OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. Apr 16, 2021 at 7:47 PM
    #241
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Agreed. Worth the $10.
  2. Apr 16, 2021 at 8:19 PM
    #242
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It's too bad we can't see the equations. I did manage to find the equations for the pan and TC temps but nothing else so I had to purchase the enhanced PIDs.
  3. Apr 17, 2021 at 1:51 PM
    #243
    coTony
    Tony
    Montrose, CO
    I know what you are talking about. I bought the additional package but am having trouble finding what I want and end up giving up because I do not have the time to continue searching. Tried several times but never got it working. I would like to know the PID’s required for each option but I have not seen a list for that
  4. Apr 17, 2021 at 3:41 PM
    #244
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What specifically are you looking for?
  5. Apr 18, 2021 at 6:10 AM
    #245
    coTony
    Tony
    Montrose, CO
    Mainly this
  6. Apr 18, 2021 at 6:13 AM
    #246
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Have a look through the thread. Lots have shared our dashboards through dropbox.
  7. Apr 18, 2021 at 6:17 AM
    #247
    coTony
    Tony
    Montrose, CO
    Understood, when you import however you have to update the PID. I cannot find a lot of the PID’s like the torque converter lockup mode, etc.
  8. Apr 18, 2021 at 6:44 AM
    #248
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    The TC lock up is called “Status of the Lock Up”. Which other PID names are you needing? They don’t make it easy to list them all out in a useful format.
    coTony[QUOTED] likes this.
  9. Apr 18, 2021 at 6:44 AM
    #249
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Under the enhanced PIDs.
    coTony[QUOTED] and TRDFerguson like this.
  10. May 17, 2021 at 6:25 PM
    #250
    t-rey1
    t-rey1 New Member
    If I purchase the add on for 2020 toyota will it be on every device I have fusion on?
  11. May 17, 2021 at 6:30 PM
    #251
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah, it should be tied to your Google Play Store account.
  12. May 17, 2021 at 7:51 PM
    #252
    t-rey1
    t-rey1 New Member
    Thank you
  13. May 18, 2021 at 11:19 AM
    #253
    t-rey1
    t-rey1 New Member
    How do you get the colors in the dial? The blue,green red and yellow. Do not see that option in mine
  14. May 18, 2021 at 12:50 PM
    #254
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    If it’s the same as OBDLink app, under Style go to the Range tab and you can add them there.
    Ruggybuggy likes this.
  15. May 18, 2021 at 6:25 PM
    #255
    t-rey1
    t-rey1 New Member
    How do you have your settings for the TC Lock gauge? Mine is just green all the time. I have the toyota add on PIDs. Thanks
  16. May 20, 2021 at 5:30 AM
    #256
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Check your range setting.
  17. May 20, 2021 at 4:59 PM
    #257
    SchnauzerMan
    SchnauzerMan New Member
    Southern New Mexico
    2019 SR5 CM 4x4
    Sumo Struts, Tiger Steps, Bed Rug, Undercover Flex Hard Folding Tonneau Cover
    I just returned from a trip and was trying to use one of the generic ELM327 bluetooth OBD readers with OBD Fusion on my Android Phone. The thing would only work for a minute or two before losing the connection. Can anyone suggest a brand/model that is reliable and will stay connected?
  18. May 20, 2021 at 8:14 PM
    #258
    CurtisLemansky
    2017 SR5 CM TRD OR
    I got an OBDLink MX+ and while a premium price wise, it’s worked flawlessly for me so far. OEM PIDs are included (for multiple vehicles) so that helps.
    SchnauzerMan[QUOTED] likes this.
  19. May 21, 2021 at 6:16 AM
    #259
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Most of us are using the Veepeak BLE. You can get it for around $32.
  20. May 22, 2021 at 5:18 AM
    #260
    t-rey1
    t-rey1 New Member
  21. May 27, 2021 at 8:30 AM
    #261
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    In the OBDFusion enhanced diag package for my '20 Tundra, it has preset PIDs for A/T Oil Temp 1,2,3, and 4. Looks like 3 and 4 don't work (maybe CVT related for other Toyota models?), but 1 and 2 give results. Given the fluctuation while driving, is my assumption correct that A/T Oil Temp 1 is Trans Pan temp and Temp 2 is torque converter temp?
