[NOW CLOSED] APRIL GROUP BUY - TeraFlex Falcon Sport Tow/Haul 2.25" Leveling Kit - Tundra
Discussion in 'Deals & Group Buys' started by French Avocado, Apr 1, 2021.
Thread Status:
Not open for further replies.
  1. May 27, 2021 at 10:07 AM
    #421
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    While zero impact is unlikely it is probably very minimal.
    The ride with these things is excellent.
    Speed bumps don’t really seem to exist anymore.
  2. May 27, 2021 at 10:10 AM
    #422
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Thanks for the description of how the load and settings interact. This is what I want most, being able to change the setting when I am towing my travel trailer.
    French Avocado[OP] likes this.
  3. May 27, 2021 at 11:11 AM
    #423
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I corner great, bumps are smoother. Turning radius seems better but I think that's because my ride is a little more firm so I can corner without so much body roll.
    I still rub in reverse at full lock, but other than that I am happy.
    akmerle[QUOTED] and GODZILLA like this.
  4. May 28, 2021 at 2:52 PM
    #424
    French Avocado
    French Avocado [OP] Double Entundra
    Utah / Wyo
    I asked TeraFlex's "Live Agent" on the website:
    What is the maximum rear lift for a Tundra if I install the 2007+ Toyota Tundra: Falcon 2.25” Sport Tow/Haul Shock Leveling System? Specifically, can I install rear shackles with a 1.25" lift?
    And the tentative response was:
    I would install the Falcon kit first and see how you like the way it sits. You can add up to 1 in of lift I believe
    That is not a very clear answer. Seeing what @Black and @John175 have done with the CB+1 I am in the market for the CB+1, because @Black and @John175 have got the look I want.
    Edited to add @John175 because his combo with trailer looks great too
    Asimov2025 and GODZILLA like this.
  5. May 28, 2021 at 3:11 PM
    #425
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    I ordered some +2 shackles and I'm planning on running heavy accessory and adding some shims up front if the rake is too extreme :)
    DCLBs need all the lift and tire they can get to not look silly :)
    HulkSmurf14 likes this.
  6. May 28, 2021 at 3:13 PM
    #426
    Black
    If you are going to do that much in the front though not sure I would you are probably going to want to add UCAs to your list.
  7. May 28, 2021 at 3:17 PM
    #427
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    Yeah... the plan is to see what the alignment is like and see
  8. May 30, 2021 at 5:02 AM
    #428
    1UP
    1UP Truck Gang
    @737fixer
    Here is the measured height difference.
  9. May 30, 2021 at 7:53 AM
    #429
    Suprafantx
    Suprafantx New Member
    2020 4X4 White Tundra TSS
    From the picture I saw the difference between the stock and level positions is 1 and 3/8 inches. If the Falcon stock setting is the same high with stock OEM, I think at level setting my truck still have more than half inch rake. Thanks for the picture.
  10. May 30, 2021 at 7:57 AM
    #430
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    The measurements on the shock will not directly correspond to ride height, the shock sits more inboard then the ball joint.
    This is the same reason a 1/4" inch shim results in a 1/2" lift.
  11. May 30, 2021 at 1:05 PM
    #431
    737fixer
    737fixer New Member
    Thanks. Should have asked it here in the first place.
  12. Jun 1, 2021 at 6:55 AM
    #432
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I am excited to get these buggers in! I feel I am noticing my truck jump around more then usual now with my stock OR setup...I might be over-sensitive now but I'm excited to get the new Falcons on! One question I am looking for advice on...I generally have a topper on all the time...if not, at least for 9 months of a year...would it be prudent to leave the Falcon rears on "level 2" to mitigate any bounce once installed...I think this is really a install and see how it feels kinda thing, right? Also in the winter months, I have my topper on as well as 600lbs of sand in the bed...makes an enormous difference and gives me steroidal traction...I assume at LEAST setting 2 on the rear Falcons will be warranted? Just curious what advice you all might have...or if there is a supposed weight rating for consideration between the settings on the rear Falcons?! Either way, I'm stoked to get these comforting suspension bits installed!
    LarryDangerfield likes this.
  13. Jun 1, 2021 at 8:46 AM
    #433
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    The great thing about these shocks is a twist of the dial and drive the same section of road to "Tune" the rear shocks to the ride you like best. My ride is essentially the same as I had with the TRD Sport shocks but handles rough roads way better. I carry quite a bit of weight in the rear everyday from a full size spare, floor jack and two swing-away bins filled with tools. I keep mine on #1 setting and #3 when towing.
    HulkSmurf14[QUOTED] likes this.
  14. Jun 13, 2021 at 7:11 PM
    #434
    Black
    A little unscientific off-road testing for you folks tonight.
    My buddy has a pretty gnarly gravel/mud/crap lane leading to his house off the main road about a mile.
    It is hilly, curvy, and not an even/flat portion for the stretch. We have had a ton of rain so it is rutted pretty well currently.
    I knew this would be a good base line run for some very unscientific testing. So I had been paying attention to speeds and how things felt.
