OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. Mar 10, 2021 at 2:59 PM
    #211
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Another noob question. I purchased the Toyota PIDs for OBDFusion and loaded the trans and TC temps on my dashboard.
    Do I need to do anything else for settings or just drive with the app on to track my temps? Not wanting to mess up my truck by doing something wrong.
  2. Mar 10, 2021 at 3:46 PM
    #212
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    No worries about the Fussion app messing the truck up. Maybe if you used a wrong custom PID but no one here has reported anything. With the purchase enhancements your good to go. Don't leave your phone displaying the gauges for long periods of time so you don't burn the gauge images into your phone.
  3. Mar 10, 2021 at 3:55 PM
    #213
    Dsptundra
    Austin TX Area
    Thank you! Going to give it a try.
    Ruggybuggy[QUOTED] likes this.
  4. Mar 14, 2021 at 1:24 PM
    #214
    CurtisLemansky
    CurtisLemansky 5.7 or Die
    2017 SR5 CM TRD OR
    Is OBDLINK MX+ the way to go if I don’t mind the cost and want to make sure everything will work properly? Features look good on the module and I want to monitor transmission temps, at a minimum, for towing.
  5. Mar 14, 2021 at 6:16 PM
    #215
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Buy the Veepeak. It works great and it's only $33. Dont buy the cheap Veepeak because it won't read K line.
    https://www.amazon.com/dp/B073XKQQQW?ref=ppx_pop_mob_b_asin_title
    Mobeyk likes this.
  6. Mar 15, 2021 at 10:06 PM
    #216
    CurtisLemansky
    2017 SR5 CM TRD OR
  7. Mar 15, 2021 at 10:08 PM
    #217
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Yes, me and lots of forum members use it to monitor trans temps.
  8. Apr 2, 2021 at 10:29 AM
    #218
    DMart19
    DMart19 New Member
    Can anyone assist? I have the Veepeak and OBD app synced.
    I paid for the Toyota add on. I cannot find anything that states trans temp. I do have the following options (A/T Oil Temperature 1, 2 and 3).
    Is this what monitors the Transmission temp/Torque converter? Any help is appreciated.
  9. Apr 2, 2021 at 11:01 AM
    #219
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Asked and answered starting at post #209 of this thread.
    Galladanb and jtwags like this.
  10. Apr 2, 2021 at 11:05 AM
    #220
    DMart19
    DMart19 New Member
    Thank you Sir
  11. Apr 2, 2021 at 12:12 PM
    #221
    OGDark Knight
    OGDark Knight New Member
    Jeff
    2019 Platinum, 14 4Runner Trail, 95 Land Cruiser 80
    Trans cooler. Pioneer 8600. TRD Pro suspension.
    Help with TQ Conv lockup settings. 2019 Platinum.
    It’s only green when I’m in 6th gear cruising. When giving it gas and you can feel/see the lockup happen on the tach the green goes away. I was wondering if my settings are messed up or is that what others are experiencing?
  12. Apr 2, 2021 at 2:34 PM
    #222
    CurtisLemansky
    2017 SR5 CM TRD OR
    Here’s my first go at a dashboard for monitoring while towing or in general. Thanks to all in this thread for the help getting this far.
    I’m curious if anyone has figured out how to get Distance to Empty to display? My top small gauge is actually meant for that, not whatever it is now. I’d like to have that on this dashboard so I can have the Trailer Brake screen up on the vehicle dash.
    jtwags likes this.
  13. Apr 2, 2021 at 2:44 PM
    #223
    CurtisLemansky
    2017 SR5 CM TRD OR
    Not sure if it’s correct, but I’ve had the same experience with my TC lockup gauge.
  14. Apr 2, 2021 at 2:47 PM
    #224
    OGDark Knight
    Jeff
    Seems backwards to me.
  15. Apr 2, 2021 at 3:22 PM
    #225
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Mine goes green when TC is locked then disappears when unlocked. Are you saying yours is working the opposite of this?
  16. Apr 2, 2021 at 3:50 PM
    #226
    OGDark Knight
    Jeff
    Yes. Maybe I’m confused on how the TC locks but it seems backwards on the display. The display only shows green (locked) in 6th gear at cruising speed.
    For example:
    6th gear cruising, when you lightly press the gas, RPMs jump up some, gear stays in 6. This is where I thought the TC is “locked”? But, display no longer shows green “locked”.
    The display doesn’t seem to want to show green locked in any other gear.
    Are my thoughts backwards on this?
  17. Apr 2, 2021 at 5:51 PM
    #227
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    Yes your thoughts are backwards, if cruising in 6th gear (TC locked) then push accelerator and TC unlocks, rpm's increase (still in 6th gear) push harder on accelerator tranny downshifts to 5th gear.
    Ruggybuggy likes this.
  18. Apr 2, 2021 at 6:06 PM
    #228
    OGDark Knight
    Jeff
    Ok then, why does the green locked not indicate in other gears or when in s4?
  19. Apr 2, 2021 at 8:12 PM
    #229
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Mine shows lock up in 5th and 4th. Maybe your just getting into the pedal too much? If its showing lock up in 6th then there should be no reason it doesn't in 5th and 4th. First, second and third gear will not lock the TC.
    OGDark Knight[QUOTED] likes this.
  20. Apr 3, 2021 at 10:30 AM
    #230
    CurtisLemansky
    2017 SR5 CM TRD OR
    Found that Fuel Level should work just fine, it just fluctuates quite a bit when accelerating/decelerating/parking on a grade/etc.
    Also can confirm TC lockup in 5th.
    SchnauzerMan likes this.
  21. Apr 3, 2021 at 12:05 PM
    #231
    OGDark Knight
    Jeff
    My TC lockup does work well. Thanks for getting my thoughts straight on it.
    CurtisLemansky and Ruggybuggy like this.
  22. Apr 10, 2021 at 8:42 AM
    #232
    skorch02
    skorch02 New Member
    2005 sr5 tundra extra cab 4X4
    Just bought a 2005 sr5 tundra 4x4 and am trying to use Torques pro to read transmission temp, but when I try to set up the PID and enter the parentheses in the equation it gives me a mismatch parentheses error. What do I need to do to fix this?
  23. Apr 10, 2021 at 9:22 AM
    #233
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    What PID equation are you using?
  24. Apr 10, 2021 at 9:46 AM
    #234
    skorch02
    skorch02 New Member
    And maybe this isn't the right one.
  25. Apr 10, 2021 at 9:50 AM
    #235
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I had a Tacoma before the Tundra and had a custom PID that I believe worked in the older Tundra. Check with Tacomaworld website. I know there was a few equations you might want to try.
  26. Apr 10, 2021 at 10:35 AM
    #236
    skorch02
    skorch02 New Member
    Thanks, not sure what I did different than the other 10 times but I got it to work.
  27. Apr 10, 2021 at 10:37 AM
    #237
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Did you use a different equation? Share, it may help others that have the older Tundra.
  28. Apr 10, 2021 at 10:47 AM
    #238
    skorch02
    skorch02 New Member
    Same equations but this time I put 21d9 instead of a capital D and a * in the unit type instead of the degree sign and no spaces in the equation. I thought I had tried that before, but I can't remember. But it works now.
  29. Apr 16, 2021 at 6:45 PM
    #239
    Just starting to go through the thread but is there a full list of available PIDs for OBD Fusion? I see there is an option to purchase extra diagnostic info in the app. Thanks.
  30. Apr 16, 2021 at 7:32 PM
    #240
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The in app purchase is worth the cost.
    Tundra234 likes this.
