Octane ?
Discussion in 'Performance and Tuning' started by Ike74, Apr 11, 2018.
Which grade do you use
  1. 85
    12 vote(s)
    8.9%
  2. 87
    94 vote(s)
    69.6%
  3. 91
    29 vote(s)
    21.5%
  1. Apr 11, 2018 at 7:29 PM
    15whtrd
    15whtrd Mr. Blonde
    This was my feeling on it also I just couldn’t bring any numbers to the table.
  2. Apr 11, 2018 at 7:56 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I run alternate between 87+89 during the non-winter months. But i run 93 during the additive-rich shit gas months of winter. I disco'd the bat to reset the mpg readout, then drove for 6 months with 89+87 and average was 11.5mpg (confirmed with hand math calculations). Then I switched to 93 for the winter and saw the mpg's go up each tank until plateauing out at 12.3mpg. The truck does run better without a doubt on the high-test. However, not recommended by my dealer, stressing the truck is designed to run 87. WTF
  3. Apr 12, 2018 at 4:11 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    All the lexus cars and trucks that have the 4.6 or 5.7 same motors require premium fuel only. I wonder if my wifes GX460 which requires premium can use 87?
  4. Apr 12, 2018 at 4:14 AM
    You can use 87 but the GX is tuned/programed to run best with premium. Just like our Tundras are tuned to run best with 87.
  5. Apr 12, 2018 at 8:31 AM
    15whtrd
    15whtrd Mr. Blonde
    So do you think Shrek is wrong at dap tuning that the tundra 5.7 L pulls 10-13 degrees of timing on 87? As well as 6-8 on 89 and 0-2 on 93?
    Metro14536 likes this.
  6. Apr 12, 2018 at 8:35 AM
    Ike74
    Ike74 [OP] New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    It honestly does not make sense to me. Toyota puts millions into R&D for their vehicles to determine what should be the optimum operating parameters. If their manual says 87 is required, then 87 should be optimal. The other question we have to approach, though, is what conditions did Toyota test under to determine the parameters? Also, what conditions did DAP test under? Where these vehicles at sea level? At altitude? what was the barometric pressure at time of test? Etc.?
    jewsNbrews likes this.
  7. Apr 12, 2018 at 8:36 AM
    Not wrong . My comment was about factory tune/program to run on 87. Factory tune. Not custom tune. Huge difference....Most of us run on factory tune/program.
    When you start adding long tube headers and BAM's.....whole new ball game with Bully Dog...
    jewsNbrews and 15whtrd[QUOTED] like this.
  8. Apr 12, 2018 at 8:40 AM
    Our 5.7L can handle a lot more HP. It's detuned, for lack of better word, to meet CAFE standards most likely and for reliability. To last longer.
    Toyota10s and 15whtrd like this.
  9. Apr 12, 2018 at 8:51 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    there's something so totally wrong about calling FB a research tool. nothing against you. more at society in general.
    luddites unite!
  10. Apr 12, 2018 at 9:05 AM
    Agreed.Frackbook is the last place I'd go for research.
    T500 and Toyota10s like this.
  11. Apr 12, 2018 at 9:10 AM
    Yes, very confusing. I agree with Colorado TJ. Has more to do with compression ratios. If our 5.7s' would require premium like other vehicles then why not? Why 87? Freaking gas hog already..Not losing sleep over it that's for sure.
    15whtrd likes this.
  12. Apr 12, 2018 at 9:30 AM
    Food for thought....I think it would be great to maximize the tune. Now with the stock tune, let's say you run with 91 over the course of a year. You gain 1+ mpg doing so. How much more are you spending with the added cost of premium fuel to gain that 1+ mpg? Is it worth it?
  13. Apr 12, 2018 at 10:00 AM
    15whtrd
    15whtrd Mr. Blonde
    OK. I was under the assumption that he meant the ecm may pull timing even on a stock tune.
  14. Apr 12, 2018 at 10:47 AM
    I'm not too sure about anything. Heh heh.. I think the Bully Dog tune is permanent until you revert back to factory tune like DAP tune too? As long as I can buy Clear87 at Maverick I'm OK, otherwise I like Shell midgrade.
    15whtrd[QUOTED] likes this.
  15. Apr 12, 2018 at 10:49 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m using the bully dog and I really like the way the truck runs with it. If I did it all over I would think about trying the DAP tune but I would want the Remote version so that I can take it out easily.
  16. Apr 12, 2018 at 11:03 AM
    Bully Dog at some point. Crazy not to do it..DAP tune would be nice but not easy to get it.:thumbsup:
  17. Apr 12, 2018 at 11:52 AM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Oh Dangit! Being in Commiefornia, gas cost and everything else burns a big hole through my wallet. DAP tune is worth it though!:spending::spending::spending:
    Areith762[QUOTED] and Black Wolf like this.
