OBD2 bluetooth scanner question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Walther1978, Jun 9, 2021.
  1. Jun 9, 2021 at 9:43 AM
    Walther1978
    Walther1978 [OP] New Member
    2019 Tundra TRD DC
    Looking for one that will work with my phone and read all temps including trans temp.
  2. Jun 9, 2021 at 9:45 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
  3. Jun 9, 2021 at 10:08 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    I'm using a generic bluetooth OBD adapter (https://www.amazon.com/Bluetooth-Scanner-Diagnostic-Vehicle-Compatible/dp/B07CP5ZJVQ/) and Torque Pro (https://www.tundras.com/threads/torque-pro-on-android-auto.56661/)on my Android phone. I bought Torque Pro a few years ago and have used it on a few vehicles. It works great. The GUI isn't intuitive, but it works for me.
    Do you plan on using it for continuous real-time monitoring? If so, you might want to set up an old tablet for that. Check out the developer's forum here for some ideas on the vehicle stats to monitor: https://torque-bhp.com/forums/?wpforumaction=viewtopic&t=160.11
  4. Jun 9, 2021 at 11:44 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  5. Jun 17, 2021 at 8:22 PM
    CaptCraig
    CaptCraig New Member
    Craig
    2021 Tundra CrewMax 4x4
    Just bought one of these on Amazon & bought the torque pro app too. Set up was relatively easy. I'll be using it for the first time while towing this weekend. Anyone know what temps I should be looking for? I've heard over 250 is cause for concern while pulling my 28 ft travel trailer.
  6. Jun 17, 2021 at 9:28 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Light comes on at 300. That’s when the engineers are worried.
  7. Jun 17, 2021 at 10:16 PM
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Another vote for MX+. It’s a pricier option but works great and you get access to unlimited OEM specific add-ons for all major manufacturers and can setup different car profiles for using them and saving data.
  8. Jun 18, 2021 at 7:29 AM
    Walther1978
    2019 Tundra TRD DC
    What reader did you get? Also how'd you set up the trans temps. I'm not sure how to do that with torque pro.
  9. Jun 18, 2021 at 9:56 AM
    CaptCraig
    Craig
    Just started a new thread for trans temps. Go to the screen with all the gauges, you select the gear in the bottom left, it'll give you options for what kind of display style you want. Then you can scroll down & select what you'd like it to display. That's ok the Torque Pro app for androis.
  10. Jun 18, 2021 at 10:09 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    What scanner did you purchase?
  11. Jun 18, 2021 at 10:13 AM
    CaptCraig
    Craig
  12. Jun 18, 2021 at 10:13 AM
    parkerbows
    Jack
  13. Jun 18, 2021 at 10:21 AM
    CaptCraig
    Craig
  14. Jun 18, 2021 at 10:22 AM
    parkerbows
    Jack
    cool that and torque pro is good for trans temps without any setup?
    ahhjh just seen your response, looking for trans temp as the priority
  15. Jun 18, 2021 at 10:28 AM
    CaptCraig
    Craig
    The instructions it comes with are easy to follow for set up.
    But that's what I'm trying to figure out. It read everything nicely once in connected to it via bluetooth. Can seem to get any reading on trans temp.
  16. Jun 18, 2021 at 10:30 AM
    parkerbows
    Jack
    Thanks if you get working could you send me a pm? Thanks
  17. Jun 18, 2021 at 12:26 PM
    CurtisLemansky
    2017 SR5 CM TRD OR
  18. Jun 18, 2021 at 4:43 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You've got it right - you either pay to play or figure out how to manually set up the PIDs. The link you posted has that info in there.
