Official 2022 Tundra 3rd Gen Thread
Discussion in '3rd Gen Tundras (2022+)' started by ColoradoTJ, Oct 13, 2021.
  1. Jan 17, 2022 at 5:39 PM
    #3901
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I have to question his calculations considering how many times he screwed up the test. I believe 20 but 24+ going 70? I really doubt that.
    OnThaLake, VRC and DrZoidberg like this.
  2. Jan 17, 2022 at 5:57 PM
    #3902
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    No problem at all, you encourage me to dig a little deeper. I found a video on YouTube on how to adjust your air suspension preset. The picture you took shows a bracket arm with a nut, that's the preset . Thanks gnc1017
    MTRock, TrimTab and gnc1017[QUOTED] like this.
  3. Jan 17, 2022 at 6:05 PM
    #3903
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Knock on wood, our 2012 Lexus GX460 premium has auto leveling and AVS shocks and it has always worked awesome. Love it, especially on road trips when heavily loaded and windy out. It's more of a handful and tiring until I put it in sport mode and then it's 100% better and less fatiguing to drive. Main reason I'm looking forward to it on a new Tundra, with hopes it will then be our road trip vehicle going forward. Sure hoping Toyota didn't screw up the Tundra's implementation in such a way it can't be corrected.
    Also have it on my 2015 GS450h F-Sport and it's been reliable and works great on it too but with only 25k miles, it's had more age than use...
    TK1979 likes this.
  4. Jan 17, 2022 at 6:05 PM
    #3904
    mountaingroan
    mountaingroan New Member
    North Idaho
    2020 SR5 DC VooDoo 4WD Bench!
    Agreed!
    TrimTab and DrZoidberg like this.
  5. Jan 17, 2022 at 6:07 PM
    #3905
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    Almost 2 mpg more than the trip computer. His test is shenanigans
    OnThaLake, VRC and TrimTab like this.
  6. Jan 17, 2022 at 6:21 PM
    #3906
    Breathing Borla
    AZ
    I thought that as well
  7. Jan 17, 2022 at 6:21 PM
    #3907
    Totherion
    Totherion New Member
    rebmo, TK1979, lonedrake and 4 others like this.
  8. Jan 17, 2022 at 6:25 PM
    #3908
    SnowRunnerTundra
    SnowRunnerTundra New Member
    2022 Hyundai Santa Cruz Limited
    For those in TX, almost all interstate highway has 80 MPH speed limit, and most go 5 mph over so realistic cruising speed is 85 MPH
    would you really go 70 MPH in TX in order to save gas but have 18-wheelers passing you constantly?
    TK1979 and OnThaLake like this.
  9. Jan 17, 2022 at 6:47 PM
    #3909
    Toyota1234
    Jack
    I would.
  10. Jan 17, 2022 at 7:06 PM
    #3910
    SnowRunnerTundra
    I did some test myself, at 85 mph I get 15mpg, and around 70 mph I get 22 mpg, it's crazy just 15 mph difference it wastes so much more fuel. It makes me suspect if big oil was behind the push to increase speed limit as they stand to benefit a lot
    Yota2121, TK1979, Mattedfred and 2 others like this.
  11. Jan 17, 2022 at 7:41 PM
    #3911
    TrimTab
    TrimTab Old man with a beard
    Trim
    New 2022 Tundra Suspension:
    ✅newly developed double wishbone front suspension
    ✅ front suspension benefits from a kingpin offset angle reduction to enhance straight-line stability and high-speed driving
    ✅ caster trail has been enlarged from 25.4mm (1 inch) on the previous generation to 34.1 mm (1.34 inches) for added stability
    ✅ roll steer has been reduced by 25% compared to the benchmarks, and the roll height center has been elevated (152mm compared to 104mm, or roughly 6 inches compared to 4 inches) to reduce body roll, especially when cornering
    ✅ Beefy NEW aluminum forged knuckles for reduced weight , prevents corrosion & stress cracks and there are steel inserts to reinforce ball joints
    ✅Air springs: Available on the SR5, Limited, Platinum and 1794 Edition, rear air springs replace the coils. They can vary rear suspension height up to 2.5 inches, but you can’t pair them with any TRD package. All TRD models, including the TRD Pro, have coils.
    ✅Air springs and adaptive shocks: Available on the Platinum and 1794 are adaptive shocks, marketed as Toyota’s Adaptive Variable Suspension system. They replace the passive shocks but pair only with the air springs.
    ✅ Tundra will feature standard twin-tube shocks at the front and rear of each truck
    ✅ TRD Off-Road package provides monotube Bilstein shocks improve damping for on-and-off highway driving
    ✅ TRD Pro gets even beefier diameter Fox internal-bypass shocks (2.5 inches versus the 1.8 inches for the Bilsteins) plus a 1.1-inch front suspension lift and a thicker front stabilizer bar that’s 20% stiffer.
    ✅AVS system (REMEMBER can only pair with Air Shocks) is designed to adjust damping force based , the AVS features built-in actuators in the FRONT and REAR shock absorbers to continuously change damping force based on the conditions, all to enhance handling, stability and comfort
    ✅ The Tundra hybrid (not available yet) gets unique suspension tuning due to weight differences
    Note you could have air shocks alone except with TRD OR package or combine them with AVS package again not with TRD package
    maxdriver, TK1979, Acedude and 2 others like this.
