OEM antenna replacement for Range extender?
Discussion in '2nd Gen Tundras (2007-2013)' started by NueveTundra, Oct 13, 2021.
  1. Oct 13, 2021 at 11:12 PM
    NueveTundra
    NueveTundra [OP] Internet Certified Forum Mechanic
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level , GoodYear helper air bags , DayStar air bag cradles, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch , White AUTMATCH Shackles 3/4" D Ring Shackle, White AutoBots winch hook, Trail Ridge mirrors , 20x9 Creeps rims , 33x12.50r20 RoadOnes , Black Hart cross drilled n slotted rotors , Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. unknown Cat-Back exhaust.
    Any one replace there OEM radio antenna for Cell booster antenna? I'm pondering at the idea it seems every one I see people mount it to the roof rack an don't use any of the extensions for the antenna. I for one don't use nor listen to radio I just use streaming services or downloads. So a radio antenna is kinda not needed was thinking at one point of getting a bullet antenna for looks but the thought of repurposing the hole and mounting area kinda has me giddy. :yes:
  2. Oct 14, 2021 at 5:57 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    Me too. I replaced the antenna with a "stubby", (don't know about cell phone boosters etc), so no need to remove antenna when going through the car wash.....:)
  3. Oct 14, 2021 at 6:04 AM
    timsp8
    timsp8 Member
    NY
    2018 Tundra Limited Crewmax
    I have a stubby antenna too. I ran my cell booster antenna up through the 3rd brake light and it’s mounted magnetically on the roof.
  4. Oct 14, 2021 at 3:55 PM
    Kramegroeg2021
    Kramegroeg2021 New Member
    Mark
    2013 Tundra
    Where did you buy the stubby antenna? I replaced my OEM radio with a BOSS head unit, the original antenna is plugged in but it seems like the reception is worse.
  5. Oct 14, 2021 at 5:42 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I think the thing to do is get a stubby for the FM/AM antenna whether you use it or not and mount a range extender antenna as high as you can which is where it should work best anyway.
    It sort of defeats the purpose of the range extender to not get that one as high and away from other metal as possible.
  6. Oct 14, 2021 at 5:43 PM
    ezdog
    ezdog New Member
    Gateway To The West
    If your reception is worse with the long antenna the stubby sure is not going to help that.
    I wonder if the antenna is connected solidly to the new radio or maybe the new radio just sucks for reception?
  7. Oct 14, 2021 at 6:18 PM
    Kramegroeg2021
    Mark
    2013 Tundra
    Thanks I think I will check out the range extender AND re-check the connection
