OEM Tonneau Cover Side Rails
Discussion in 'Toyota of Cool Springs Parts' started by j45lvr, Nov 2, 2020.
  1. Nov 2, 2020 at 2:33 PM
    j45lvr
    j45lvr [OP] New Member
    james
    2017 Tundra Limited
    I bought a Toyota OEM hard tonneau cover used, but it didn't come with any hardware or side rails. Does anyone have a source?
  2. Nov 17, 2020 at 8:38 PM
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    I checked with Toyota as I am looking at a used OEM tonneau tomorrow and posted instructions and parts below.
    Does it have the gutters?
    While the instructions say it requires a the deck rail system, I don’t think you need them. If you had rails you would remove them and use the 5 bolts to secure the gutters and brackets on each side. Then you would re attach the rails to the lower notches on the brackets.
    attached are the installation instructions I got from the dealer and another post on here. It may indicate part numbers for you to see what you need.
