NOW, I've done it! Crossed battery leads.
Discussion in 'Other Toyota Vehicles' started by Mr Badwrench, Mar 1, 2019.
  1. Mar 1, 2019 at 6:49 PM
    Mr Badwrench
    Mr Badwrench [OP] New Member
    Hello all, I am Mr. Badwrench, and my name suits me quite well.
    I crossed the battery leads on my truck today. Not my Tundra though, my Tacoma. It's an '03 limited 4X4 V6.
    My battery died two weeks ago, and I purchased one today. I don't know what the hell I was thinking, I bought the wrong battery (reversed leads), and my eyes aren't the best and that's my story and I'm sticking to it... Now my truck won't even crank. I have no power to ANYTHING.
    Is there a main fuse for this, possibly a fuseable link? It was approaching dusk when I did this, so I really can't trace out the wiring as well as I would like to.
    I was in a hurry guys, cut me some slack..
  2. Mar 1, 2019 at 6:54 PM
    Wonder if the ECU fried
  3. Mar 1, 2019 at 6:54 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    There is always a fuse. I would search the engine side first
  4. Mar 1, 2019 at 6:54 PM
    Mr Badwrench
    NOOO go away! My first thought actually.
    joonbug likes this.
  5. Mar 1, 2019 at 6:56 PM
    I agree with this.
  6. Mar 1, 2019 at 6:57 PM
    Lupe
    Lupe New Member
    Lupe
    2006 Tundra
    Could be a ecu.
  7. Mar 1, 2019 at 7:00 PM
    tinman10101 and Mr Badwrench[OP] like this.
  8. Mar 1, 2019 at 7:07 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    check your main fuse box , check fuses marked "main fuse or efi fuse or something like that" also check your manual book for list of main fuses
    Mr Badwrench[OP] and OR18TRD like this.
  9. Mar 1, 2019 at 7:16 PM
    @ARamirez73 can sell/install the battery.
    Trooper2, Watt maker, Casper3 and 5 others like this.
  10. Mar 1, 2019 at 7:22 PM
    8MINT8
    8MINT8 #NotBetty
    Lost
    2018 Unicorn TRD
    Or you get
  11. Mar 1, 2019 at 7:24 PM
    Westside_cook
    Westside_cook New Member
    2018 Double Cab in Superwhite
    Stock
    I can’t imagine the battery actually going bad.
    Trooper2 and Mr Badwrench[OP] like this.
  12. Mar 1, 2019 at 7:25 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    take the battery to the auto parts store that you prefer and have them check the battery and do a load test on battery
    Toyotoholic and OR18TRD like this.
  13. Mar 1, 2019 at 7:32 PM
    Mr Badwrench
    I load tested it, it is okay.
    OR18TRD likes this.
  14. Mar 1, 2019 at 7:34 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    OP your username is quite fitting at the moment.
    I wouldn't sweat it, that's why there are fuses. I would start by checking them. Do you know how?
    Toyota switches the posts so we need to buy special batteries, so I vote blame them.
    Mr Badwrench[OP] likes this.
  15. Mar 1, 2019 at 7:39 PM
    Mr Badwrench
    yeah, yeah... fits like a glove. Yeah, I will manage testing my fuses, it is just too dark to tear into it. Anybody else done this? I am really sweating this one.
  16. Mar 1, 2019 at 7:48 PM
    trdprobped17
    trdprobped17 New Member
    I would call AAA and have them come out to check to see if it’s really the battery. They have that battery tester and OBDII reader on their vehicles. However, you’ll need to tell them that you need them to send out the mechanic’s truck, because you don’t know what the problem is.
    Good luck!
  17. Mar 1, 2019 at 7:52 PM
    Mr Badwrench
    Any suggestions though?
    trdprobped17[QUOTED] likes this.
  18. Mar 1, 2019 at 8:20 PM
    Mr Badwrench
    #34 is what I am after, apparently. Thank you Migraine, I do appreciate this. I have rebuilt engines, drive trains... transmissions, xfer cases, front and rear ends and have restored Scouts, Blazers and CJ's. But I have never screwed anything up like this, nothing so simple as a battery replacement! At least nothing I couldn't fix. I hope this is just a fuse! I am getting old... my mind isn't what it was
  19. Mar 1, 2019 at 8:20 PM
    Mr Badwrench
    No! Thank You! You have most certainly helped!
    Migraine and MotoTundra like this.
  20. Mar 1, 2019 at 8:20 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    For a Honda not a Toyota, but same situation.
    Watch the whole video first.
    Replace the fuse though, don't twist it to make contact. Not even as a test.
    https://youtu.be/keuRJgOMfK4
    YardBird likes this.
  21. Mar 1, 2019 at 10:00 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    My pops and I did this on an old Ford years ago. In that particular case, the battery was fine. Starter solenoid popped and smoked, and one of the fusible links blew.
    As soon as I started reading your post, the first thing I thought was the fusible links. I'd certainly check there first. If that doesn't work, maybe check the starter solenoid.
  22. Mar 1, 2019 at 10:16 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    A buddy of mine did this to a truck of mine when we where younger. Fried my ecu. :oops:
  23. Mar 1, 2019 at 11:44 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have guys do this at work all the time not really a big deal just replace the main fuse which is 100 percent blown. Don’t forget to cross your fingers though....
  24. Mar 1, 2019 at 11:47 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    Yeah definitely don’t do that... that’s how you cook the ECU
    MotoTundra[QUOTED] likes this.
  25. Mar 2, 2019 at 7:10 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Can someone please explain this. What's with all thr aRamirez threads/inside jokes.
  26. Mar 2, 2019 at 7:14 AM
    He was away on vacation. We were all try to jam up his inbox with alerts/messages. And his side job is at AZ.
    The @ARamirez73 was all in fun but he his back now so it should stop or at least slow down.
    T-Rex266, MotoTundra and Black Wolf like this.
  27. Mar 3, 2019 at 2:41 PM
    Mr Badwrench
    Just an update on this... Had to replace a handful of fuses and clear my check engine light, but I got it running again. The ECM is fine, and the check engine light spit out about 30 some codes... if I counted correctly. The truck smoked like crazy for about five minutes after I started it, probably because I desperately tried turning the key forward about a dozen times after realizing what I had done (could hear the fuel pump buzzing).
    All fixed, as far as I can tell. Wish me luck though, I hope that is all I screwed up. Thank you, all who responded, for you input.
  28. Mar 3, 2019 at 2:43 PM
    :thumbsup:
  29. Mar 3, 2019 at 3:05 PM
    Westside_cook
    Stock
  30. Mar 3, 2019 at 4:35 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    :yes::woot:
    Great to hear!
