Off-sized spare
Discussion in 'Wheels & Tires' started by focal, Nov 21, 2019.
  1. Nov 21, 2019 at 11:49 AM
    focal
    focal [OP] and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    Curious, I believe my spare is the factory wheel size; however, I have 35’s on the hubs.
    If I were to get a flat, could I safely drive a 4x4 with an irregular sized wheel up to 100 miles, not considering tire wear but damage to the front end.
    Also, are you able to fit a 35” spare under the bed in the spare tire spot?
    Thanks.
  2. Nov 21, 2019 at 11:58 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    i dont think you would do any long term harm. a spare to get you to the nearest rest stop or shop would be ok.
    i think you can fit a full sized 35" spare under the bed. I believe you can also fit an aired down 37". but overall, youd be ok
    focal[QUOTED][OP] likes this.
  3. Nov 21, 2019 at 12:01 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    You want to put the off-sized tire in the front not the rear. So if you're replacing a rear tire, move a good one from the front to the rear then the spare to the front.
  4. Nov 21, 2019 at 12:02 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    I’ve seen a thread on here that showed 35’s up under the truck. I think they had to bend or cut the tabs, but it was there and looked pretty tight. As far as driving like that with such a difference could possibly cause issues. I’m running 295/70/18 and bumped my spare up to a 275/70/18 it’s not exact but it’s closer than the factory spare. Only reason I didn’t go full 295 for the spare was the fact that we didn’t know if it would clear the upper control arm in the front.
    focal[OP] and Rica25 like this.
  5. Nov 21, 2019 at 12:26 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I have a 35x12.50 spare under the bed - I had the remove the guides but the tire fits fine with ToyTec shackles (it may not have fit with Coachbuilder shackles). The tire is mounted to a matching wheel so I know it will clear the UCAs. @MAGDADDY brings up a good point - if you are running stock wheels (+60 offset) without spacers then you may have issues with a 12.5" wide tire clearing the UCAs.
    TheBeast, focal[OP] and MAGDADDY like this.
  6. Nov 21, 2019 at 12:30 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    You shouldn't have any problems as long as you don't put it in 4 wheel drive.it could cause the transfer case to bind the gears.like someone else said, I wouldn't drive it like that very long
  7. Nov 21, 2019 at 1:37 PM
    focal
    Nikolai
    VA / NC
    Thanks everyone!
    Could the spare rim have a different offset that may not clear the UCA’s with a 35 and my best bet would be to use a stock matching rim with a 35? The truck currently has the 17” stock rock warrior wheels with 35’s. I don’t believe there are spacers but I’ll know next week when I take ownership.
    thanks again for everyone’s help!
    Rica25, sr5shark[QUOTED] and MAGDADDY like this.
  8. Nov 21, 2019 at 1:50 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Since the wheels are OEM, it seems unlikely that the offset of the spare would be different (+60). Are the tires on the Rock Warriors 35x12.50? If they are, there is a chance that wheel spacers are already installed. I have heard of some running 12.5" tires on stock wheels with no spacers but the tire is really close to the UCA. If you do any off-road driving at all you will want a little more space between the tire and UCA so if there are no spacers installer then it is pretty inexpensive to add them.
    Rica25 and focal[OP] like this.
  9. Nov 21, 2019 at 1:52 PM
    TheBeast The Beach
    if you run 35"s best to have matching spare and that includes the rim with proper offset. You can always deflate the spare a bit since most likely you have air on board and fit it underneath the bed.
  10. Nov 21, 2019 at 5:58 PM
    focal
    Nikolai
    VA / NC
    I believe they are 35x12.5”. I’ll have to report back next week after I give the truck a run down and check for spacers. Thanks!
    Rica25 and sr5shark[QUOTED] like this.
  11. Jan 14, 2020 at 5:35 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Has anyone fit a 35" spare with CB shackles?
    Rica25 likes this.
  12. Jan 23, 2020 at 6:06 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    ^^this.
    I’m trying to come up with a solution as well. I need the lift of the CB +3 shackle but can’t get my 35x12.5 spare to fit. I’ve got a little room forward. I’m thinking of fabing some brackets and a spacer to mount it at a slight downward angle to the front of the truck.
    Rica25 likes this.
  13. Jan 23, 2020 at 6:26 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I believe that's a no go with the CB shackles.
    Rica25 likes this.
  14. Jan 23, 2020 at 6:26 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  15. Jan 23, 2020 at 6:30 PM
    cook2kill
    cook2kill PNW
    Portland OR
    2018 CM
    I’m thinking with some kind of plate mounted between the spare and the bottom of the bed that I could tighten the tire forward and with a little tilt and it would clear.
    Seems to be enough room before contacting the diff and I would only need to slightly relocate the DD resonator.
