Official 2022 Tundra 3rd Gen Thread
Discussion in '3rd Gen Tundras (2022+)' started by ColoradoTJ, Oct 13, 2021.
  1. Feb 25, 2022 at 4:44 PM
    #4891
    Xspurt
    Xspurt New Member
    I know few have much choice right now but we are being conditioned to think MSRP is good deal and are now suspicious of a deal below MSRP?!? LOL, we are so screwed!!
    Mattedfred and MTRock like this.
  2. Feb 25, 2022 at 7:14 PM
    #4892
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Obviously I don’t know a lot about turbos . lol . Thank you for the explanation .
  3. Feb 25, 2022 at 8:48 PM
    #4893
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    This one sat on the lot for almost a month. Was one of the first to arrive here in OR. 4x2’s just don’t move here. I saw it in person when getting a new oil filter. This dealer is below MSRP on all Tundras though but only $177 below on 4x4’s. The other dealer in town is $250 below for 4x4’s. Both had unclaimed rigs coming in as of last month. Just none that I wanted.
    Acedude, Mattedfred and doublethebass like this.
  4. Feb 26, 2022 at 1:21 PM
    #4894
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Very impressive towing without a WDH. I hate WDH's myself because when you go from pavement to whoops you have to disconnect and go to a straight hitch. I beef up the rear suspension to compensate onroad (Timbrens on this Sequoia). '22 Tundra is very impressive how it handles max GVWR from LA through Moab and into Denver and no need for a WDH.
    TK1979 and Tundra'25 like this.
  5. Feb 26, 2022 at 3:10 PM
    #4895
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    With that 6k trailer he was within 20lbs of the rear axle max rating! Anybody catch that?
    Acedude likes this.
  6. Feb 26, 2022 at 5:07 PM
    #4896
    Totherion
    Totherion New Member
    Acedude, Tundra'25 and Mattedfred like this.
  7. Feb 26, 2022 at 5:17 PM
    #4897
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    He also had 250 lbs of bike in the bed and no weight distributing hitch on it. Weight distribution hitch would transfer some of that weight
    Acedude likes this.
  8. Feb 26, 2022 at 7:57 PM
    #4898
    Malinois38
    Pa.
    Don’t want to sidetrack the thread. But, a truck cap weighs about 250lbs, so that is a wash for me. And a WDH transfers some weight to the front axle and to the trailer axles but the force is still applied to the tongue. I’m not an engineer, but that is the best way I can explain it and I’ve done a lot of research on this particular subject.
    Trust me, I want the new Tundra to work for me & my family. We pull a camper and our tongue weight is 980lbs. and there are four of us. My 2008 Tundra with 1325lbs of payload has been a workhorse for us and taken us all over the U.S. But, I’m now over 200k and 14years in the northeast. It’s time for me to upgrade & hoping the hybrid Tundra can work for me. I just have no confidence in any other brand.
  9. Feb 26, 2022 at 9:13 PM
    #4899
    Osiris
    Osiris New Member
    20 Plat
    Jthawks, TK1979, Mattedfred and 2 others like this.
  10. Feb 26, 2022 at 9:14 PM
    #4900
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    Hmm, I've never thought about that. Not that I top it off after it clicks, but . . . very interesting
    I'll take a look at the vid.
    TK1979 likes this.
  11. Feb 26, 2022 at 9:19 PM
    #4901
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    shoot…I guess this is something I need to stop doing as well (on all my vehicles)
    Minarets likes this.
  12. Feb 27, 2022 at 5:26 AM
    #4902
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Honestly sounds like you need a 3/4 ton with those numbers, but from what I have been seeing if your second gen handled it, the third gen will too.
    Acedude and Malinois38[QUOTED] like this.
  13. Feb 27, 2022 at 7:00 AM
    #4903
    Xspurt
    Xspurt New Member
    Topping off where you see the fuel right at the top of the filler - so full that closing the cap might even spill some out, is definitely bad. They wait 30 seconds to let any foaming die down (this is more of an issue with diesel but gasoline does it too) and then turn the pump on one more time until it clicks off. That doesn't equate to the topping off they're warning against. If doing it TFL's way is causing damage then this would be a massive, widespread problem which it is not.
    So yeah, don't top off but that isn't what TFL is doing.
  14. Feb 27, 2022 at 7:29 AM
    #4904
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Exactly. Some pumps out there don't flow well into various fuel necks and will click off after only like 20 litres even though you're at a 1/4 tank and can take 100 litres. It's all in how the pump, fuel neck, and fuel flow interact. If the fuel is flowing faster you will get the click sooner. Doing the 30 second wait and then going for another click is the most reasonable way to properly determine fuel used without actually having a removable tank
  15. Feb 27, 2022 at 7:49 AM
    #4905
    Osiris
    Osiris New Member
    20 Plat
    Why would you even bother risking thousands in damage for a 1/4 gallon extra? It IS a widespread issue. It's not going to stop your vehicle from running but it does cause permanent damage to the EVAP system. You won't get a check engine light until it's far too late with the purge valve being damaged. Being that it IS just the EVAP system, you COULD delete it in states that don't do emissions checks but that's another topic. If you work in the automotive maintenance field, you would know how widespread of a problem this is. Most people don't even know they have a problem and wonder why their vehicle smells like gas when parked.
  16. Feb 27, 2022 at 9:11 AM
    #4906
    Drobc
    Drobc New Member
    I think the 3rd gen with fully boxed frame can handle greater payloads than the 2nd gen. On paper, I think the new/ weaker composite bed on the 3rd gen is what is driving payload numbers down. That and maybe rear coils, but those can be upgraded.
    Acedude likes this.
  17. Feb 27, 2022 at 12:53 PM
    #4907
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    sounds like the 3rd gen will work great for you then. But don’t get a hybrid if your worried about payload.
    Acedude likes this.
  18. Feb 27, 2022 at 12:55 PM
    #4908
    Toyota1234
    Jack
    My last two trucks I always filled up until I could see the fuel. At some point a few years ago I learned it can cause problems so I stopped but. No
    Issues ever came from it. At least that I’m aware of.
    Mattedfred likes this.
  19. Feb 27, 2022 at 2:09 PM
    #4909
    Malinois38
    Pa.
    Well, I think the hybrid payload numbers will be close to the non-hybrids. And I definitely want the extra torque that the hybrid provides. I will wait & see how the #’s look.
    Cpl_Punishment and Acedude like this.
  20. Feb 27, 2022 at 3:21 PM
    #4910
    Toyota1234
    Jack
    The hybrids will have a payload rating of a couple hundred pounds less. Batteries are heavy..
  21. Feb 27, 2022 at 3:34 PM
    #4911
    belanger9
    Edmonton, AB
    A bunch
    Toyota also increased the GVWR of the hybrids to help negate the battery/motor weights. The payloads won't drop as much as other vehicles do.
  22. Feb 27, 2022 at 5:16 PM
    #4912
    Osiris
    Osiris New Member
    20 Plat
    Toyota website lists the TRD Pro as having a ~6klbs GVWR vs ~5800lbs, more towing and a higher payload than Plat/1794 non-hybrid.
    The bed isn't what is lowering the payload. It's the softer suspension in the rear with 5 link coilovers vs leaf springs that makes it a smoother ride, especially when empty. That's why people that overland would usually add leaf spring helpers to increase their permanent payload. People that add campers to 3/4/1tons usually add airbags as well to prevent sagging of the compressed leaf springs.
  23. Feb 27, 2022 at 8:21 PM
    #4913
    Xspurt
    Xspurt New Member
    Especially NIMH batteries.
  24. Feb 28, 2022 at 8:36 AM
    #4914
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Acedude likes this.
  25. Feb 28, 2022 at 11:16 AM
    #4915
    Acedude
    Acedude New Member
    Colorado Plateau
    8.8MPG with a 7klb brick hooked up is what I'm used to at altitude with Toyota V8's. TTv6 handles the load well but the physical laws of the Universe don't change by engine choice. You want to hold 70MPH towing a brick you'll be refueling often. I believe TFL has done the same loop with diesel trucks and saw better MPG but not a super-remarkable MPG bump.
    eebozz likes this.
  26. Feb 28, 2022 at 12:09 PM
    #4916
    belanger9
    Edmonton, AB
    A bunch
    And that just reinforces how tough it's going to be for EV's to crack the working truck market. ICE get 30-50% mileage when towing, EV's getting that range cut that much is trouble for those looking to travel. Physics don't care if it's hip or trendy.
  27. Feb 28, 2022 at 12:14 PM
    #4917
    Breathing Borla
    AZ
    ya, someday it will get there, but not now.
    when I drive to northern MN to fish in the summer and fall, I want to go 600 miles without screwing around. or other road trips
    Acedude likes this.
  28. Feb 28, 2022 at 12:19 PM
    #4918
    nodak67
    nodak67 New Member
    JR
    dont forget to add in cold weather loss on top of the towing loss on EV trucks.
  29. Feb 28, 2022 at 6:14 PM
    #4919
    belanger9
    Edmonton, AB
    A bunch
    I'm thinking my next truck will indeed be an EV one, but that's more going around the city and small runs to in laws. Take a long trip and it'll be in the ICE SUV/Truck. EV's certainly have their place, but around here 4+ hours trips are considered short so that's at least 1 charge up time to get home.
    It's why I was really hoping this Tundra would have a PHEV version. Give me 20-30 miles on electric and I'd be super happy. Run around town without worrying about the engine needing to warm up, have the gas backup to take the longer trips.
  30. Feb 28, 2022 at 6:21 PM
    #4920
    Outbound
    Aaron
    Northern Alberta
    I've said it before, I'll say it again. For fully electric trucks to be practical in most of Canada they need 500+ kms of range at -40 degrees Celsius while towing at least 8000lbs through the mountains at 110km/h with the ability to charge from flat zero to full in under 15 minutes or less anywhere there is currently a gas station. Until that's possible, electric trucks are worthless outside of the 3 or 4 biggest cities in the province.
    PHEV is really the only way to be remotely practical for Canadian usage.
