OEM LED Fog light bulbs in OEM Fog light housing
Discussion in 'Lighting' started by GATORthaBEAST, Nov 18, 2022.
  1. Nov 18, 2022 at 9:02 PM
    GATORthaBEAST
    GATORthaBEAST [OP] New Member
    2019 Tundra SR5 2WD Silver Sky Metallic
    18x9 METHOD MR312 w/BFG A/T KO2s, TRD DUAL EXHAUST, TRD PRO SKID PLATE, BLACK TOYOTA NERF BARS......work in progress.
    Hello, my friend just put new LED fog lights in his 4Runner. He said I could have his OEM LED fog lights, which from what I read are the same for Tundras, 4Runners, Tacomas. Would I be able to take the LED bulb from the his OEM LED fog lights and put them in the housing on my OEM fog lights after removing the halogen fog lights Or should I just switch the entire thing out? I couldn’t find much here on the forum. Hopefully my question makes sense. Thanks for your help.
  2. Nov 19, 2022 at 5:14 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    You should switch the entire assembly. Oem led fogs are cheap and a great upgrade. The housing internals of led and halogens are completely different, you can't just switch bulbs.
    Taco-Spike likes this.
  3. Nov 19, 2022 at 5:22 AM
    Taco-Spike
    Two Trucks
  4. Nov 19, 2022 at 6:40 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I kept the stock fogs and installed Alla LED switchback bulbs and love it. White color matches the TRD Pro LED headlights and I can switch them to yellow for fog and rain. About 50 bucks, easy install in factory fog halogen housing.
    Yakisoba and Taco-Spike like this.
  5. Nov 19, 2022 at 7:22 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That's pretty cool.
    Changes from white to amber just by turning them on and off.
    If I still had my OEM fog lights I'd be all over that.:thumbsup:
    Amazon.com: ALLA Lighting H8 H9 H11 LED Switchback Fog Lights, High, Low Beam Conversion Kits, DRL, Dual Color 6000K White/3200K Yellow 12V H16 H8LL H11LL H965W, Extremely Super Bright 8000 Lumens : Automotive
    MadMaxCanon likes this.
  6. Nov 19, 2022 at 8:49 AM
    frichco228
    Yes, they have been great! I looked into switching out the fogs to factory LED or something else when I installed the factory LED headlights, but these things fit my needs, easy install and cost was great. They perform really well.
    Yakisoba likes this.
