Now what, took my fender flares off
Discussion in '1st Gen Tundras (2000-2006)' started by Cummins3500, Sep 12, 2020.
  1. Sep 12, 2020 at 9:37 AM
    Cummins3500
    Cummins3500 [OP] Never finishes.....
    Logan
    Took the fender flares off in prep of some up coming paint work.
    how do I re-attach these? Some 3m two sided tape? That little gray rubber seal that came on them is toast
    Stock63 likes this.
  2. Sep 12, 2020 at 9:54 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    3M double sided tape would be a good choice , I think most manufacturers use that anyway .
  3. Sep 12, 2020 at 10:12 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Unless it's insanely expensive I would buy a new seal. Also, are there not a series of plastic clips that pop back in? You may have to replace some of those. I would also put a coat of wax on that area before covering it back up but I'm anal like that.
  4. Sep 12, 2020 at 10:45 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    There should be square holes in the body where the fenders sit. They sell the plastic clips on Amazon. You'll need the red ones and the blue ones, they are two different sizes. I do believe it's 6 clips on each fender and 2 screws. No need for tape.
    Jack McCarthy and Darkness like this.
  5. Sep 12, 2020 at 10:51 AM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    I recently had my drivers side bed repaired on my 2006 DC Limited due to a deer hit. The body shop replaced the wheel flare pad (part # 61783-0C030-C0) and installed the flare using new wheel flare clips (part # 90904-67036 )
    bmf4069 likes this.
  6. Sep 12, 2020 at 11:03 AM
    Cummins3500
    Logan
    So the flares on mine were held on by the blue and red clips, plus several screws inside the fender well and that grayish seal
    I’m having trouble finding just the seal. That seal peeled off like it was some kind of tape, that’s why I was thinking 3m
    neverMind, found it with the part #’s linked above
    Thanks :thumbsup: @weadjust
    Appreciate the info fellas: trying to get everything lined out on the ole girl before she gets monstaliner applied.
    Gmillz85 and Darkness like this.
  7. Dec 9, 2020 at 4:41 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Anyone ever sourced the clips locally? Stealership, O'riley?
  8. May 16, 2021 at 3:03 PM
    Cummins3500
    Logan
    A little thread revival, does it matter if I go back with all reds or all blues?
  9. May 16, 2021 at 3:35 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    This comes from a member here (@Wsidr1) and also at Tacomaworld that worked where 1st Gens were built.
    Fender flare clips
  10. May 16, 2021 at 3:56 PM
    Cummins3500
    Logan
    @BubbaW sweet, appreciate it. That post mentions you can tell from the slots on the back of the flares what goes where :thumbsup:
    BubbaW likes this.
  11. May 16, 2021 at 6:50 PM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    Some of mine are busted so this will be helpful.
  12. May 17, 2021 at 5:46 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Yep. Orange ones in the longer slots. Blue ones in the square slots.
  13. May 17, 2021 at 8:04 AM
    stupidchicken03
    stupidchicken03 Team Moist
    Thomas
    In the SAC of CA
    -2002 SR5 4x4 AC -2018 Lifted XV Trek
    Method MR701 17x8.5 w/ BFG KO2 265/70/17
    Great timing for this thread to pop up. Been thinking about removing mine to Rhino-line them.
    CodyP likes this.
  14. Aug 7, 2021 at 1:25 PM
    Outbackrob
    Outbackrob New Member
    2002 AC TRD
    Just replaced the 20yo stereo tape deck with wireless CarPlay. I feel like I have traveled ahead in time!
    THANK YOU! This post definitely me some cash and probably a lot of aggravation. Much appreciated!!
    I love this forum!
    BubbaW[QUOTED] likes this.
  15. Aug 7, 2021 at 1:57 PM
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    I recently did this on the front flares of my 01 AC TRD. There were 3 different plastic clips. I'm sure yours mounts different. Look on Toyota parts online and look carefully to order whatever clips or strips you need.
  16. Aug 7, 2021 at 3:09 PM
    Outbackrob
    2002 AC TRD
    The manual shows something different still. But you are right. There are THREE different clips needed for the front of an 02 AC TRD, too. The familiar Red and Blue and the one in front which is more of an opaque orangey red. Have NO idea which one that is...... Hope the driver's side removes as easily....
  17. Aug 7, 2021 at 3:13 PM
    Outbackrob
    2002 AC TRD
    So did you also replace the little rubber molding that goes around the flares? I am planning to replace all of mine. HOWEVER, the original ones were glued on or maybe taped on. The new ones (and I haven't confirmed it yet) seem to have NO adhesive on them at all. There does not seem to be a part associated with this either. I can't imagine trying to run a bead of glue all around my nice new paint job..... What did you do?
  18. Aug 7, 2021 at 3:21 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
    Do you have unpainted fender flares? Not just thin trim? If so you have what I have. Three different types of clip. And a rubber weather strip with a thin strip of double sided tape on each side. It sits between the plastic fender flare and the paint. If I get time I'll take a screenshot of the online parts catalog.
    Outbackrob likes this.
  19. Aug 7, 2021 at 3:30 PM
    mbreed2
    Allentown PA
    2001 Tundra 4x4
  20. Aug 9, 2021 at 12:45 PM
    Outbackrob
    2002 AC TRD
    Thank you, sir! I ordered all the parts. Then after doing so, I found a few threads that talked about gluing the rubber strips back. I may have missed a post, but it sounded like they were gluing NEW parts on. Fortunately, my parts arrived and they already have adhesive on them. Now just waiting on one more set of clips! Kinda can't wait to get the gray plastic flares Raptor coated and back on, but I am sorta liking the look without the flare as well.....
    mbreed2 likes this.
  21. Sep 30, 2021 at 8:28 PM
    Outbackrob
    2002 AC TRD
    Finally got it done. Never did find the third clip part number but they were the only clips not to break when I pulled the old ones off. They look a little different than the red or blue ones
  22. Oct 1, 2021 at 5:43 AM
    shifty` Waving My Dick In The Wind
    Replying here also just in case anyone finds this thread later and gets confused.
    More info on the pink clips can be found here. https://www.tundras.com/threads/red-and-blue-fender-flare-clips.87210/
