Obd2 problem
Discussion in '1st Gen Tundras (2000-2006)' started by geo145145, Jul 21, 2021.
  1. Jul 21, 2021 at 6:32 PM
    geo145145
    geo145145 [OP] New Member
    2000 toyota tundra limited 4.7
    My 2000 Tundra 4.7 only gets .5 volts at the OBD2 connector so it will not scan.When plugged into scanner voltage goes to 1.83. When I ohm from ground to reference wire I get 2.2 ohms. this goes away if I pull the fuse for ETCS. Any thought would be helpful.
  2. Jul 22, 2021 at 3:32 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Have you checked the 7.5 A OBD fuse driver side kick panel ?
    You are checking at pin 16, correct ?
  3. Jul 22, 2021 at 11:54 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    I believe there is also a fuse for the port under the hood as well.
  4. Jul 22, 2021 at 3:10 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    1st gen has CAN bus?
  5. Jul 22, 2021 at 3:23 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    negative
    mbreed2[QUOTED] likes this.