  16. Jul 5, 2021 at 4:52 PM
    shdwkeeper
    shdwkeeper New Member
    2013 Magnetic Gray Tundra 4x4 Limited CM
    Diamondback Bed Cover (Line-X) Bed Rug Mirror Caps (Paint Matched) Door Handles (Paint Matched) 2020 Sequoia TRD Grill Conversion Morimoto XB Fog Lights Alpharex Pro Jet Black Headlights HIKARI 2021 Acme-X H7 LED Bulbs 6112 (top setting) / 5160 Combo @Coachbuilder1 Differential Drop Kit 1.00" @Coachbuilder1 Coilover shims (2 drive-side 1 passenger side) @Coachbuilder1 Front Bump-stop extensions @Coachbuilder1 Front Bumper Shims @Coachbuilder1 +3 Shackles Fuel Vector 18" +20 Wheels 35x12.50x18 Nitto Ridge Grapplers RCI Off-road Engine Skid plate Desert Eagle Off-road transmission/catalytic converter protection plate Interior: VLEDs 5K cabin interior + LED strip footwell Coupe Custom Battery Mount WeatherTech Floor Mats
    I put a 285/75/18 Terra Grappler G2 (used) in the stock location. I think overall diameter is 34.84in. Thought this would be a great spare for my 35x12.5x18 Nitto Ridge Grapplers. I also have the Coachbuilder +3 shackles. Had my tire shop air hammer out the stock tire guides, than I painted it with black Rustoleum spray paint. Here are some pics.
    20210705_120636.jpg 20210705_122018.jpg 20210705_144038.jpg 20210705_150118.jpg 20210705_150044.jpg 20210705_150147.jpg 20210705_150101.jpg 20210705_150129.jpg
  17. Jul 5, 2021 at 6:10 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    @shdwkeeper So that’s on the stock spare rim? Will it fit if you don’t have shackles? I plan on putting the same size tires on with Ray10s, but if I don’t have to buy a full size spare that’s a win.
  18. Jul 5, 2021 at 6:22 PM
    biebs96
    PA
    yes it will fit.
    I have a 285/75/18 on the stock spare rim and it fits just fit.
    Stock rear shackles as well
  19. Jul 5, 2021 at 6:33 PM
    shdwkeeper
    YES, stock spare rim. You will have more room without these shackles, as these shackles are pretty beefy.
    GELCW[QUOTED] likes this.
  20. Jul 5, 2021 at 6:47 PM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    Thanks!
  21. Aug 10, 2021 at 9:30 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    At what size do you need to remove the guides? Would a 275/70R18 fit without removal of the guides?
    gosolo likes this.
  22. Aug 10, 2021 at 10:06 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I have 275 70 18s and have a matching spare, they fiit in the space with no problem
    French Avocado likes this.
  23. Aug 10, 2021 at 10:14 PM
    TheBeast The Beach
    i kept my 295/70/18 toyo AT2 as spare. I run 35 K02 all 4 corners and the height is almost identical. the 35 are slightly wider which doesn't matter really for a spare.
    I did cut the guides and run the same aftermarket rim.
  24. Aug 10, 2021 at 11:29 PM
    shdwkeeper
    I had a tire shop air hammer my guides off as shown in previous pictures and I painted it with black paint. Not that hard if you have right tools.
  25. Aug 11, 2021 at 7:50 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Yes, you just need to guide the spare up and to the left as you raise it if memory serves correct.
    Especially with Coachbuilder Shackles.
    Fits like a glove up there.
  26. Aug 11, 2021 at 7:58 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    Huh? Why is that?
  27. Aug 11, 2021 at 8:07 AM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    I have a matching wheel and tire underneath. 35x12.5 17. Coachbuilder shackles as well. I have no issues with rubbing or fitment. Had to grind off the factory guides as well as a couple small pieces on the part that holds the wheel up there. Been about 25k miles now no issues.
    shdwkeeper likes this.
  28. Aug 11, 2021 at 8:54 AM
    Black
    You want your drive wheels to be as close to the same diameter as possible especially with the electronic limited slip business. So you don’t induce too much binding in the differential.
    Of course if you are using 4wd you’ll have the same issue by putting it on the front.
  29. Aug 11, 2021 at 9:31 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    OK...I would have thought it would throw the steering into turmoil. I'll at least remember to turn TC and everything else off if that scenario presents itself.
  30. Jun 27, 2022 at 2:25 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    So I have 285/75/18 tires (34.8" tire) on stock TRD rims and been looking at getting that same tire size on my spare rim. I dropped my spare tire and took some measurements.
    Coachbuilder shackle to shackle is only 33 inches
    Back of truck (bumper/license plate area) to resonator location for BA midpipe is 33 inches
    How have y'all been able to get a larger tire to fit? I don't want to bite the bullet and mount a brand new tire on my spare rim just to find it not be able to fit anymore?
