OBD Thread: PIDs, Apps, Dashboards
Discussion in 'Performance and Tuning' started by WNY PAT, Jan 18, 2020.
  1. May 2, 2024 at 4:30 AM
    #391
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I don't think so, at least I don't think I've experienced that happening
  2. May 2, 2024 at 9:55 AM
    #392
    ScottsTundra
    ScottsTundra New Member
    2017 SR5 Crewmax
    Headwaters seat covers, Undercover Flex
    Thanks for the reply! At least now I know it’s something on my end
    koditten likes this.
  3. May 4, 2024 at 2:35 PM
    #393
    ScottsTundra
    2017 SR5 Crewmax
    So after playing around and copying some of your setups, I’ve got mine halfway set up. Did I miss where there are specific values for this green yellow and red borders on the temperature gauges? Also, has anyone played around with the alarm function? I was considering putting an alarm at the appropriate temperature but I missed if anyone posted some good numbers.
    also, still dealing with OBD fusion disconnecting during phone calls. Reached out to tech support. Fast response. They are running some tests. No results yet.
  4. May 4, 2024 at 4:38 PM
    #394
    Ericsopa
    Ericsopa Old man and the sea
    I don't suppose there's any way to get the $14.99 enhanced diagnostics from fusion without giving Google all your personal info, huh? Bad enough that I've had to have a Google account for a few other things, but I have no desire to give them the info they require for Google Pay. I'd gladly pay double or even triple the cost to use some other method of payment, e.g., a credit card.
    koditten and ATV25 like this.
  5. May 4, 2024 at 5:50 PM
    #395
    koditten
    Kirk
    Midland of the Mitten
    I hear you. I'm on the same page. There is really no way to move thru life via cash.
  6. May 6, 2024 at 7:33 AM
    #396
    Gaston
    Gaston New Member
    Gary
    SE MI
    Didn't you have to pay for the app to even download it?
  7. May 7, 2024 at 9:27 AM
    #397
    Ericsopa
    Basic app was free
    ATV25 likes this.
  8. May 7, 2024 at 10:15 AM
    #398
    Gaston
    Gaston New Member
    Gary
    SE MI
    hmm, ok, I hadn't seen a free version
  9. May 28, 2024 at 4:46 PM
    #399
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    2018 Midnight black tundra S/C
    Pro comp 7", 35" tires, method wheels, brush guard, light bar, roof rack, pedal commander, magnuson 2650 supercharger
    Hi all, im thinking about getting the veepeaks ble+ but im confused reading through on how to get certain options or PIDS. I recently got a TT and will be traveling from az to or plus my truck is supercharged. Id like to keep an eye on trans temps, altitude so I can see the difference with my afr and boost (already have an afr and boost gauge)
    Please take it easy on me lol.
    Thanks for the help
  10. May 29, 2024 at 4:55 AM
    #400
    Gaston
    Gaston New Member
    Gary
    SE MI
    After getting the OBDII adapter, you'll need to download an app to access the data. Most of us are using OBD Fusion. With OBD Fusion you'll need to purchase the enhanced diagnostics package to get the PID's you want for monitoring the transmission temp. The are other apps you can use but I don't have experience with those, I personally use OBD Fusion. If you have specific questions just ask, most here are very helpful in getting people setup.
  11. May 29, 2024 at 8:52 AM
    #401
    NatesNightMare
    Pinetop Az
    Yeah id like to know how to get the PIDs I want added.
    Why would I need to purchase the enhanced diagnostics?
  12. May 29, 2024 at 10:40 AM
    #402
    NatesNightMare
    Pinetop Az
    Are there any major differences between these?
  13. May 29, 2024 at 11:02 AM
    #403
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Post 13 shows the user defined pids you'll need to add in the app to monitor trans pan temp and trans temp at the converter. I have the $41 Amazon unit you showed works fine.
  14. May 29, 2024 at 11:26 AM
    #404
    Gaston
    Gaston New Member
    Gary
    SE MI
    I'm using the $32 version you posted an it works fine, so you should be good with either
    NatesNightMare likes this.
