Nsv light bar problem
Discussion in 'Lighting' started by Wes, Apr 6, 2019.
  1. Apr 6, 2019 at 6:30 PM
    Wes
    Wes [OP] New Member
    I installed the nsv night rider today I can get it to swipe and the drl will come on but I can't get the light bar it self to come on
  2. Apr 6, 2019 at 6:56 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Turn your brights on.
  3. Apr 6, 2019 at 8:03 PM
    Wes
    Wes [OP] New Member
    That was it thank you can you over ride that ? And just turn it on and off with the switch ?
  4. Apr 6, 2019 at 8:06 PM
    Sas
    OKC, OK
  5. Apr 6, 2019 at 8:08 PM
    RoninPro
    RoninPro Abecedarian BASTRD
    East Bay
    17 CM TRD Pro
    I have the same issue this week. My NSV wont come on!!
  6. Apr 6, 2019 at 8:15 PM
    Wes
    Wes [OP] New Member
    What about modification to make them stobe ?
    Tundyfundy likes this.
  7. Apr 6, 2019 at 8:21 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    There have been people that have bypassed that. I believe there is a post on here telling how to Get strobe functions back. NSV can’t tell you how because the strobe function became a liability issue. So they changed the function on the later versions.
  8. Apr 15, 2020 at 9:19 PM
    Greywind Tundra
    Greywind Tundra New Member
    Stephen
    San Diego, CA
    2020 Cement Tundra TRD Off-Road CM
    @RoninPro you ever figure this out. I can get swipe and DRL on but not the entire bar....
  9. Apr 15, 2020 at 11:02 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    My NSV light bar only turns on completely when I have the lights on and push for high beams it does not turn on completely on Auto
  10. Apr 16, 2020 at 12:27 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Yes only with high beams not on auto. Switch also has to be engaged on the switch panel.
    Greywind Tundra likes this.
  11. Apr 16, 2020 at 3:29 AM
    Greywind Tundra
    Stephen
    San Diego, CA
    thanks
    Tundyfundy[QUOTED] likes this.
  12. Apr 16, 2020 at 4:28 AM
    Sunnier
    Sunny
    San Diego, CA
    Good help, fellas!
  13. Apr 16, 2020 at 4:49 AM
    Tundyfundy
    Bay Area, CA
    Most likely but voids you’re warranty. Why would you need a lightbar on but not your brights? It also provides a toggle function so you don’t have to reach down every time. On long dark highway, which I usually drive I love using my bar, but it’s nice to be able to switch it off and on for occasional passing traffic.
    Sunnier likes this.
  14. Apr 16, 2020 at 4:52 AM
    Sunnier
    Sunny
    San Diego, CA
    @Yusef are you always up this early?!
  15. Apr 16, 2020 at 4:52 AM
    Tundyfundy
    Bay Area, CA
    Yes I work graveyard!!
    I get to cherry pick my way through all the fresh posts!
    Sunnier[QUOTED] likes this.
  16. Apr 16, 2020 at 4:53 AM
    Sunnier
    Sunny
    San Diego, CA
    I don’t know how I missed that. I did too until start of February. Now I get up Too Early.
    ... back to the normally scheduled thread.... :cool:
  17. Dec 31, 2020 at 9:42 AM
    TundraBeast20
    TundraBeast20 New Member
    Jaime
    2018 TSS Off Road Tundra 5.7V8 4x4
    Blacked out screws on gender flares, TRD Exhaust ,black tundra tailgate emblem
    Anyone here know why my tundras regular night lights are not working after installing the NSV light bar? The NSV Light Bar works perfect but my truck is having issues with lighting.
    the taillights and license plate lights are not working.
    my front side marker lights from my headlights are not working either.
    my regular DRL‘s from my LED headlights aren’t working as well.
    thats about it. I follow each step in the headlight revolution video and as well in the PDF instructions.
    really need help thanks.
