OEM LED Headlight upgrade?
Discussion in 'Lighting' started by Tuckerman048, Nov 13, 2022.
  1. Dec 1, 2022 at 6:06 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I have a truck with halogen lights and the LED DRL strip on the bottom only, I needed the harness. Its the easiest version to convert, but you still need the harness.
    jonclark96 likes this.
  2. Dec 1, 2022 at 6:50 AM
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    Why did you need the Harness? Is there N issue with the lights not being a direct plug and play, or was it to prevent hyper flash from the turn signals?
    I have been told from multiple sources that the harness is not needed as long as your 2020 or 2021 had LED DRL’s from the factory.
  3. Dec 1, 2022 at 7:01 AM
    MadMaxCanon
    Not sure of the reason to be honest, i just know that when I read iHackers how to, he specifically has a section for halogens with the LED strip. All the connections from the OEM LED and the iHacker harness fit and lined up so I am not sure why he would create one if it wasnt needed.
  4. Dec 1, 2022 at 7:03 AM
    Shaff777
    Justin
    Boise
    2020 cement SR5
    Thanks for the response- I appreciate it. move reached out to him directly as well to clarify :)
    MadMaxCanon likes this.
