Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Jul 29, 2024 at 7:21 PM
    #121
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
    Haha pretty sweet you have it automatically come on. Does the Red and Blue mess with your eyes too? Green is the only one that seems clear to me.
    I have a mechanical KB with backlighting, and it's the same with that, only green seems clear.
    455h0le_dachshund likes this.
  2. Jul 29, 2024 at 7:26 PM
    #122
    KNABORES [OP] Sarcasm incoming
    Green is my favorite so far. Easy on the eyes and good definition of objects. Doesn't mess with night vision either. This setup is dimmable too.
  3. Jul 29, 2024 at 7:27 PM
    #123
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Topo graph with the 10 on it
  4. Jul 29, 2024 at 7:35 PM
    #124
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I'm definitely doing this if I ever swap my softopper for a shell. Came out awesome dude.
  5. Jul 29, 2024 at 7:36 PM
    #125
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Ok that's just dope AF. I'm officially jealous.
  6. Jul 30, 2024 at 5:19 AM
    #126
    I've been mulling over how to mount mine similarly (I have the same LED runs). I'm carpeted, and I see some folks suggesting velcro online. But that raised support section thru the middle of the roof has substrate of some sort sandiwched in between and I was toying with the idea of using ¼" fasteners to pop into the vertical edge of that. The same section is used to mount the overhead lockbox on some shells, and fishing rod holders, and plenty of other stuff.
    I also think an under-rail install could produce solid results, but nowhere near as good as yours turned out..
  7. Jul 31, 2024 at 8:40 AM
    #127
    Ordered a new 3rd brake light for the cap, original is baked and cracked and barely light up anymore. Removal has begun, awaiting the delivery of the replacement.
  8. Jul 31, 2024 at 8:53 AM
    #128
    Clean enough for re-install. Hurry up UPS….
  9. Jul 31, 2024 at 9:31 AM
    #129
    Add to the parts pile. Other side of the truck parts that someone apparently didn’t order the first time. Good help is hard to find.
  10. Jul 31, 2024 at 12:45 PM
    #130
    Third brake light came in. Install was easy.
    I added some additional 3M tape to the back surface. It came with tape on the bottom surface. Had to open the wire hole up a little due to the new light having a small hump around the wire exit.
  11. Jul 31, 2024 at 10:27 PM
    #131
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    It looks fantastic! Sure beats wearing a headlamp or holding a flashlight between your teeth! I know it was a game changer after i installed the daisy chain LED lights all throughout my Econoline motovan. I went YEARS and YEARS without proper lighting under my canopies and vans, so when i bought my econoline (about 10 years ago) one of the first things i did was install LEDS.
    Fobroader likes this.
  12. Jul 31, 2024 at 10:47 PM
    #132
    whodatschrome
    lots of dents
    The very second i saw the red lights, i immediately thought of the choppa ride in the movie Predator.
    Fobroader and bmf4069 like this.
  13. Aug 1, 2024 at 1:56 AM
    #133
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Is that an override kill switch for the lights? In case you want the topper open for an extended time, but the lights not burning?
    Looks great man. The older I get the more I appreciate good lighting :thumbsup:
  14. Aug 1, 2024 at 4:35 AM
    #134
    It’s the on off switch that came with the lights, so yes, it allows you to turn them off when the cap is open.
    Fobroader and BroHon[QUOTED] like this.
  15. Aug 12, 2024 at 12:22 PM
    #135
    Stole some leafs from my factory pack before dumping the rest at the metal recycle place. Gotta feeling I might need these in the future. Was able to save the pads for them. The center pin on the HD pack has some room left for one more leaf me thinks.
    Fobroader, BroHon, bmf4069 and 2 others like this.
  16. Aug 12, 2024 at 4:33 PM
    #136
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I've seen people make pretty sweet rocking chairs out of them.
    455h0le_dachshund and dbittle like this.
  17. Aug 14, 2024 at 2:30 PM
    #137
    The refresh continues with a front end rebuild. All the moving bits are being swapped for OEM. Already swapped the worn out sway bar end links for the Suspension Maxx extended ones. Have about 2.25” of lift in the front from the 5100 Billies.
    After tearing it all down, diagnosis: all the shitty non-OEM parts have failed in spectacular fashion in less than 60k miles. Some of them have been done failed for many miles.
  18. Aug 14, 2024 at 2:56 PM
    #138
    Rear leafs (Husky HD 5 leaf from rockauto) have only settled about 1/4” after some towing.
    Hutcheson, shifty` and BroHon like this.
  19. Aug 14, 2024 at 3:11 PM
    #139
    CVs were shot, well at least the boots were. These must be built like AKs, cause despite the wide open boots for a long time, they still worked great. Advanced auto axles with lifetime warranty, so swapping them Out tonight.
  20. Aug 14, 2024 at 3:22 PM
    #140
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Carquest premium from AA? Any chance you can snap a pic side by side with the OEM axles for science?
  21. Aug 14, 2024 at 3:25 PM
    #141
    Don’t have any OEM axles to compare it too. I unwisely discarded them years ago when they failed.
    bmf4069 and DarkMint[QUOTED] like this.
  22. Aug 14, 2024 at 3:27 PM
    #142
    DarkMint
    Ben
    I didnt realize those are already AA axles :thumbsup:
    KNABORES[QUOTED][OP] likes this.
  23. Aug 15, 2024 at 5:02 PM
    #143
    Good grief what a pain today. Bearings pressed. Not a fun job.
  24. Aug 15, 2024 at 5:12 PM
    #144
    Replaced:
    Upper ball joints - OEM
    Lower ball joints - OEM
    Tie rod ends - OEM
    Tie rod end boots - Detroit axle
    Front wheel bearings - Koyo (OEM)
    CV axles - Advanced Auto
    Drives like new. So smooth and quiet. No more Wah-Wahs. Steers straight and true and with much less effort. I thought my steering rack was failing prior to this. Not so much now. Need to add some front diff fluid back and adjust my rear brakes again.
  25. Aug 15, 2024 at 5:54 PM
    #145
    A close second to the bearings was the steering rack bushings. F those things.
  26. Aug 15, 2024 at 6:03 PM
    #146
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    John is still driving around without one of his steering rack bolts in place because of that. It's been 3 years now.
    What was so difficult about the wheel bearing?
  27. Aug 15, 2024 at 6:11 PM
    #147
    The pressing was challenging due to the surface that you are using to hold the spindle (the bolts that hold the brake shield on) is smaller diameter than the hub surface with the lugs. So you have to sneak something in between the hub and the spindle and somehow support it on all sides. Then, you 100% need a 20 ton Press. It took all it had. You also have to raise it up high enough to clear the hub + about 3” that gets pressed out.
  28. Aug 16, 2024 at 7:30 AM
    #148
    Bled the brakes with new Dot 3 synthetic fluid. Old stuff was predictably green and nasty looking. Adjusted the rear drums, all out of LSPV adjustment short of making a new bracket. Also refilled the spilt front diff juice. Royal Purple 75/90.
    Oh yeah, spun the breather and greased the driveline too
  29. Aug 16, 2024 at 8:01 AM
    #149
    Any bets on how long it takes before the reservoir is light green again? I'm usualy at about 3-6 weeks.
    bmf4069 and KNABORES[OP] like this.
  30. Aug 16, 2024 at 8:01 AM
    #150
    Doesn’t seem to take long
