OEM Bed Mat - Anyone using it?
Discussion in '2.5 Gen Tundras (2014-2021)' started by LastCanadianExit, May 22, 2017.
  1. Jun 15, 2017 at 6:30 PM
    #61
    15whtrd
    15whtrd Mr. Blonde
    Find the exact center of each hole take out the bed mat and set it on the piece of plywood or material of your choosing and drill it out with a holesaw. Or razor knife
    PaulROahu likes this.
  2. Jun 15, 2017 at 6:33 PM
    #62
    Basskrazee
    Basskrazee Pop
    Joe
    Indianapolis, IN.
    2016 Tundra SR5 /TRD
    AFE mass air intake TRD rear anti sway bar Headwaters seat covers TRD Pro grill Bilstien 6112 coil overs Bilstien 5160 rear shocks Consol vault
    I've got both in the bed and would do it again
  3. Jun 15, 2017 at 6:49 PM
    #63
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    I was thinking hole saw too an i have almost every size but i think the rubber would gum up very quickly. Maybe cut a hole in a piece of 1/2" plywood and use it as a template to guide a razor knife. I cant imagine it would be too nasty to cut but wanted to check here first.
    15whtrd[QUOTED] likes this.
  4. Jun 15, 2017 at 7:08 PM
    #64
    15whtrd
    15whtrd Mr. Blonde
    Just for fun after you're done cutting out the first one try a smaller holesaw on that leftover piece and see if it gums up.
  5. Jun 15, 2017 at 7:30 PM
    #65
    Tacogrande
    Jeremy
    Will Do. ...hmmm Maybe i could screw a razor blade to the holesaw.?
  6. Jun 15, 2017 at 7:31 PM
    #66
    CarlitosWay
    CarlitosWay New Member
    Carlos
    How about using a jigsaw?
  7. Jun 15, 2017 at 9:32 PM
    #67
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Razor
  8. Mar 25, 2025 at 10:47 AM
    #68
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    Did Toyota discontinue the oem bed/cargo mat? What brand is the next best option? I have sprayed in bed liner which serves its purpose but also scuffs up items. I prefer the rubber mat for traction and cushion. I am partial to oem but can’t find it on dealer websites.
  9. Mar 25, 2025 at 8:08 PM
    #69
    d33pt
    d33pt New Member
    I use the Bed Rug bed mat over Rhino Liner. Mostly because it makes it flat without the ribs, and much softer on the knees. It is also much lighter than the thick rubber bed mat. About $100 and comes with the tailgate portion which also covers up the gap between the bed and tail gate. That's really nice when hauling rocks or mulch.
  10. Mar 25, 2025 at 8:49 PM
    #70
    SYNCRO
    SYNCRO New Member
    I was at the dealer last week asking the same thing for my DC. Was told it’s discontinued. I should’ve bought it when I had the chance. :mad::(
  11. Mar 25, 2025 at 8:52 PM
    #71
    SYNCRO
    SYNCRO New Member