  18. Apr 12, 2018 at 12:05 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I pretty much run 89. Locally the choices are E85, 87, 89 and 91 but the station I get gas at has 89 with no ethanol. After reading this thread though, I'm wondering if the 89 I'm running is mixed at the pump. I can say that the truck gets 4 to 5 tenths of a gallon better on 89 versus 87 but I'm not sure it's worth the extra .75 a gallon.
    Black Wolf likes this.
  19. Apr 12, 2018 at 12:13 PM
    #49
    BayRunner
    2017 Tundra Platinum
    If the station your buying your 89 at also has 87 and 91, then the 89 is most likely mixed at the pump. However,this is not a certain for they can also supply pure 89.
    duece292[QUOTED] likes this.
  20. Apr 12, 2018 at 12:22 PM
    #50
    I'm not sure if we have 89 here in CO but you might want to add 89 since so many are using it....:thumbsup:
    15whtrd likes this.
  21. Apr 13, 2018 at 4:08 AM
    #51
    Toyota10s
    Toyota10s New Member
    Chace
    West Coast
    2017 Toyota Crewmax limited Tundra
    Bone stock.
    I thought the manual says to use 93 which I believe is on the gas cap as well.
    Problem on west coast is we have mandated ethanol with summer blend. My Toyota 86 knocked and pinged frequently. I contacted Toyota and CAL EPA and got no reply. That gas is garbage. And we only have 91 so 93 is out of the question.
  22. Apr 13, 2018 at 4:12 AM
    #52
    Toyota10s
    Chace
    West Coast
    Bone stock.
    Good points. Top Tier is an industry org that rates gas but only for fuel detergents. I wish they rated octane. Costco Visa card will get you about 3 or 4% off the pump price so I agree with your statement but I've used Chevron over Costco lately and it's much better than Costco. Vehicle stopped pinging and knocking for the most part.
  23. Apr 13, 2018 at 4:24 AM
    #53
    I’m not sure why the requirement would be premium fuel? Compression ratio is 10.2:1. Now if it was 11.8:1 like my car, yeah, premium is required.
    Here is a club Lexus thread all about it.
    https://www.clublexus.com/forums/gx...-460-gas-fuel-premium-regular-87-89-91-a.html
  24. Apr 13, 2018 at 6:47 AM
    #54
    Nick T
    Nick T New Member
    Nick
    Compession ratios and octane requirements depends on so many factors. For the 3UR-FE , Even with fuel injection and well designed aluminum heads 10:1 CR DOES require higher octane. 40psi fuel pressure can only atomize the fuel to a certain extent, aluminum can only dissipate the heat to a certain extent. Modern engines have knock sensors and then ECU will pull timing once it senses pre ignition. 87 is fine for 99% of the time, and the ECU will protect the engine that last 1%.
    Will it run better on higher octane? Probably. Will it run perfectly fine and reliably on 87? Yes.
    Is the 1-2% increase in Hp worth the $0.50 per gallon extra? The owner has to decide.... if mine was stock, i would use 87 unless i am towing or offroad where every last once of performance is desired
  25. Apr 13, 2018 at 7:56 AM
    #55
    attillatundra
    attillatundra New Member
    I think we all need to look at this from a financial perspective. I agree 99% of the time 87 is fine. 93 will definitely give slightly better performance and mileage but the cost difference may not be worth it to most of us. If under severe load or during other high stress situations then 89 or 93 may be worth it. If you can afford it then go ahead and use it as it should not cause any problems. But in the end it will cost a small bit more per mile and that is a personal decision for us to make. I use 87 80% of the time but occasionally will use 89 or 93. Never had an issue with knocking but the 93 does run better by the way it feels and responds.
    netranger6 likes this.
  26. Jul 7, 2018 at 9:29 AM
    #56
    dooododoo
    dooododoo New Member
    MGM '17 CM OR
    Fortin EVO-ONE Remote Start iBoard Running Boards (Black 5") LED interior lights Line-X Bed Plasti-Dip Emblems
    87 in the chicagoland area where i live.
    i put in 85 when in utah and colorado while pulling 6k+ trailer
    sprtbkr likes this.
  27. Jul 7, 2018 at 10:12 PM
    #57
    Tombob26
    Tombob26 New Member
    Tombob26
    2018 CM TSS 4X4
    My manual states no lower than 87 but research octane was 91. Nowhere does it specifically say to use 87 just no lower than.
    LKROOZR likes this.
  28. Jul 7, 2018 at 10:21 PM
    #58
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
  29. Jul 7, 2018 at 10:32 PM
    #59
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I run 87. It's my low grade here. Usually see 87, 89 and 91-93 for premium. Only two stores sell non-ethanol and it's the premium. I just make sure nothing more than 10% ethanol.
    ColoradoTJ likes this.
  30. Jul 7, 2018 at 10:45 PM
    #60
    Just go man, just go...
    Oh that’s so warm...