  12. Jan 18, 2022 at 5:15 AM
    #3912
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    It won't be that bad or going 120 would be normal plus 20L/100km (around 35L/100km) and even my 2020 doesn't get that bad mileage. Every 10kms over maybe.
    Outbound likes this.
  13. Jan 18, 2022 at 5:44 AM
    #3913
    TrimTab
    Trim
    TK1979 likes this.
  14. Jan 18, 2022 at 6:19 AM
    #3914
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Grams per what?
  15. Jan 18, 2022 at 6:40 AM
    #3915
    Toyota1234
    Jack
    Doubt it. But in Montana I know they never had a speed limit but the feds told them they had to have one so they set it to 80 as that was the highest they could. 80 mph is basically no speed limit imo lol
    TK1979 likes this.
  16. Jan 18, 2022 at 6:46 AM
    #3916
    Outbound
    Aaron
    Northern Alberta
    That doesn't seem right. At 100km/h, I average 13.5L/100km. At 120, about 15L/100km. This is in my '05 with the 4.7L V8.
    Mattedfred[QUOTED] likes this.
  17. Jan 18, 2022 at 6:59 AM
    #3917
    xc_tc
    xc_tc New Member
    This is CO2 emissions per mile. Tim kept saying NOx but that’s another story…
    Carbon Dioxide grams/mile is directly correlated to miles/gallon. So as mpg goes up, CO2 grams/mile goes down. We can calculate how much CO2 is produced in the combustion process due to the stoichiometric air/fuel ratio. So 460 grams/mile is about 19 mpg.
    Acedude and Mattedfred[QUOTED] like this.
  18. Jan 18, 2022 at 7:30 AM
    #3918
    yooperbikemike
    yooperbikemike New Member
    2022 SR5 TRD OR Premium CM 5.5
    Does anyone know if the Crewmax TRD Sport 4x4 is available with the 6.5 ft bed?
  19. Jan 18, 2022 at 8:12 AM
    #3919
    There's no perfect formula for how many mpg's you'll lose over 60mph. Depends on a number of factors, like gearing, aerodynamics, engine setup etc. But you are correct that aerodynamic drag really starts to kick in around 60mph and it will take significantly more energy to increase and maintain 60mph or greater. That's why during the oil embargo in the 70's the speed limit was set at 55mph. Safety would be a secondary factor for those speeds, but fuel efficiency was number one.
    TK1979 and gj953 like this.
  20. Jan 18, 2022 at 9:16 AM
    #3920
    flattie
    flattie New Member
    2018 Tacoma Dbl Cab Long Bed Off Road
    If you watch the video he discloses that he passed through a few towns where he had to slow down to 40 or 25 mph and was not doing 70 the entire route - so not all highway speeds and not stop and go traffic but promising nonetheless
    TK1979 and Mattedfred like this.
  21. Jan 18, 2022 at 9:17 AM
    #3921
    Xspurt
    Xspurt New Member
    I seriously doubt it's a linear scale anyway. I'm sure the mpg drops much faster with a smaller and smaller increase in speed once you get above a certain speed, especially with the size and shape of a pickup.
  22. Jan 18, 2022 at 9:20 AM
    #3922
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    Yes, most modern day vehicles are designed to be most efficient at 55-60 mph since that is common highway speed. There's tons of studies out there about it and while every engine is slightly different and has its own nuances, they all have the same relative efficiency graphs.
    TK1979 likes this.
  23. Jan 18, 2022 at 9:34 AM
    #3923
    xc_tc
    xc_tc New Member
    You can’t really apply a catch-all formula to highway efficiency. The aero resistance, rolling resistance, driveline friction, and engine operating efficiency at any given speed can be hugely different from on brand truck to another (even same model with different powertrains). I’d be really curious to see 70 mph vs 80 mph highway cruising mpg.
    TK1979 likes this.
  24. Jan 18, 2022 at 9:59 AM
    #3924
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    9OH1, TK1979, EvilSteve and 2 others like this.
  25. Jan 18, 2022 at 10:19 AM
    #3925
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    EvilSteve likes this.
  26. Jan 18, 2022 at 10:33 AM
    #3926
    Squatting Pigeon
    Holden
    North Texas
    Looks like it might, but I'm sure they'll factor that in to the finished product.
  27. Jan 18, 2022 at 11:23 AM
    #3927
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Yeah, it's exponential. The formula for velocity vs weight vs frontal area is about three sentences long.
  28. Jan 18, 2022 at 4:14 PM
    #3928
    Totherion
    In would say no it is not.
  29. Jan 18, 2022 at 4:17 PM
    #3929
    1SikhTRDPRO
    1SikhTRDPRO New Member
    Just spoke with my dealer in Canada who had the training course on the TRD Pro today, he stated the combined fuel economy is 11.2L/100km or 21mpg-ish.
    ryanwgregg likes this.
  30. Jan 18, 2022 at 4:20 PM
    #3930
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's about what the V8 GMs are getting. :facepalm:
    OnThaLake and TK1979 like this.
