Official 2022 Tundra 3rd Gen Thread
Discussion in '3rd Gen Tundras (2022+)' started by ColoradoTJ, Oct 13, 2021.
  1. Jan 17, 2022 at 8:07 AM
    #3871
    RoddersLV
    RoddersLV New Member
    Rodney
    Las Vegas, NV
    2022 Tundra DOA
    Read all my posts. Ditto issues. Toyota refused to resolve other than wait for parts. Dealership (Findlay Toyoto/Henderson NV) came thru with new truck at their sole expense
  2. Jan 17, 2022 at 8:22 AM
    #3872
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    I haven't been on here in a minute, been a busy holiday season for me. I did get the chance to pick up my 2022 CrewMax SR5 TRD Sport this weekend and put a couple hundred miles on her. Loving it already.
  3. Jan 17, 2022 at 9:02 AM
    #3873
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    This is the combination of airbags, bed cover and spray on bed liner. I believe it's a programming issue with the PSI preset in the airbags. If you have airbags you do not have Springs. Every little dip the truck buttoms out. Anyone else with this combination and problem? This it a picture of where the truck sits with nothing in it. I Put 3 bags of dirt which weighed 300 pounds and it was sitting on the axle. This is not ok.
    Acedude and ryanwgregg like this.
  4. Jan 17, 2022 at 9:08 AM
    #3874
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    What else would you have them do? If they don't know how widespread the issue is, what would be the point of giving you a new truck that may have the same issue?
  5. Jan 17, 2022 at 9:21 AM
    #3875
    Breathing Borla
    Northern Illinois
    good lord man, the beats just keep on coming...
    ryanwgregg and 1UP like this.
  6. Jan 17, 2022 at 9:24 AM
    #3876
    How do you adjust the psi in the system? Shouldn't it be auto load leveling? I don't know enough about the new system in these.
  7. Jan 17, 2022 at 9:27 AM
    #3877
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    The only way it auto levels have it on tow+haul. I believe it has a preset psi and they didn't calculate for bed covers and bedliner weight. I'm not going to get in my truck every day and press tow+haul so that I can have a better ride. I shouldn't have to do that.
  8. Jan 17, 2022 at 9:34 AM
    #3878
    That can't possibly be the way the system is setup. That's terrible if so. It should auto-level regardless of tow haul.
    gnc1017 and ryanwgregg like this.
  9. Jan 17, 2022 at 9:44 AM
    #3879
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    That's not the case ,like I stated I threw 3 bags of sand which weighed 100 pounds each and I rode from Lowe's to my house with the bump stops on the axle. Of course I eventually pushed the tow+haul button and it did self level. Either way the 1st picture I posted is where it sits with nothing in the car and just for daily driving with nothing in the back I shouldn't have to push tow+ haul. You can manually increase the PSI but only up to 18 miles an hour, then auto switches to normal height over 18mph.
    Acedude likes this.
  10. Jan 17, 2022 at 9:46 AM
    #3880
    Where do you adjust between the three available height settings?
  11. Jan 17, 2022 at 9:48 AM
    #3881
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    You have a manual toggle switch underneath the air conditioning settings with a plus and negative.. Handbook States you can deflate airbags for onloading and you can increase PSI for rock crawling and off roading up to 18 mph on both settings..
  12. Jan 17, 2022 at 9:52 AM
    #3882
    So on the normal setting, with 300 measly pounds in the bed, you're riding on the bumpstops. That's terrible
  13. Jan 17, 2022 at 9:54 AM
    #3883
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    Yes my thoughts exactly! Toyota wants me to bring it in but I know there's nothing they're going to do about it. I'll wait until enough people have the same complaint then maybe the programmer can increase the normal ride setting PSI.
  14. Jan 17, 2022 at 9:56 AM
    #3884
    They at least need to separate the auto-level from the tow/haul feature. I wouldn't want to drive around in aggressive mapping mode all the time just because I have a truck topper and some gear in the back.
    Acedude and gnc1017 like this.
  15. Jan 17, 2022 at 9:58 AM
    #3885
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    Correct once you press the tow+ haul button it changes your programming like gearing, breaking and acceleration....
    ryanwgregg likes this.
