OEM Tonneau Cover Fit
Discussion in 'Tonneau Covers, Caps and Shells' started by jsquared22, Mar 22, 2018.
  1. Mar 22, 2018 at 7:27 AM
    jsquared22
    jsquared22 [OP] _________________
    2018 White Tundra Platinum
    I recently purchased and installed a used OEM Tonneau cover for my 2018 Crewmax. Despite following the installation instructions, the Tonneau cover fits a bit loose with approximately 3/8" of vertical play near the rear. I'm mostly concerned from a security perspective. The price was right, so I can't complain, but it's not immediately obvious to me how to adjust for this situation. The rails appear to be too high. The only adjustment that I'm aware of is the set screw on each side rail near the front. Any ideas?
    Video https://www.amazon.com/photos/share/Eda6kErLRB8WivGVfe7jvxa5M3gloEWuN704GdPe0mv
  2. Mar 22, 2018 at 7:45 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t know much about that cover but maybe you could find some heavy duty vinyl of the right thickness and adhere it to the underside of the bedrail. So when you shut the cover you have to push down on it to get it to tightly latch.
  3. Mar 22, 2018 at 3:09 PM
    jsquared22
    Thanks 15whtrd for the response. I agree that your recommendation would work (and might be my attempt at a quick fix) but hoping someone is familiar with this condition and has additional ideas.
    15whtrd[QUOTED] likes this.
  4. Mar 23, 2018 at 5:54 PM
    jsquared22
    Anyone else have a recommendation? :)
  5. Mar 23, 2018 at 6:09 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    @15whtrd pretty much nailed it. Your cover is almost identical to the Extang Encore, which has no vertical adjustment to the latches. Extang provides a couple of vinyl pieces, similar to door edge guard, to take up that gap and the play in the cover.
    15whtrd likes this.
  6. Mar 23, 2018 at 6:14 PM
    Borgs
    Borgs New Member
    PA
    Isn’t the OEM cover just an Extang with a Toyota badge and an extra $500?
    15whtrd likes this.
  7. Apr 10, 2018 at 10:04 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Is that in the front by the cab? If so, in the instructions I read, there is supposed to be a foam seal that runs across the top rail. I'm buying a used one as well and will have to come up with that too.
  8. Apr 10, 2018 at 12:08 PM
    duece292
    Greg
    Green Bay, WI
    The looseness of the latches is usually at the rear. You will need a foam or rubber gasket at the bulkhead. I usually try to use a closed cell foam that I can tuck under the edge of the bedcaps. Tucking it helps to seal the corners as well as closing the seam where the bulkhead meets the bed sides.
  9. Apr 10, 2018 at 1:02 PM
    SnrDisregardo
    Wade
    IL
    Thanks. I couldn't tell from his picture if that was up front or in the rear. I will keep that in mind for when I go to install the one I get.
  10. Apr 10, 2018 at 2:47 PM
    jsquared22
    It's the rear of the truck at the tailgate. Extang sent me a shim kit, which helped a little, but still seems a bit loose. Here's how it appears with shims.
    Video