    My wife’s Suburban with the factory 22” wheels and GMs craptastic Magnaride system (to which I can’t wait to delete) handled this lane at about 10-15mph. 15 mph in the rutted times was a seriously bad idea.
    In the Tundra with the factory Limited suspension and 70K+ miles. 15-20mph was a decent speed where it stayed moderately comfortable. The last few times I went I knew the Falcons were coming so I pushed it. 30-35 mph not only was I getting hammered in the truck you really felt the truck taking a beating.
    So tonight went out there in the Tundra with the Falcons for the first time and 35mph was absolutely nothing for this truck. Absolutely felt stable as could be and while you could feel the suspension working, it was not getting worked, nor was the truck getting bashed, nor was I really getting hammered. On the way out I knocked it up to 45 and 50mph and the truck handled it just fine there are just a number of curves so anything over 50 is not going to happen no matter what you drive you just don’t have the space or room unless you want to meet some trees.
    I am still very impressed with this Falcon system. I am
    Still waiting for life to slow down a bit for me and I can do some real off-roading being that is what I have built it for.
  15. Jun 15, 2021 at 6:31 PM
    #435
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Just to give you guys a little confidence I ordered the eibach stage 2 kit from stage 3 Motorsports. It said they had some in stock and after I ordered the number went down by one so it was an accurate counter and it showed up in a timely manner. Not sure how many of you guys are still waiting for your kits but I look forward to seeing all of you get them.
  16. Jun 15, 2021 at 6:38 PM
    #436
    Black
    Stage3 is a top notch operation. I ordered my kit from them in November used them for some stuff on my Expedition before the Tundra and just built my buddy’s Tacoma with Eibach Stage 2s and ordered all RCI Skids from them.
    While I ordered from Stage3 they were drop shipped from Teraflex/Falcon.
    They were excellent in communications over my 4 month wait.
  17. Jun 16, 2021 at 9:16 AM
    #437
    French Avocado
    Utah / Wyo
    There are 19 of us waiting - impatiently. Should be about second week of July.
  18. Jun 16, 2021 at 9:21 AM
    #438
    MightyTundraGA
    MightyTundraGA New Member
    If this group buy deal ever comes back around again, please let us know!!!!
  19. Jun 16, 2021 at 9:24 AM
    #439
    18" TRD Off Road Wheels
    It wasn't a deal that came around, though. @French Avocado busted his butt and did all the ground work and contacting to get it set up with the retailer... or he had his secretary do it. Either way, group buys don't usually happen without somebody doing the leg work unless the seller is a vendor on the forum.
  20. Jun 16, 2021 at 9:28 AM
    #440
    MightyTundraGA
    Well, considering half the forum that wanted them probably took advantage of French Avocado's hard work, the likelihood of seeing another group buy is probably not high.
  21. Jun 16, 2021 at 9:31 AM
    #441
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We can let @French Avocado confirm if you'd like, but I was on retainer to take over the GB if Stage 3 fell through. If you'd like to order I can't quite get you to the GB pricing, but I can get you pretty close even in a one-off situation. PM incoming.
  22. Jun 16, 2021 at 9:42 AM
    #442
    French Avocado
    Utah / Wyo
    I don't give my secretary the fun Tundra work!
    HulkSmurf14 and GODZILLA[QUOTED] like this.
  23. Jun 18, 2021 at 5:06 AM
    #443
    K9Lonzo
    K9Lonzo New Member
    Kris
    2019 Silver Sky Platinum
    Anyone else get a shipping confirmation? Christmas is coming in June for me it appears!
    French Avocado[OP] and GODZILLA like this.
  24. Jun 18, 2021 at 5:19 AM
    #444
    Congrats, man! No news for me, yet. I was one of the last to give my info, so I expect to be one of the last to have it shipped. All good. I'm buried with a million other concerns right now anyway. :goingcrazy:
  25. Jun 18, 2021 at 6:23 AM
    #445
    kranyx
    kranyx New Member
    '07 DCLB 5.7
    Just got my shipping confirmation as well. :bananadance:
  26. Jun 18, 2021 at 6:26 AM
    #446
    Ignore my previous post! Shipping confirmation hit my email 12 minutes ago! :yes:
    French Avocado[OP] and RobertD like this.
  27. Jun 18, 2021 at 6:42 AM
    #447
    Suprafantx
    No news for me yet.
  28. Jun 18, 2021 at 7:11 AM
    #448
    French Avocado
    Utah / Wyo
    Thanks for the heads up. I found the notice in my promotions folder with delivery TODAY!! Great news.
    HulkSmurf14 and GODZILLA like this.
  29. Jun 18, 2021 at 7:27 AM
    #449
    HulkSmurf14
    2014 Tundra Limited
    I am JACKED to see said email/confirmation! The juice will be worth the squeeze!
    **I just got my tracking information...delivery Monday, June 21!! OOOOH HEEELLLLL YEAH!!!!
    GODZILLA and French Avocado[OP] like this.
  30. Jun 18, 2021 at 7:49 AM
    #450
    French Avocado
    Utah / Wyo
    Check your spam folder. Amazing day - a month earlier than expected.
    RobertD and GODZILLA like this.
Thread Status:
