OEM steering rack bushing acceptable wear limits?
Discussion in 'Suspension' started by J.A.T.O., Feb 29, 2020.
  1. Feb 29, 2020 at 8:44 PM
    J.A.T.O.
    J.A.T.O. [OP] New Member
    Hawaii
    2013 Tundra SR5 Crewmax 4x4
    Bud Built skid plates, Fox TRD Pro suspension, Nitto terra grapplers
    Does anyone know the “within limits” play range for steering rack bushings?
    I’m trying to track down a popping feeling in the steering wheel while driving; and a “clunk” when turning hard left at low speeds.
    My skid plates are removed and steering rack has no leaks or firm boots. Tie Rod ends are tight as well as wheel bearings. U joint in steering column seems tight also.
    However I can see left right movement in the rack and pinion that coincides with the “pop” felt in the steering wheel.
    It feels exactly like a worn out U joint in the steering column of an old Silverado.
    2013 5.7 4x4 CrewMax 102k on TRD pro fox suspension with 275/65/20 nittos.
  2. Mar 3, 2020 at 7:34 AM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Sounds like it might be your steering rack bushings.
  3. Jun 22, 2020 at 2:44 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Earlier today i diagnosed my bushings were bad. After that i was talking to another server friend that works at a 4x4 shop and told me this secret.
    "Clean with brake clean all over...so the tape sticks real good to the heads of the bolts and whatnot...make sure the vehicle is on the ground and do the steering wheel wiggle...preferably not running so the wiggle really wiggles the rack up a bit. If the tape breaks its time for new bushings"
