NSV Light Bar Group Buy
Discussion in 'Deals & Group Buys' started by X808, Sep 17, 2019.
Thread Status:
Not open for further replies.
  1. Oct 26, 2019 at 7:13 PM
    #151
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yes I did...haven't hooked battery up yet to try it out...plan on knocking it out in the morning
    soloshairtrigger likes this.
  2. Oct 27, 2019 at 2:59 PM
    #152
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Done! So awesome!
  3. Oct 27, 2019 at 6:30 PM
    #153
    viha22
    viha22 MAGA
    WA
    2018 Cement Limited Tundra Crewmax TRD 4x4
    So i installed mine and i dont know if its normal or not but my light bar only turns on if manually turning on headlight and using high beams not when headlight is in auto mode and using high beams.
    If its normal than its kind of stupid as i can forget turning off headlights if i have to always manually turn on headlights to use the light bar.:(
  4. Oct 30, 2019 at 4:21 PM
    #154
    soloshairtrigger
    soloshairtrigger New Member
    G
    2019 Black TRD Pro
    Love these
    HulkSmurf14 likes this.
  5. Oct 30, 2019 at 9:02 PM
    #155
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    OK so I just finished installing mine!! Looks great and everything worked as planned. I had a question:
    The truck activates the swipe on startup and shut down. Is this normal?
    Also the truck has a delay in the swipe upon locking and locking the doors. It seems to be longer of a delay than ive seen in most videos. What could the issue be?
  6. Oct 31, 2019 at 2:22 AM
    #156
    soloshairtrigger
    G
    2019 Black TRD Pro
    I just installed mine and see the same thing. Seems to be normal. I called NSV for another issue. They got right back to me and the issue was quickly resolved. If you call them they should be able to explain the delay.
  7. Jan 13, 2020 at 10:38 PM
    #157
    Coachcleats90
    Coachcleats90 Solar Octane
    Brad
    Bend, Or
    23 Pro Solar Octane
    OEM Console safe Bed Tie downs Tactillian flag & Bear flag AJT key fob CBI covert bumper More to come
    Very interested
  8. Jan 14, 2020 at 7:19 AM
    #158
    HulkSmurf14
    2014 Tundra Limited
    I'm a huge fan of my setup...there is a delay, but its isn't too bad...my swipe only engages (when button is turned off) when I lock/unlock...or it is always on when button is engaged.
    I wasn't certain the light output of the entire light bar would be worth the cash it took to be owned, but I am very happy with the output after using it. It's a spotlight focus immediately in between the high beam headlights...amazing light throwing ability!
Thread Status:
