Official 2022 Tundra 3rd Gen Thread
Discussion in '3rd Gen Tundras (2022+)' started by ColoradoTJ, Oct 13, 2021.
  1. Feb 22, 2022 at 7:01 PM
    #4861
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Not sure, most piggy back units don’t though, they intercept info going to the engine or from the engine to the ECU, and fool the ECU into thinking everything is normal while telling the engine to operate differently than stock.
    Kind of a dumbed down explanation but more or less how they work.
    Armament likes this.
  2. Feb 22, 2022 at 7:15 PM
    #4862
    badmeat
    badmeat New Member
    Cincy, OH
    2022 Limited
  3. Feb 22, 2022 at 7:55 PM
    #4863
    Jbeans691981
    Jbeans691981 New Member
    2022 Tundra Sport Lunar Rock
    n/a
    I kind of found the answer. It does not flash the ECU. It uses the vehicles existing mapping. here is a better explanation
    "The JB4 is a programmable computer that attaches between the ECU and vehicle sensors allowing it to adjust your vehicle’s tuning by tapping into areas of the factory flash mapping that are not normally available. Unlike other similar-looking tuning systems the JB4 is also able to tap in to CANbus - analogous to a spinal cord - allowing it to communicate and receive information from not only the ECU but also the transmission computer, stability control module, dash module, and many others. This CANbus connection provides a complete set of real-time operational data which is then dynamically incorporated into your JB4 tuning.
    A flash tune, on the other hand, modifies the tables on the ECU directly for higher performance. Usually loaded via the vehicles gateway on the OBDII port, but in some applications directly to the ECU by drilling a hole or disassembling the ECU to access the processor inside."
    MTRock likes this.
  4. Feb 22, 2022 at 7:56 PM
    #4864
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Low compared to? 5.7 Dyno is just shy of 300 RWP…At the Crank 381. So if parasitic loss is equal the 2022 3.5TT rated at 389…321RWP at the crank would be 402..if anything its underrated?
    Bo-Hunter and ryanwgregg like this.
  5. Feb 22, 2022 at 8:01 PM
    #4865
    Jbeans691981
    n/a
    Yea I've read that article a bunch of times and it really doesn't answer the how just the what. Its also really interesting to note that according to owners on this forum its only the front that is .5 inches lower. The rear is apparently the same height as the base and off-road.I can attest to the front being lower as the stance on mine is raked hard to the front.
    Acedude likes this.
  6. Feb 22, 2022 at 8:13 PM
    #4866
    Coal Dragger
    Kung Fu Dick
    We can chalk up any result to variations in the dyno, operator of the dyno, and of course the vehicle and its mileage and condition.
    Jbeans691981 likes this.
  7. Feb 23, 2022 at 10:01 AM
    #4867
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Something is also off on the RPM - looks to be 1000 off. Peak torque from Toyota is at 2400 RPM and the chart only has 200 ft lbs at that rpm
  8. Feb 23, 2022 at 10:14 AM
    #4868
    Coal Dragger
    Kung Fu Dick
    Chassis dynos don’t work well at recording torque readings over a wide enough operating range to capture good data at lower RPM’s if higher RPM’s are needed. Plus getting the transmission to play along and stay in 7th gear from idle to redline at wide open throttle is probably not happening.
  9. Feb 23, 2022 at 11:03 AM
    #4869
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Sorry, I know I’m getting old. But, listening to this guy makes me want to puke.
    MTRock likes this.
  10. Feb 23, 2022 at 11:20 AM
    #4870
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    I like this guys vids. Nerd Note: At about 2:30, even though they know the area, they bring out the DeLorme Gazetteer to make sure they know the proper route of attack. I'm a Gazetteer nerd. Of course you have to know how to read a map for it to be useful.
  11. Feb 23, 2022 at 11:43 AM
    #4871
    Jbeans691981
    n/a
    Not sure that is the actual dyno report from the jb4 chip. Good point though.
  12. Feb 23, 2022 at 5:18 PM
    #4872
    badmeat
    badmeat New Member
    Cincy, OH
    2022 Limited
    I placed a deposit on an in production Limited. Thanks for the suggestions regarding the suspension and towing. Ultimately this vehicle will serve its purpose just fine. I throughly enjoyed test driving one today. The PVM camera system is incredible. ETA for delivery is a couple weeks
    HMNYC, Acedude and MTRock like this.
  13. Feb 24, 2022 at 5:26 PM
    #4873
    Tibetan Nomad
    Tibetan Nomad New Member
  14. Feb 24, 2022 at 7:21 PM
    #4874
    Coal Dragger
    Kung Fu Dick
    Why do you keep spamming this video in every thread?
  15. Feb 24, 2022 at 7:23 PM
    #4875
    nmmike
    nmmike New Member
    2022 Tundra CrewMax SR5 TRD
    Howdy,
    I am going to start towing with my 2022 Tundra CrewMax 4 X 4 Premium OR package next week.
    My travel trailer weights 5500 loaded with dual axles. I use a Blue Ox weight distribution anti sway hitch.
    I am going to do hitch up the trailer and do a short test drive prior to hitting the road.
    I will update.
  16. Feb 25, 2022 at 9:50 AM
    #4876
    TimboSlice15
    TimboSlice15 Another money pit....
    Timothy
    Holly Springs NC
    2022 Tundra SR 4x4, 2017 BRZ Limited w/ PP
    I'm having a hard time believing this is a stuck closed issue. I've not seen any mention of over-boast and the related hoses blowing off. When my truck goes into low power mode, I don't hear the blow off value being held open to bleed of excessive pressure due to a stuck closed wastegate. I have the feeling this is actually a wastegate position sensor issue. Too bad Toyota didn't include a boost gauge to monitor pressures. We'll see where this goes. My truck has gone into reduced power mode a few times, but never set the CEL.
    Acedude likes this.
  17. Feb 25, 2022 at 9:53 AM
    #4877
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    So, I had to go to a town yesterday with a Toyota dealer that had 2 Tundra listed in their website. I get there and there's no trucks. The sales manager/salesman (this a very small dealer) said delivery if these has been put off so many times by Toyota that he no longer pays much attention to the promised date. Got my name on the list for an SR if it shows up.
    Acedude likes this.
  18. Feb 25, 2022 at 10:25 AM
    #4878
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    There's someone on the FB page selling an SR for 1k under msrp.
  19. Feb 25, 2022 at 10:27 AM
    #4879
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I might be wrong but isn’t that the reason for reduced power ? So the turbos aren’t being used .
  20. Feb 25, 2022 at 10:36 AM
    #4880
    Coal Dragger
    Kung Fu Dick
    The truck doesn’t have a blow off valve, since it is a mass air flow sensor regulated engine. So it will not vent intake air directly to atmosphere, instead there is a bypass valve and routing to dump excess boost or compressor surge on throttle close back in front of the compressor inlet. Otherwise the ECU can’t account for metered air that has entered and been vented directly to the atmosphere.
    Acedude likes this.
  21. Feb 25, 2022 at 11:09 AM
    #4881
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Saw a dark blue SR5 CM on the road yesterday, that color looks really nice with that package. Lady probably thought I was a little weird changing lanes all around it to get a good look...lol. The more of these I see in person, the more it grows on me. Started filling my penny jar for my deposit on a 24-25ish Lunar Rock CM Pro... (To replace my Dodge work truck... never getting rid of the Gen 2, until the wheels fall off...)
    Acedude, Joro43 and gj953 like this.
  22. Feb 25, 2022 at 11:13 AM
    #4882
    yooperbikemike
    Which 2022 FB page is that? There must be a half-dozen
  23. Feb 25, 2022 at 11:14 AM
    #4883
    COElkHunter
    Jeremy
    Stevenson Toyota in Denver is sending out advertising emails at MSRP. They had a platinum and SR5 listed (in transit...)
  24. Feb 25, 2022 at 11:50 AM
    #4884
    TimboSlice15
    Timothy
    Holly Springs NC
    For the Turbos to not be used, then the wastegate would need to be in the fully opened position. If the wastegate issue is "stuck closed", then the turbos will always be building boost pressure on the intake side as long as there is enough volume of exhaust gases to spin the impeller. There are 2 ways to control boost pressure, primary is the wastegate. The wastegate opens to allow the exhaust gasses to bypass the turbo impeller. When the gases are bypassing the impeller, it can't spin the charge side at speed to build boost. It is possible to bleed off boost pressure on the charge side via the blow off valve, but on the stock setup, there is a limit to how much this will help as the blow off can't be vented to atmosphere due to it potentially having hydro carbons in the intake. Turbos are awesome, but have draw backs.
  25. Feb 25, 2022 at 12:16 PM
    #4885
    yooperbikemike
    The ones I saw were from a dealer in PA -- Both white 2wd
    Mattedfred[QUOTED] likes this.
  26. Feb 25, 2022 at 1:34 PM
    #4886
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Yup. Not a lot of demand for the SR.
  27. Feb 25, 2022 at 1:41 PM
    #4887
    Breathing Borla
    AZ
    I bet it would be way higher if it wasnt detuned
  28. Feb 25, 2022 at 2:23 PM
    #4888
    TimboSlice15
    Timothy
    Holly Springs NC
    SR or not, this sounds suspect.
  29. Feb 25, 2022 at 3:54 PM
    #4889
    Xspurt
    Xspurt New Member
    Because of the price?
    TimboSlice15[QUOTED] likes this.
  30. Feb 25, 2022 at 4:04 PM
    #4890
    TimboSlice15
    Timothy
    Holly Springs NC
    Yeah, I went 2 hours away just to pay msrp plus window tent and door edge paint guard that I couldn't decline. There is one dealer 45min away that sells at MSRP with out add on, but they were talking about a 6 month waiting list.