  22. Jun 28, 2021 at 6:14 PM
    #262
    DangTundra
    DangTundra New Member
    Has anyone have issues getting the transmission pan temp to work on the Torque Pro app with the BAFX ODBII reader? I have a 2007 Tundra 4.7L 4wd. I've used the settings found on this thread and others in this forum and I can't seem to get any data. Anytime i test, I get "no data". Here are the settings i used
    Mode and PID: 2182
    min value: 0
    max value: 350
    scale factor: 1x
    unit: F
    equation: ((((A*256)+B)*(7/100)-400)/10)
    ODB header: auto
    I'm able to get other reading like engine coolant temp, and revs, etc. Some reason, I can't get the darn tranny pan temp. I've even tried this setting, and no dice.
    Mode and PID: 2182
    min value: 0
    max value: 350
    scale factor: 1x
    unit: F
    equation: ((((E*256)+F)*(7/100)-400)/10)
    ODB header: auto
    Any ideas, help, suggestions would be much appreciated. Thanks!
  23. Jul 7, 2021 at 8:46 AM
    #263
    DangTundra
    After playing around some more... I was able to use pid 21d9 and using the e and f equation, and left the odb header blank. That seemed to do the trick. Hope this helps someone else out there.
  24. Sep 2, 2021 at 9:44 AM
    #264
    sseibert3
    sseibert3 New Member
    David
    2021 SR5 TSS
    2021 Tundra 5.7L 4x4 TSS.
    Thank you so much for your posts. I am leaning for the OBDLink MX+ OBD2. I have contacted OBD Link to verify that they capture all of the PID that I need. They also have their own app for monitoring engine performance.
    I would appreciate your recommendations for the Droid and Apple program to get this thing operational with the least amount of hassle/adjustments.
    I would like to capture in Real Time: Oil Temp, trans temp, engine water temp, RPM, torque, gear, vehicle speed.
    We will be getting a light travel trailer max. 6,000# loaded.
    Thank you in advance for your input/thoughts.
    Scott
  25. Sep 2, 2021 at 9:50 AM
    #265
    SchnauzerMan
    Southern New Mexico
    2019 SR5 CM 4x4
    Just curious why folks mess around with these formulas when OBD Fusion provides all of these with the expansion pack (minimal cost). Are these figures inaccurate in OBD Fusion?
  26. Sep 18, 2021 at 6:01 PM
    #266
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I bought the Scantool MX+. Pricey but worth it from pervious experience. All the Toyota PIDs were free so that was a plus. I have been messing with it today and so far this is what I have. There was like 6-700+ PIDs for Toyota if I recall when it was downloading them.
  27. Sep 18, 2021 at 6:05 PM
    #267
    pursuit2550
    I just got it today and it’s works perfect. I had Scantool before so I choose to buy it again. Worth the price I think. Only thing I haven’t found and I don’t thing it has it is the PID for what gear your in. Maybe they will add it later, who knows. It has its own app for both and the PID pack for the tundra is free.
  28. Sep 28, 2021 at 1:02 AM
    #268
    Islandboy_671
    Islandboy_671 #gotte'y sibesa-hu
    Toby
    Lacey, WA
    2016 SR5 Tundra TRD Inferno
    8" ReadyLift w/ Bilstein Coil-overs and Rear Shocks, BAM 8" Exhaust, Stillen CAI, Coach-Builder Steering Kit and 3" Rear Shackles, Tech12Volts Remote Start and JBL speaker Upgrade system, Pioneer DMH-WT8600NEX HU, 3W Liners window mod, Morimoto XB LED Headlights, RC 30" Light Bar, RC 2" x4 cube LED's, HRS Smoked Sequential Tail Lights, Mammoth Guards Kryptek Gap Guards, Fab Fours Matrix Front Bumper, Fab Fours Vengeance Rear Bumper...
    I am able to see most of these PID's on my Pioneer HU and really only the ones that pertain to my model features stock and any additional. The only PID's that can't be selected are the features that my specific vin when purchased didn't have or didn't want the add-ons . I can customize the gauges and what not through the HU/Maestro vehicle settings and I have it programmed to one of the steering wheel buttons to pull up anytime along with the anytime rear camera....
  29. Oct 8, 2021 at 12:02 AM
    #269
    CurtisLemansky
    2017 SR5 CM TRD OR
    They have it here.
  30. Dec 25, 2021 at 7:00 AM
    #270
    DLJ6
    DLJ6 New Member
    Dave
    Thanks gang this thread has been a big help setting up the linkmx+ in my 08 5.7l DC. Am running link and fusion on both iOS devices and link on android tablet. Most Functionality is fine but having issues with the tpm network reporting pressure approx 20psi over readings taken with multiple gauges. The “calibrate sensors” function appears to briefly run but makes no change.
    I have a support ticket open with OBDLink and will post their reply but wanted to also check here to see if anyone has encountered this.
