OEM Wireless Charger & new iPhones?
Discussion in '2.5 Gen Tundras (2014-2021)' started by trd.james, Jan 4, 2021.
  1. Jan 4, 2021 at 5:50 AM
    trd.james
    trd.james [OP] New Member
    James
    2020 TRD PRO | Westcott Lift | 35" KO2's
    Does anyone else have a new iPhone 12 model and have issue with the wireless charger that Toyota started putting in the console lids in 2020? Mine worked great with my older iPhone but the new one won't stay connected. I think it's that the camera bump is so much bigger, it creates an air-gap between the phone and the charger itself and/or the phone slides around and loses it's magnetic connection. I think an anti-slip mat would actually fix the problem...if anyone knows of one that fits in that space well?
    richiewestside likes this.
  2. Jan 4, 2021 at 7:09 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I’ve had problems with my iPhone 12 Pro also. I’ve had the metal band around the outside make the red light come on and when it doesn’t, it’s very finicky about the position as you said. I’ve pretty much given up on it. It has to be plugged in for CarPlay to work anyway.
  3. Jan 4, 2021 at 7:19 AM
    Kung
    KG, VA
    Agree w/the others; and it's not just the charger in the truck. I've got an older wireless charger that worked fine with my iPhone 11, but it's almost impossible for the iPhone 12 to charge on it.
    War Machine and trd.james[OP] like this.
  4. Jan 4, 2021 at 7:21 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Yep same here. Apple put out an update that seemed to briefly fix the issue but now mine is having problems again.
    Something changed in the 12 that is making them less compatible with previous wireless chargers. Had one in my house that stopped working as well once I got the 12
    trd.james[OP] likes this.
  5. Jan 4, 2021 at 7:24 AM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Have you had any luck with the phone face down OR maybe backwards with the camera facing the rear seats? Does it charge okay that way? I started with the wireless charger after removing it from my 2015. I started using Android carplay more and will probably be getting rid of the Toyota wireless charger.
    Hope you find a solution.
  6. Jan 4, 2021 at 7:29 AM
    trd.james
    James
    I would suggest you pick this up...it works flawlessly for me (now, post software update on the dongle itself). It's really nice. I hid it under the cupholder console with a $5 usb right angle extension cable. I can find the thread on here with pics and link it if interested. Very clean.
    https://www.amazon.com/gp/product/B085VVCLKR/ref=ox_sc_saved_title_6?smid=A1EE5VCGDAEB07&psc=1
    But, back to the wireless charging point. Thanks for your input. I'm guessing it's a lost cause which is too bad.
  7. Jan 4, 2021 at 7:31 AM
    trd.james
    James
    Interesting, I didn't know it affected other wireless chargers. I've only used the Nomad wireless charger (which works fine on the 12 Pro Max) and Apples MagSafe charger...so for me the Truck charger was the anomaly. I see that isn't the case now.
  8. Jan 4, 2021 at 7:51 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    Thanks for the info, I’ll check that out.
  9. Jan 4, 2021 at 9:00 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    FWIW/YMMV
    My iPhone 12 mini has the same problems on my existing wireless charging stands. It wouldn’t charge on any of them all of the sudden. It still happens occasionally. What I do is completely
    Power down the phone and restart it, then my wireless charging works as it should. Also I’m running a thick Speck case (14’ drop test) mil spec etc, etc. it’s not the iPhone magnetic case or whatever they’re calling their wireless charging compatible cases.
    https://www.google.com/aclk?sa=l&ai...wjB0tLj4oLuAhVPtZ4KHcy9B0YQwg96BAgBECM&adurl=
  10. Jan 4, 2021 at 10:36 AM
    Kung
    KG, VA
    Yep. With that said, as an IT guy (translation: nerd LOL), I'm not too worried about it. While it may not look it, there are a *LOT* of changes under the hood this year for the iPhone 12 from last year:
    - all of them have OLED screens
    - all of them use Qualcomm modems (FAR better reception)
    - better camera
    - 5G
    - FAR better screen (I've actually intentionally TRIED to scratch it and am as of yet unsuccessful lol)
    - spiffy iPhone 5-like design
  11. Jan 4, 2021 at 10:45 AM
    ssnyt
    ssnyt New Member
    2019 Tundra Pro
    a lot of people have been complaining about this issue over several forums, not vehicle related. apple once again shit the bed.
  12. Jan 4, 2021 at 10:45 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    My iPhone 12 suffers the same wireless charger issue as most-have to reboot. Fortunately I am not a iPhone person, it is a seldom used phone which I do not rely on.
  13. Jan 4, 2021 at 10:50 AM
    War Machine
    War Machine SSEM # 5 3MW
    Same here.
  14. Jan 6, 2021 at 5:48 PM
    trd.james
    James
    Does anyone know of an anti-slip mat or some kind of insert that fits that console lid phone tray? I can't find anything that looks to be made for the tundra except the one that has the cut outs for the non-wireless charging version.
