New Member
    Scott
    @PGW85706 here's a picture of the tailgate with the lettering you were looking for. Not the best light, but hopefully this helps.
  16. Dec 31, 2024 at 10:48 AM
    #286
    PGW85706
    PGW85706 Member
    Patrick
    Central VA
    Thanks for sharing. Looks good. What color is the lettering....flat black? gloss black? matching MGM? Is it a Toyota installed accessory? I am studying the TufSkinz version and there are some good color choices. I don't like to stray too far from the OE look.
  17. Dec 31, 2024 at 7:53 PM
    #287
    vichmr
    vichmr New Member
    Scott
    I’d say flat black. I like it but have heard that the TuffSkinz are a quality product.
  18. Jan 21, 2025 at 6:31 PM
    #288
    andycas88
    andycas88 New Member
    Andrew
    2025 Tundra Limited 4x4
    New to Tundra forums. Was on Tacomaworld forums for over 20 years. Had an 04 Tacoma till 2013 and then had a 2012 Tacoma 4x4 Trd Sport till 1/18/25. Got a hell of a deal on my 2025 Limited 4x4 with under 5300 miles. Located just outside of New Orleans, LA. Looking forward to getting to meet some of y’all.
    ngoshawk, Blufin, Soupbean77 and 3 others like this.
  19. Jan 22, 2025 at 2:49 AM
    #289
    wing-2
    wing-2 New Member
  20. Jan 22, 2025 at 11:05 PM
    #290
    northtundra
    northtundra New Member
    2024 Tundra TRD OR
  21. Jan 26, 2025 at 2:24 PM
    #291
    Volator
    Volator New Member
    Vassalboro, Maine
    2025 Tundra CrewMax TRD - MGM
    Alu-Cab Contour with Crossbars Decked Drawers - Gen 2 Rough Country HD2 Steps Custom 2nd row platform for Dog Kennels Bullet Point Rubigrid Weathertech HP Matts Ceramic Coated Chrome Delete (Vinyl wrapped) Spigen Tempered Glass Screen Protector JDMCAR Central Control Gear Shift Panel Trim Cover Cornfed 2nd Gen 1.5" Front Lift Cooper Discoverer Stronghold AT 295-70/r18 Toyota TRD Exhaust Tip Rok Block tailgate gap seal GG Offroad Camera Relocation kit GG Offroad brake light cable GG Offroad Camera Suction Cup Mounts
    Just traded my 2017 CrewMax TRD in Quicksand for a 2025 CrewMax TRD in MGM.
    First mod is a platform for my dog kennels
    Also now have Rough Country HD2 running boards and Decked Drawers installed...
    Soupbean77, northtundra and CrayCray like this.
  22. Jan 30, 2025 at 9:36 PM
    #292
    spliffgates
    spliffgates New Member
    2022 Magnetic Grey SR5 Tundra 4x4
    This looks great, which topper is that?
    ngoshawk likes this.
  23. Jan 31, 2025 at 1:53 AM
    #293
    Volator
    Volator New Member
    Vassalboro, Maine
    Looks like a RSI Evo-A
  24. Feb 6, 2025 at 7:16 AM
    #294
    Tundra009
    Tundra009 New Member
    Concord, CA
    Actually its just an ebay knock off that I got for half the price of what most are asking for. Solid made out of metal and has held up really well on all my once a month overland trips.
    spliffgates[QUOTED] and ngoshawk like this.
  25. Feb 10, 2025 at 6:20 AM
    #295
    ngoshawk
    ngoshawk New Member
    That’s an interesting looking topper, and very functional from your pictures. Sometimes the form-fitting ones can look a bit stale to me.
    Cheers.
  26. Feb 22, 2025 at 4:48 AM
    #296
    Taikowaza
    Taikowaza New Member
    Can you share a link to the link, or model #, name? looks great
  27. Feb 22, 2025 at 12:35 PM
    #297
    SnowToy
    SnowToy New Member
    2023 Tundra TRD Pro - build in the works...
    295/70/18 Duratracs - more mods being researched...
    what suspension setup are you running ? That looks perfect.......
  28. Feb 22, 2025 at 12:49 PM
    #298
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    It's in his Sig Block, Icon Stage 9.
  29. Feb 22, 2025 at 12:51 PM
    #299
    SnowToy
    SnowToy New Member
    thanks !
  30. Feb 22, 2025 at 12:52 PM
    #300
    Maharisc
    Maharisc w/Patty
    Karl
    You're welcome.