  15. Jun 2, 2024 at 1:35 PM
    #405
    NatesNightMare
    Pinetop Az
    Anyone have the PID for altitude/elevation?
  16. Jun 3, 2024 at 5:24 AM
    #406
    Gaston
    Gaston New Member
    Gary
    SE MI
    It's located in the GPS section
  17. Jun 3, 2024 at 10:13 AM
    #407
    NatesNightMare
    Pinetop Az
    In the app?
  18. Jun 3, 2024 at 11:25 AM
    #408
    NatesNightMare
    Pinetop Az
    Do you know how to set thelat up for it to read correctly?
  19. Jun 3, 2024 at 11:45 AM
    #409
    Gaston
    Gaston New Member
    Gary
    SE MI
    yes
    when you are creating a gauge and you go to select the PID for that gauge, the altitude PID is located in the GPS section.
    In a dashboard, select Menu > Add Display. Select the style of gauge you like and then select Next at the top right. You'll then be asked to color design of the gauge, pick the one you like and continue by selecting Next at the top right again. Now you can select the PID you wish to display by tapping on the PID field, that'll bring up several categories of PID's you can select from, go to the GPS section, next you'll see things like Altitude, GPS Speed, etc. Select Altitude and select Done at the top right. You can change the title of the gauge if you'd like and depending on the gauge style you selected you might have some other options you can set. Once you've done all that select Done at the top right an you should now see your altitude being shown, you won't need to be connect to your vehicle to see this one and it's pulling this data from your phone. Hope this helps
  20. Jun 3, 2024 at 12:18 PM
    #410
    NatesNightMare
    Pinetop Az
    So I just removed the one I tried to change out and re added a new with altitude, set max to 10000.and I have bluetooth on, not connected to device (I get it this week) but altitude doesnt change
  21. Jun 3, 2024 at 12:19 PM
    #411
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I think some perimeters need the device
  22. Jun 3, 2024 at 12:36 PM
    #412
    Gaston
    Gaston New Member
    Gary
    SE MI
    Are you setting this up on your phone?
    I set up a gauge with altitude on my phone to test and it showed up right away and seems to track with what this area altitude is. And I'm not connected to the device in my truck. It should just use the GPS from your phone to get this data.
  23. Jun 3, 2024 at 12:56 PM
    #413
    NatesNightMare
    Pinetop Az
    Yes im setting up the display for now. I want to add the trans temps but need device to add those.
  24. Jun 3, 2024 at 5:48 PM
    #414
    NatesNightMare
    Pinetop Az
    Got alititude to work. Had to go imto location and give the app permission
    reywcms likes this.
  25. Jun 3, 2024 at 7:35 PM
    #415
    Gaston
    Gaston New Member
    Gary
    SE MI
    you should be able to set up your gauges/dashboards without being connected to the adapter/truck, you just won’t be able to verify if they are working correctly until you connect. That’s how I set up all my gauges, I’d set them up when I wasn’t busy at home or whatever and then make sure they were functioning the next time I was in the truck.
  26. Jun 3, 2024 at 7:53 PM
    #416
    NatesNightMare
    Pinetop Az
    Then how to I input the trans pan temp and converter temp?
  27. Jun 3, 2024 at 8:05 PM
    #417
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Manually adding them in user defined pids
    Gaston likes this.
  28. Jun 3, 2024 at 9:51 PM
    #418
    NatesNightMare
    Pinetop Az
    Ok I figures it out… hopefully
  29. Aug 20, 2024 at 6:16 AM
    #419
    JohnWhicker
    JohnWhicker New Member
    2021 SC Tundra 2013 SR5 Tundra 2010 RCSB Tundra
    I plan to use OBD Fusion for basic monitoring and I need to make a decision on which hardware OBD2 module to use. Looks like Veepeak OBDCheck BLE+ and OBDLink MX+ are the best 2 options and I was wondering which one got the most PID's for a Tundra 2021 with a supercharger? Price is not an issue.
  30. Aug 20, 2024 at 9:27 AM
    #420
    NatesNightMare
    Pinetop Az
    they wont have an option for a supercharger .youll just be able to monitor everything else
