NSV Light Bar Install 2019 Tundra TRD Pro Help
Discussion in 'Lighting' started by SLA10, Jun 22, 2020.
  1. Jun 22, 2020 at 11:29 AM
    SLA10
    SLA10 [OP] New Member
    2019 Tundra TRD Pro
    I installed my new light bar this weekend. The video says if you have factory led headlamps with DRL to cut the blue wire on the turn signal plug. I've repinned the plug previously to use the 28w filament instead of the 8w filament. If I cut the blue wire the turn signal is not going to work. Anyone else encountered this. Not sure what cutting that particular wire, since it was technically connected to nothing, on the factory plug accomplishes.
    Beesta likes this.
  2. Jun 22, 2020 at 11:56 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I did not cut it either on my 19 SR5 CrewMax. There has been no loss of functionality that I can tell.
    SLA10[QUOTED][OP] likes this.
  3. Jun 22, 2020 at 12:25 PM
    SLA10
    2019 Tundra TRD Pro
    I didn't see any benefit to cutting the wire either, don't know if there's a different install video I should be referring to. The only reason it came up is while driving down the road to the house I drove over a few speed bumps, that I routinely drive over, less than 5 mph and got a beep each time the front wheels passed over the bump.
  4. Jun 22, 2020 at 12:31 PM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Hmmm... now that is interesting. :monocle:
    I can’t say I know what that might be about. So the beeps started after the NSV light bar install?
  5. Jun 22, 2020 at 12:35 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    I did not cut anything either mine is a 2019 DC limited it has LED lights
    Beesta and ElNopal like this.
  6. Jun 22, 2020 at 12:41 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    It's only for 2018 with leds.. Note: Vehicle Trim Advisory For 2018 Models with LED Headlights. This only applies for 2018 Model Toyota Tundra’s. Follow Steps 1-3
    ElNopal likes this.
  7. Jun 22, 2020 at 12:42 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Install instructions...
    ElNopal likes this.
  8. Jun 22, 2020 at 1:09 PM
    SLA10
    2019 Tundra TRD Pro
    Yes, it what made me question if I had messed something up, I've driven over those speed bumps dozens of times, today was the first time
    I got a beep as the front wheels passed over the speed bump, only doing a few mph.
  9. Jun 22, 2020 at 1:11 PM
    SLA10
    2019 Tundra TRD Pro
    I saw something on 2nd gen with VSC, but thats at speed in corners or turns, not straight at a few mph.
  10. Jun 22, 2020 at 1:35 PM
    SLA10
    2019 Tundra TRD Pro
    Yes that's what is confusing me, I assumed 18 meant 18+, no specific steps for a 19 and it doesn't work for 20's because of switch panel changes, and the wire they want you to cut would stop power to the turn light.
    Either no alteration to harness is required for a 19, which would be a simple note to add to the instructions
    Beesta likes this.
  11. Jun 22, 2020 at 1:37 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Yeah they could of made it a bit less confusing. When I was doing mine I had to double check what it was saying because it was confusing..
  12. Jun 22, 2020 at 1:52 PM
    SLA10
    2019 Tundra TRD Pro
    Pic
    Beesta and Tchase like this.
  13. Jun 22, 2020 at 10:46 PM
    SLA10
    2019 Tundra TRD Pro
    I've looked again at the instructions that came with the light and they say DRL & LED 2014-2019 cut the blue wire.
    Beesta likes this.
  14. Jun 22, 2020 at 10:49 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    post number 7 I posted the pdf instructions. What I quoted is right out of it.
  15. Jun 22, 2020 at 11:09 PM
    SLA10
    2019 Tundra TRD Pro
    Not trying to be argumentative. My instructions look newer
    and say 14-19 cut the wire
  16. Jun 23, 2020 at 4:44 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    We will have to ask them but that is sr base models?
  17. Jun 23, 2020 at 8:12 AM
    SLA10
    2019 Tundra TRD Pro
    Well I'm ripping the head lamp out and disconnecting light bar, even though the light bar functions normally, I dont appear to have drl or side markers, I've also found wiring the previous owner quick connected and then cut when they traded vehicle in so i have 2 cut grounds and exposed 13.6 volts wire sitting in the drivers side floor panel i have to remove. Once I unhook nsv from headlamp I'll see if marker and drl return. I still wonder if my repinning the turn signal for 28w is throwing off there harness.
    Tchase likes this.
  18. Jun 23, 2020 at 8:44 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    You should shoot them and email to confirm that cut wire, they were very good at responding when I purchased mine.
  19. Jun 23, 2020 at 10:46 AM
    SLA10
    2019 Tundra TRD Pro
    I disconnected the headlamp and steering column connections, still had no led motor, side lights, or drl. Replaced the 10A fuse on the tail light, tail lights are good and everything else works now, suspect I have to repin harness at turn signal
  20. Jun 23, 2020 at 10:53 AM
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    This ^^^
    In my experience, Caleb and MJ out at HR, have been very helpful with assistance.
    Maybe some pics to see what you are seeing as well?
    Tchase[QUOTED] likes this.
  21. Jun 23, 2020 at 11:29 AM
    SLA10
    2019 Tundra TRD Pro
    Repinned the nsv harness to account for the swap of factory wires to get 28w filament on turn signal, everything works, no more tail light fuses popping
    ElNopal and Tchase like this.
  22. Jun 23, 2020 at 12:58 PM
    SLA10
    2019 Tundra TRD Pro
    I'll have to make a note on the post for swapping filaments, save them the pain if the buy the light bar.
  23. Aug 31, 2020 at 6:34 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
    Hey guys ... so on my 2019 .. do i need to re solder the blue wire then ..? I got the same issue no driver side turn signal ..
  24. Aug 31, 2020 at 6:37 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    I assume yours still working just fine .?
  25. Aug 31, 2020 at 6:40 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    How are you able to turn on NSV and still able to have Rigid fogs on., ? I like that
  26. Sep 1, 2020 at 8:05 AM
    SLA10
    2019 Tundra TRD Pro
    Because I screwed up and forgot I had already fixed my turn signal wiring when I connected the nsv, it did allow the fog lights to be lit, but was blowing tail light fuse and drls weren't working. Once I restored the factory wiring I fixed the nsv turn signal harness for 28w filament, then everything worked, but back to no fog lights and hi beams.
  27. Sep 1, 2020 at 8:58 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    yes
    Beesta[QUOTED] likes this.
  28. Sep 10, 2020 at 2:12 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Update ... with me soldering the blue conn back together ... within a week i kept blowing 10 amp TAIL fuse. I unplugged the patch harness and everything is back to normal ... Did any of you ran to this issues.? Thanks
  29. Sep 10, 2020 at 3:26 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    How ?
  30. Sep 10, 2020 at 3:32 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Did these guys actually helped you ..? I got some guy told me “ follow the instruction to the tee” and resend me the same manual i have. SmH .!!
