OEM backup camera plug busted
Discussion in '2.5 Gen Tundras (2014-2021)' started by bimini07, Mar 30, 2022.
  1. Mar 30, 2022 at 7:30 AM
    bimini07
    bimini07 [OP] New Member
    Hi,
    I am a noob when it comes to automotive electrical. I have a 2014 Tundra Crewmax. A couple of the wires broke off from the OEM backup camera plug. The replacement plug is $100 bucks!
    https://connectorexperts.com/i-31645527-ce4189f.html?ref=category:1261630;brand:100061
    I have a few questions regarding this connector:
    1. What is it called?
    2. Can the original plug be taken apart and then rewired?
    3. Are any cheaper alternatives available to replace this plug?
    Please see the pictures of the plug attached.
    [/URL][/IMG]
    [/URL][/IMG]
  2. Mar 30, 2022 at 7:37 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    You can try removing the pins and re-pinning the wires.
    Although Toyota doesn't have much slack in the wiring.
    You could always solder an extra length of wire to the existing wire.
    Some of those camera wires might be shielded wires making them VERY difficult to work with.
    I'm not sure..
    camera_be882dc462d9fa4c3d6c97e11b9ae4bca3c642cb.jpgcamera_plug_de06d5101533f4e51cf0aeb9ea3b7df453911454.jpg
    Watch some youtube on HOW TO re-pin automotive connector
    https://youtu.be/CFM-6ovP_-k
    Welcome top the forum..
  3. Mar 30, 2022 at 7:53 AM
    Welcome from NY.
    Maybe @Roman can provide you a part number.
  4. Mar 30, 2022 at 10:18 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  5. Mar 30, 2022 at 5:54 PM
    bimini07
  6. Apr 1, 2022 at 9:04 AM
    bimini07
    Hi @Roman - All,
    I placed an online order for the part but per the dealer, the part has been discontinued and cannot be ordered anymore.
    Any other options? The wire broke off right at the connector so cannot solder it. Not sure if it can be picked apart. I tried picking it apart but that did not work.
  7. Apr 1, 2022 at 9:15 AM
    Roman
    Roman
    Franklin, TN
    Yep, showed to be good but then Toyota kicked it back stating it was discontinued. Called it a non-serviceable part.
    If it is just the wire that is broken, I would get the pin out, grab a new wire with the pin attached, and solder the new wire to the old one.
  8. Apr 1, 2022 at 9:16 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    From the wiring diagram that @1lowlife posted, another option would be to cut out the stock connectors and replace them with a cheap generic 4 pin connector. Here are a couple that were on the front page of Amazon. Someone can chime in if this is a bad idea but if you cannot get your connect to depin and repin it is an option.
    https://www.amazon.com/Deutsch-Pigt...48829461&sprefix=4+pin+c,aps,158&sr=8-4-spons
    https://www.amazon.com/MCIGICM-Wate...48829534&sprefix=4+pin+c,aps,158&sr=8-1-spons
    1lowlife and Roman like this.
  9. Apr 6, 2023 at 3:17 PM
    Tomcom01
    Tomcom01 New Member
    Tom
    2021 Limited
    stock
    I have the same problem, I’m under warranty but Toyota says the plug was damaged, maybe the idiot who sprayed my bed liner . How did you make out , did you re pin ?
