Nutribullet Explosions
Discussion in 'Food Talk' started by Mater, Jul 7, 2021.
  1. Jul 7, 2021 at 9:40 AM
    Mater
    Mater [OP] New Member
    Nick
    SD
    2016 MGM Platinum
    Not sure how many, if any, of you use a Magic Bullet/Nutribullet but I personally would recommend for you toss them out if you do and go get another blender. My wife had ours blow up on her on Monday and got 6 lacerations on her left hand. If you think about it; it’s a pretty poor design. To have to push down towards a blade to turn the thing on. Makes no sense. Anyway, here’s a video showing examples. Pretty crazy the thing will blow up with just water alone. Hopefully this post spares at least one person
    https://youtu.be/aiy4kju0ubs
  2. Jul 7, 2021 at 9:57 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    We used to have a generic version of that... they are really a terrifying design if you have someone not thinking about what they are doing. A great example - my wife was trying to figure out how it worked and started to push the base onto the motor... without the freaking cup/shell on it. I freaked out on her before she could activate the blades. She probably would have lost a finger doing that shit.
    Hope your wife is ok, Nick. And thanks for posting this.
    Mater[OP] likes this.
  3. Jul 7, 2021 at 10:07 AM
    hitech
    hitech New Member
    Blair
    SOMD
    2018 CM TRD OR Limited
    we use the Ninja version, but it's all the same design. So, I'll be telling my wife tonight that we need to get something else with a better design. thanks for the video, pretty f'd up.
  4. Jul 7, 2021 at 10:10 AM
    Mater
    Nick
    SD
    2016 MGM Platinum
    Thanks, Jake. Glad your wife made it out unscathed! Most of the time when people are using those things they're doing ten other things at the same time and don't have full attention on blending.
    If you look at the threads on the base, there's maybe an 1/8" of plastic holding the base to the cup. I'm no engineer, but i'd be willing to bet over time (couple years) that plastic becomes weak and just a little pressure from inside the cup forces that plastic outward enough to allow the cup to blow off.
    Wife's all good, just bandaged up. Appears to have all sensation in her fingers and hopefully Mederma will fix the rest. I thought for sure she lost at least one finger. This is the scene I came into after hearing the bang and screaming (she was blending baby food in the downstairs bathroom because our convection oven was running and would have popped the breaker) :
  5. Jul 7, 2021 at 10:13 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :eek2: Please tell me she was blending up blueberries or something and that's not all blood...
  6. Jul 7, 2021 at 10:14 AM
    Mater
    Nick
    SD
    2016 MGM Platinum
    Haha yeah, that's blueberry and strawberry baby food
    Black Wolf, TheBeast, tbutler and 2 others like this.
  7. Jul 7, 2021 at 11:53 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    Oof. Glad to hear your wife will be OK. The similar designed one I had twist locked in and out, you didn't have to hold it to blend.
  8. Jul 7, 2021 at 12:34 PM
    Mater
    Nick
    SD
    2016 MGM Platinum
    The Nutribullet is a twist lock too. But to get it into the locked position you need to depress the three sensors, or whatever they are, to get it onto locked. So the blender is already running before its locked. In my wife's situation, it was literally the split second between going from sensor depressed and locked. The operating instructions for the thing should be "1) with your blender unplugged, lock the jar into position 2) once locked into position, plug the blender in using a 20ft extension cord"
    And for the record, I always view those videos as a bunch of ambulance chasers etc. etc. The video I posted even comes off a bit like that too. However, this one is a little different. It's just a sh*tty design and probably shouldn't be on the market. If this ever happened in a R&D kitchen at a food manufacturing facility, I'm pretty sure OSHA would be all over it.
  9. Jul 7, 2021 at 12:48 PM
    xdmelarton
    xdmelarton New Member
    Richard
    2017 Tundra TRD Pro CM
    I have had one of these for about 4 years, I actually just had to replace it. The new one isn't as well made as the original one. It does build up enough internal pressure if you over fill it past the line to start leaking but I have never had a problem with mine. I blend ice, 2% milk, dry oats, chocolate peanut butter protein powder, and natural peanut butter all at one time...but that's all I use it for. I like to call it the healthy version of the Sonic Reeses Peanut Butter Cup Milk Shake and man is it good.
  10. Jul 7, 2021 at 1:05 PM
    Kung
    KG, VA
    I appreciate you posting this. I don't have a Nutribullet, but as others have said, I've got a similarly designed one - ALTHOUGH what I usually do is screw things in, lock it into place, and THEN plug it in.
    hagrid likes this.
  11. Jul 7, 2021 at 2:14 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    You have to bite "the bullet" and get a Vitamix blender... They are super durable and safe. Wish the Mrs a speedy recovery.
  12. Jul 8, 2021 at 9:54 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Thanks for posting this. My wife and I discussed it and we will be looking for a replacement. In the meantime, it will be locking it in place unplugged and unplugging to turn off.
  13. Jul 8, 2021 at 12:49 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Vitamix is great but their cup/single serve solution leaves a lot to be desired. But no biggie just make a batch and freeze what you don’t use
    Toyotoholic and Mater[OP] like this.
  14. Aug 21, 2021 at 5:09 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Ouch! Thank you, I had no idea.
    We use an old beehive blender and a newer Ninja smoothie blender.
    I got them the Ninja by accident when what they wanted was a bullet type blender. We all love my mistake- me even more so now!