  16. Jan 17, 2022 at 10:03 AM
    #3886
    OnThaLake
    OnThaLake New Member
    Uh, hopefully doesn't increase "breaking" seems enough is already broken...
  17. Jan 17, 2022 at 10:04 AM
    #3887
    OnThaLake
    I am shocked that the Tundra doesn't use a ride height sensor, just relies on dead reckoning?
    Freaking weird
  18. Jan 17, 2022 at 10:08 AM
    #3888
    Dav123
    Dav123 New Member
    David
  19. Jan 17, 2022 at 10:08 AM
    #3889
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    I’m glad I left off the advanced package on the platinum. Seems like the bags and AVS are more trouble.
  20. Jan 17, 2022 at 10:12 AM
    #3890
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    Absolutely why only on the tow+ haul setting does it have the ride height adjustment. What if I just had suitcases and a load for traveling , that would mean I'd have to put it on tow+ haul to accommodate for the load which changes gearing and most likely bad gas mileage.
    Acedude and OnThaLake like this.
  21. Jan 17, 2022 at 10:45 AM
    #3891
    Jaxyaks
    Jaxyaks New Member
    Toyotas attempt at air bag systems and ride leveling systems etc have always been garbage, its usually the most and sometimes the only problematic feature on any of the vehicles they have put them on. (Lexus etc)....I laughed when I saw that they were offering it on the truck.
    Sorry about your troubles, but while Toyota does build some things better than others, some things they are really terrible at...(I'm looking at you infotainment systems and navigation...lol)
    Yota2121 likes this.
  22. Jan 17, 2022 at 10:46 AM
    #3892
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Well damn. I thought the air suspension was supplemental for the rear coils, not the primary.
    mountaingroan likes this.
  23. Jan 17, 2022 at 10:55 AM
    #3893
    OnThaLake
    I remember trying to find a lightly used LS460 a few years ago. Everyone suggested to find the versions with the "steel suspension" meaning coil springs and not the air ride option. The air ride was very prone to issues.
    Turns out, since I wanted AWD, those with coil springs were like unicorns. I eventually gave up and bought an Infiniti instead....
    TK1979, Yota2121 and Jaxyaks[QUOTED] like this.
  24. Jan 17, 2022 at 12:18 PM
    #3894
    Jonross227
    Jonross227 New Member
    They should have just used the AHC system off the lx570. It's relatively trouble free if you keep up with maintenance and it's stout. Many people pulling travel trailers and boats well over the rating as well as cargo loads over with no issues.
    TK1979 and Yota2121 like this.
  25. Jan 17, 2022 at 12:25 PM
    #3895
    Yota2121
    Yota2121 New Member
    chanon
    2022 Tundra Limited
    None
    gnc1017 posted that you can manually set the psi with an adjustable screw. I'm going to look into this.
  26. Jan 17, 2022 at 12:29 PM
    #3896
    Jaxyaks
    Jaxyaks New Member
    While it may be stouter than some, a quick google search of LX570 AHC system yields forum pages upon pages of AHC system problem threads and issues as well.
    What they should have done (if they wanted to keep the tundra legendary reliability in tact) is offered a payload package with better springs to compensate for the toyota notoriously inadequate soft springs and leafs. Or they could have done what Ram did with their 2500 coil spring set up and added a shock in the middle.
  27. Jan 17, 2022 at 1:35 PM
    #3897
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Chilema, TK1979, MTRock and 3 others like this.
  28. Jan 17, 2022 at 5:13 PM
    #3898
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
  29. Jan 17, 2022 at 5:27 PM
    #3899
    gnc1017
    gnc1017 New Member
    22 Tundra Platinum Hybrid 6.5 Blueprint
    1.75 leveling kit Nitto Ridge Grappler tires (305/55/20) Black Rhino Arches Gunmetal wheels Truxedo Deuce cover w/ TonneauMate box
    Sorry if I caused confusion. The screw adjust picture I posted was for headlight adjustment, not for the air ride. Hopefully, that screw adjustment will allow resetting of the headlight height (especially for those with the auto-level feature) when a front leveling kit is installed.
    They've got to fix the auto-level when not in tow mode. Only reasonable option.
  30. Jan 17, 2022 at 5:28 PM
    #3900
    4WDWalrus
    The Silver Walrus