  15. Jan 7, 2021 at 6:54 AM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Do you mind showing how you routed this? You purchased the Audi version?
  16. Jan 7, 2021 at 6:59 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Sorry that you are experiencing issues. I purchased the add-on wireless charger on the console lid (from Sparks) for my 2019. It works well with my iPhone 12 Pro Max with a Tendlin case.
  17. Jan 7, 2021 at 7:04 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I’m curious if you had a case on the phone that made the camera bump flush with the phone body if that would make a difference
  18. Jan 8, 2021 at 5:29 AM
    trd.james
    James
    Yes, I bought the Audi version. I don't think there is actually a difference in versions, but I bought the Audi one either way.
    As for the routing, I did the same thing that this guy did...post #60. https://www.tundras.com/threads/wireless-carplay-for-those-with-2020s.69222/page-2
    Only difference is where his wire goes off to the left kind of, I fed it straight down.
    I used this usb right angle extension: https://www.amazon.com/gp/product/B07NL5DDRJ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
    Here's a pic of mine: [​IMG]
    Gabrielo93 and gabex35[QUOTED] like this.
  19. Jan 8, 2021 at 5:31 AM
    trd.james
    James
    I do think that would make a difference. I don't use a case on my phone and am not willing to to make the charger work...but if the back of the phone were flush because of a case, my guess is that it would work.
  20. Jan 8, 2021 at 5:39 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    And here are some pics under the console:
    https://www.tundras.com/threads/wireless-carplay-for-those-with-2020s.69222/page-2#post-1813546
    trd.james[QUOTED][OP] likes this.
  21. Jan 11, 2021 at 3:58 AM
    token2k6
    token2k6 New Member
    2021 Tundra CM SR5
    I was able to get the wireless charger installed in my 2021 Saturday morning, in pajama pants, while everyone else was sleeping. Easy install, great mod! I don't have a wireless charging phone (OnePlus 8 5G) but my wife has the iPhone 12 Pro, and my youngest has the 12 Mini. Obviously no dice with a PopSocket and case, so have to take those off; the phones don't charge face down either. Took a drive around town and the 12 Pro would go to red after every turn! Holding it in place seems to help. The 12 mini was a little better, but if it slid too far to one side, it would go red as well.
    I did the mod just to have it since it's OEM, knew I wouldn't really use it, doesn't seem great. I think more phones will come out with thick back bezels around the cameras like this. Maybe someone will 3D print, or make with foam, a spacer per phone size to really hold it in the center...
  22. Jan 11, 2021 at 4:07 AM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
    I almost upgraded to iPhone 12, may be I'll hold off for now. I think it has to do with the new Magsafe feature. The 12 now has a magnetic ring around the charging mechanism, thus probably a smaller area of contact where it can charge from. Apple is probably going to push selling MagSafe compatible accessories.
    Gabrielo93 likes this.
  23. Jan 11, 2021 at 4:14 AM
    MatD13
    MatD13 New Member
    2018 Limited Cement Crewmax 4x4
    I went from Samsung to the 12 pro 2 weeks ago and I haven’t had a problem with the charger
  24. Jan 11, 2021 at 4:40 AM
    Gabrielo93
    Gabrielo93 New Member
    Gabriel
    Grand Prairie, TX
    2015 Black Toyota Tundra SR DC
    12 Volt Remote Starter Lockerdown Safe ICS Fab Dash Mount Husky All Weather Beaters Mats Rear Folding Seat Mod Linex Platinum Kicker Sub/Amp Combo CoverCraft Dash Cover Kenwood Headunit Cravenspeed Untenna CupHolderHero Aukee Tailgate Inserts OEM Deck Rails Rolling tonneau cover CravenSpeed Untenna
    I use the MagSafe charger with these. But I also bought these to replace the 17mm ball mount.
    BESINPO for Magsafe Car Mount, 360 Degree Rotation Dashboard Phone Stand Holder Hands Free Mount with VHB Adhesive Mounting Base for iPhone 12/iPhone 12 Pro/iPhone 12 Pro Max/iPhone 12 Mini https://www.amazon.com/dp/B08ND8FCCD/ref=cm_sw_r_cp_api_glc_fabc_GBe.FbBZ1SZ44?_encoding=UTF8&psc=1
    iBOLT Aluminum 17mm AMPs Adapter Plate - for Garmin GPS Devices, iBOLT Smartphone Holders and Other Industry Standard 17mm adapters https://www.amazon.com/dp/B01HU6G6NG/ref=cm_sw_r_cp_api_glc_fabc_HCe.FbRKXTN8D?_encoding=UTF8&psc=1
    Will post picture mounted later today when off of work.
  25. Mar 28, 2021 at 11:39 PM
    emdcksn
    emdcksn New Member
    Eugene
    Eugene OR
    2021 MGM Tundra Platinum CrewMax
    My 12 Pro Max hasn’t worked with my Qi charger since day one. Works great with MagSafe of course.
