Oem oil filter question
Discussion in '3rd Gen Tundras (2022+)' started by Northern Toyota, Sep 28, 2024.
  1. Sep 28, 2024 at 9:06 PM
    Northern Toyota
    Northern Toyota [OP] New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    My local parts counter gave me a 90915-yzzf1 oil filter for my 2023 tundra. What made me look up the part number was I noticed that my oil pressure goes to 3/4 on the gauge at startup and when driving pressing on the accelerator pedal any amount. Is this filter going to hurt my truck or is it acceptable? I have ZERO faith in my local service department and now parts department.
  2. Sep 28, 2024 at 9:35 PM
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    It will most likely be just fine. The F1 filter and the part # it calls for(90915-10010) are very similar. And all Toyota filters have the by pass built in and the anti drain check. My gauge also goes up to 3/4 on start up. Haven’t really paid attention to what it reads while accelerating, but I would image it should increase as throttle increases
    Ausfahrt likes this.
  3. Sep 28, 2024 at 9:36 PM
    Northern Toyota
    Tires and bilstein
    Thanks. I did a little cross referencing and see Fram lists all kinds of Toyota PN’s as acceptable to their own PN for tundra oil filter. Just had me a little worried at first.
  4. Sep 28, 2024 at 11:55 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    That’s how oil pressure works.
    Hella Krusty likes this.
  5. Sep 29, 2024 at 6:42 AM
    Northern Toyota
    Tires and bilstein
    No kidding, thanks for the insight.
    was more concerned because I didn’t remember my oil pressure this high for the previous 15k before I just changed my oil with this filter.
  6. Sep 29, 2024 at 7:13 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    My dealer did the same thing, and they work fine. Their outer dimensions are just a couple mm different from the 9xxxx but the threads and mating surfaces are identical. Lately I have been ordering the 9xxxx P/N filter but the ZZF1s are widely available at Wally World stores and other retail outlets so if you need one quick that is easier than going to the dealer.
    I started a topic on this very issue a year ago and it contains lots of discussion and photos. I'll try to find it and link it here later when I have time.
    TundraDan723 likes this.
  7. Sep 29, 2024 at 7:38 AM
    Northern Toyota
    Tires and bilstein
    Thanks. I actually did a Google search and it yielded me the thread you speak of. I read it all, well I skipped over the oil filter arguing about fram haha
    steveh and raylo[QUOTED] like this.
  8. Sep 29, 2024 at 8:09 AM
    Danman34
    Danman34 New Member
    Danny
    Ambient temps are dropping. Even a 10* difference changes the viscosity of the oil. The gauge is going to fluctuate. It’s more just a dummy gauge anyway. Having oil higher pressure isn’t a bad thing. It simply means you have good flow. As the engine gets hot, the oil becomes more viscous so it will inherently drop a little in pressure. I would be more concerned of low pressure as that could indicate blockages as the sensor is downstream.
    Hella Krusty and Tundrum74 like this.
  9. Sep 29, 2024 at 8:17 AM
    lapoolboy
    lapoolboy New Member
  10. Sep 29, 2024 at 3:20 PM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I recently bought a filter at the dealer, was a bit over $9. First two I bought were a bit over $13 for both. My son came home that Monday with a whole box of Toyota filters, for a bit over $6 per. :)
  11. Nov 9, 2024 at 4:56 PM
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    I’m ready to do my first 1,000 oil change and picked up the OEM oil filter from a local dealer. Holy smokes - this thing is sooo small! Later today I compared the filters for the Toyota engine (3.4L) and the Yamaha Waverunner (1.8L) and the latter is bigger. Is the size of the OEM Toyota filter not a concern???
    FrenchToasty likes this.
  12. Nov 9, 2024 at 5:03 PM
    VCheng
    VCheng New Member
    Upstate NY
    Factory installed self-destruct device :D
    Or does it? Media type and total cross sectional area, anti-drain back valve, bypass pressure etc.? Perhaps.
  13. Nov 9, 2024 at 6:10 PM
    Hella Krusty
    Hella Krusty New Member
    Size doesn't matter apparently
  14. Nov 9, 2024 at 6:11 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I did the same thing. Got a box of the original filters from Toyota and paid about $7 each plus tax. I have enough to last me awhile lol
    SilveradoSwap[QUOTED] likes this.
  15. Nov 9, 2024 at 6:15 PM
    GREENPUS
    GREENPUS New Member
    Scott
    I’m just happy it’s not a Toyota cartridge filter. My 2018 RAV4 had one and it was a pain in the ass to change. I had to buy a special tool to remove it which wasn’t cheap. One good thing, the tool fits the OEM Tundra oil filter too
    Raven67 likes this.
  16. Nov 10, 2024 at 8:27 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    Same filter as a -10010. One is made in Japan and the other in Taiwan.
    *Note to all, pre-order your Toyota filters from your dealer online for WillCall pickup and you’ll get them for $7. If you walk in and buy at the counter they’ll charge you $13 or more. Same for all parts.
    Raven67 likes this.
  17. Nov 10, 2024 at 8:32 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Walmart has Toyota filters about $7.50
    Just bought one for my daughter in law TRD Camry
  18. Nov 10, 2024 at 9:08 AM
    VCheng
    VCheng New Member
    Upstate NY
    I have a 2018 Landcruiser with the cartridge filter, and I am not a fan of those, just like you. My son's 2022 RX350 has it too, but it is a bit easier to change than the Lc, given its lack of skid plates.
    The only upside I can think of is the ability to see any glitter etc. in the media without cutting open a spin on filter.
